Re: Stuck .500"dowel pin in engine for trans bell help! [Re: Clanton] #2777243
05/22/20 10:37 PM
05/22/20 10:37 PM
You should be able to see the offset step on the dowels work
Or are you verifying the exact amount of offset with those dowels work If so, good for you up
Re: Stuck .500"dowel pin in engine for trans bell help! [Re: Cab_Burge] #2777274
05/23/20 07:58 AM
05/23/20 07:58 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
You can weld the bolt with the engine in the car. Drilling the left side would require tilting the engine a fair amount. Slide hamer may not fit in the tunnle either. Welding is way quicker. Plus when you weld a fastener it tends to shrink. Used a standard length 3/8" ratchet to pull it out. Took 5 minutes to pull both dowels.
Doug
Re: Stuck .500"dowel pin in engine for trans bell help! [Re: Cab_Burge] #2777295
05/23/20 08:53 AM
05/23/20 08:53 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
You know how getting even the small parts need to be checked.I am going to file a pointer to help me see things
Re: Stuck .500"dowel pin in engine for trans bell help! [Re: dvw] #2777297
05/23/20 08:56 AM
05/23/20 08:56 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you for your input on this but my 110 Sears welder and the operator are not that good
Doug
Re: Stuck .500"dowel pin in engine for trans bell help! [Re: Clanton] #2778768
05/27/20 03:21 PM
05/27/20 03:21 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The CAV-95200 worked like butter pulling the dowels.
Re: Stuck .500"dowel pin in engine for trans bell help! [Re: Clanton] #2778813
05/27/20 05:30 PM
05/27/20 05:30 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hmmm... Now I know who has one up Maybe when we do Fran's stick conversion on his wagon he might hit you up grin
Gus beer
64 Plymouth Savoy
Dana 60
Re: Stuck .500"dowel pin in engine for trans bell help! [Re: fourgearsavoy] #2778838
05/27/20 06:32 PM
05/27/20 06:32 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I would be glad to let you guys use it.
Gus beer
