Page 3 of 18 1 2 3 4 5 17 18
Re: 1970 Coronet.... Wanna-Bee project. [Re: Edison62] #277585
09/14/09 06:17 PM
09/14/09 06:17 PM
Halifax, N.S. Canada
Edison62 Offline OP
Edison62  Offline OP
Few more pic's before the fun begins... pretty clean floor. Will need a Rallye Dash frame and guages w/harness.
Well, found the dash I need complete with A/C and harnesses....... most costly item yet(other than the car)... man this adds up fast!
Don't be stupid.... it's not smart!
1970 Super Bee. Big blk 4 speed car.
1973 Dodge Dart Sport 340 4 speed car.
1985 Dodge Ram D-100 /6 auto. Original paint
1990 Dodge Ram D-150 V-6 5 Speed. Original paint
1995 Chrysler LHS V-6 auto. Original paint
2014 Ram 1500 R/T 5.7 Hemi...!
Re: 1970 Coronet.... Wanna-Bee project. [Re: Edison62] #277586
09/20/09 08:44 PM
09/20/09 08:44 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Nice score...are you going the AC route ?
Re: 1970 Coronet.... Wanna-Bee project. [Re: 340dart4spd ] #277587
09/24/09 06:33 PM
09/24/09 06:33 PM
Edison62 Offline OP
Edison62  Offline OP
Yes... I wanted to keep the car an A/C car and the donor car (71 Chrysler 300) has the 440 w/all the Air stuff!
Re: 1970 Coronet.... Wanna-Bee project. [Re: Edison62] #277588
09/24/09 06:53 PM
09/24/09 06:53 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
is the white one AC... if not your gonna have to cut the firewall to use Air..
Re: 1970 Coronet.... Wanna-Bee project. [Re: 340dart4spd ] #277589
09/30/09 09:31 PM
09/30/09 09:31 PM
Edison62 Offline OP
Edison62  Offline OP
Yup... factory A/C car!
Re: 1970 Coronet.... Wanna-Bee project. [Re: Edison62] #277590
10/01/09 06:04 PM
10/01/09 06:04 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
cool your all set then,, I have a ton of 70 parts if u need anything
Re: 1970 Coronet.... Wanna-Bee project. [Re: 340dart4spd ] #277591
10/03/09 06:16 AM
10/03/09 06:16 AM
Edison62 Offline OP
Edison62  Offline OP
Want/need List:
:white door panel/arm rest/interior trim
:2X15" rallyes
:radiator for a big blk 4 speed car
:8 & 3/4 sure-grip
:big block bell & inspection cover
I'm heading to Maine the weekend of the 17th... doing a little pre-Xmas shopping.
Bryan
Re: 1970 Coronet.... Wanna-Bee project. [Re: Edison62] #277592
10/20/09 07:28 AM
10/20/09 07:28 AM
Edison62 Offline OP
Edison62  Offline OP
Well, since the Coronet is in the body shop I've pulled the donor car in the main garage to pull the motor & tranmission...... here's the car!
Re: 1970 Coronet.... Wanna-Bee project. [Re: Edison62] #277593
10/20/09 07:30 AM
10/20/09 07:30 AM
Edison62 Offline OP
Edison62  Offline OP
The motor...440 HP! HP + Torque =
Bryan
Re: 1970 Coronet.... Wanna-Bee project. [Re: Edison62] #277594
10/20/09 01:34 PM
10/20/09 01:34 PM
Tracy, New Brunswick, Canada
magnumcharger Offline
Bryan, don't forget...I need an 8.75 diff!!
Hinty hint-hint!
Re: 1970 Coronet.... Wanna-Bee project. [Re: magnumcharger] #277595
10/20/09 03:18 PM
10/20/09 03:18 PM
Edison62 Offline OP
Edison62  Offline OP
Hinty hint-hint!
NO worries..... consider it done! I may need the center section but the rest is yours....... consider it payback for the hood find!!!
Bryan
Re: 1970 Coronet.... Wanna-Bee project. [Re: Edison62] #277596
10/20/09 03:51 PM
10/20/09 03:51 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
what year is the car bryan...
Re: 1970 Coronet.... Wanna-Bee project. [Re: 340dart4spd ] #277597
10/20/09 08:51 PM
10/20/09 08:51 PM
Edison62 Offline OP
Edison62  Offline OP
The donor car is a 1971 Chrysler 300...... 440 TNT auto car loaded out. Originally Green w/white interior. I've had the car about 10 years..... it has points so I'll need a newer dist to put in my car.
Bryan
Re: 1970 Coronet.... Wanna-Bee project. [Re: Edison62] #277598
10/21/09 10:51 AM
10/21/09 10:51 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
Bryan
must be a late 71.. I see it has the later 72 Air cleaner....
Re: 1970 Coronet.... updated pic's Oct 29th! [Re: 340dart4spd ] #277599
10/29/09 06:07 PM
10/29/09 06:07 PM
Edison62 Offline OP
Edison62  Offline OP
Ok, got a few.... first off just had to lay the Super Bee hood on it.... my resto man Jeffery took this shot before the disassembly began.
Re: 1970 Coronet.... updated pic's Oct 29th! [Re: Edison62] #277600
10/29/09 06:08 PM
10/29/09 06:08 PM
Edison62 Offline OP
Edison62  Offline OP
Another....
Re: 1970 Coronet.... updated pic's Oct 29th! [Re: Edison62] #277601
10/29/09 06:09 PM
10/29/09 06:09 PM
Edison62 Offline OP
Edison62  Offline OP
Ok, here we go....
Re: 1970 Coronet.... updated pic's Oct 29th! [Re: Edison62] #277602
10/29/09 06:10 PM
10/29/09 06:10 PM
Edison62 Offline OP
Edison62  Offline OP
Another one...
Re: 1970 Coronet.... updated pic's Oct 29th! [Re: Edison62] #277603
10/29/09 06:11 PM
10/29/09 06:11 PM
Edison62 Offline OP
Edison62  Offline OP
4 speed ....... someday!
Re: 1970 Coronet.... updated pic's Oct 29th! [Re: Edison62] #277604
10/29/09 06:12 PM
10/29/09 06:12 PM
Edison62 Offline OP
Edison62  Offline OP
Top is removed!
