Page 2 of 4 1 2 3 4
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: plycuda] #2775846
05/18/20 05:00 PM
05/18/20 05:00 PM
Central TEXAS!!!!
sr4440 Online content
sr4440  Online Content
Central TEXAS!!!!
I had a chevy do the same thing, would run fine when cold and then when hot it would turn into a dog. Was hard to start when hot. Turned out the coil was bad, changed it and all was good.
Joe
Without Data, you’re just another guy with an opinion.
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: plycuda] #2775852
05/18/20 05:08 PM
05/18/20 05:08 PM
Berlin, CT
SportFuryS/23383 Offline OP
Confused
Confused
Berlin, CT
Originally Posted by plycuda
get the heat off the carb.
The car has a phenolic bodied carb spacer, and a phenolic bodied Demon carburetor on it also so it dissipates heat better.
If You Ask Me This Whole World Has Gone To Hell- Creed Fisher
Proud Supporter Of LGBT (Liberty Guns Beer & Trump)
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: mother hen] #2775856
05/18/20 05:13 PM
05/18/20 05:13 PM
St.Pete,Florida
lancer493 Offline
lancer493  Offline
St.Pete,Florida
I agree with lewtot184 to check integrity of fuel delivery system. Road salt and sand accumulation where the steel fuel line runs along the frame rails and under front suspension rusted fuel line producing pin holes in the line covered with debri. Line would never hold a real vacuum.Mechanical pump couldn't produce enough vacuum to pump fuel at low speed when warmed up. It happend to a police vehicle (Mopar) while driving in a parade. Very imbarrassing for the officer,when it died out several times.
Porous fuel lines,neoprene or steel,can fool you. Same for a clogged sending unit sock, or lack of tank venting. Early vehicles, alot of times relied on venting provisions inthe fuel tank cap itself.You can verifythe lack of venting by running the vehicle without the cap on after the car has warmed up.If car operates correctly at that point, you have wrong gas cap plugged tank vent tube.Be sure to also check sock tube on fuel sender on an older car that has set for a while, it has fooled many Bill
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: SportFuryS/23383] #2775858
05/18/20 05:20 PM
05/18/20 05:20 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
So was there any signs of pistons scuffing as I metal transfer? When you called in the experts did they square up the bores and sign off on "well that was the cause" How was the valve lash at running temp? The 440 Source heads sounds like a strange part addition since Nick was an Indy head guy. But since your dad was paying the bill I guess he put on what he wanted shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: SportFuryS/23383] #2775862
05/18/20 05:30 PM
05/18/20 05:30 PM
Berlin, CT
Confused
Confused
Berlin, CT
Here are some more pictures of the engine....
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: SportFuryS/23383] #2775863
05/18/20 05:31 PM
05/18/20 05:31 PM
Berlin, CT
Confused
Confused
Berlin, CT
One more picture......
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: fourgearsavoy] #2775866
05/18/20 05:38 PM
05/18/20 05:38 PM
Berlin, CT
Confused
Confused
Berlin, CT
Yes there was scuffing but very very minimal and don't believe that caused the problem, our mechanic took the oil pan off the engine and said he "leaned towards" honing the cylinders, and another friend of ours also suggested honing the cylinders as well like we did
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: fourgearsavoy] #2775871
05/18/20 05:45 PM
05/18/20 05:45 PM
Berlin, CT
Confused
Confused
Berlin, CT
Nick set all that up and it was not touched since then
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: fourgearsavoy] #2775872
05/18/20 05:47 PM
05/18/20 05:47 PM
Berlin, CT
Confused
Confused
Berlin, CT
Gus beer
That would be correct my stepfather wanted the 440 source heads.
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: lancer493] #2775876
05/18/20 05:49 PM
05/18/20 05:49 PM
Berlin, CT
Confused
Confused
Berlin, CT
The car does not have a sending unit sock
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: SportFuryS/23383] #2775878
05/18/20 05:52 PM
05/18/20 05:52 PM
Berlin, CT
Confused
Confused
Berlin, CT
We honed out the cylinders .003" and it still does not run
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: SportFuryS/23383] #2775881
05/18/20 05:59 PM
05/18/20 05:59 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
too many unknowns here. what does it mean the car doesn't run?
what is the initial timing set at? are you running an electronic distributor or points? is the distributor in 180 degrees? is there a thermostat in the car? if yes take it out. what carb is on the car now? take the throttle cable off the carb. I just ran across this on another site where the throttle cable was hanging up pulling the throttle blades open exposing the idle slots and making the mixture screws in effective. how many different problems are we fighting here. so lets take it one at a time.
also hopefully you didn't hone a full .003 out of the cylinders that's a ton. telescoping gages are not the way to measure the bores.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: GY3] #2775884
05/18/20 06:04 PM
05/18/20 06:04 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Originally Posted by GY3
I had a magnetic pickup do this in a '75 Powerwagon a few years back. It would run fine until it got warmed up and then wouldn't start. Turned over fine, though, just no spark.
I've had them do that too.
Just remember....air, fuel, spark, compression. That's all it needs.
The odds of it losing compression and air are slim.
It's most likely losing fuel or spark.
Check for fuel spark with the condition duplicated.
Quick test for ballast resistor equipped stuff, multimeter required:
Check coil + voltage key in start vs. key in run. Should have battery voltage in "start", should be around 9v or slightly less depending on ballast value with key in "run". If you've got less than battery voltage with the key in "start" then you're probably on the right track. (This is a pretty common wiring error).
Rich H.
Esse Quam Videri
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: SportFuryS/23383] #2775886
05/18/20 06:07 PM
05/18/20 06:07 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I love the car! Does he live near you - would love to meet him and see the car when I visit my mom.......
My first thought was fuel and the second ignition. You can't rule out fuel pressure unless you have a pressure gauge . Does it have a fuel pressure gauge? My 67 Coronet street car was running out of fuel and to diagnose it I temporarily tied a fuel pressure gauge to the wiper - it told me that my pressure was dropping to near zero on acceleration - was temperature dependant.
You could have an ignition box, pickup or ignition coil failing when it gets hot.
If the pistons were too tight in the wall, I would expect that would be easy to test by trying to turn the motor over with a breaker bar when hot. Should be noticeably harder to turn over. And it should turn over noticeably slower with the starter.
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: ZIPPY] #2775891
05/18/20 06:11 PM
05/18/20 06:11 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Fuel is vaporizing in that steel line between the pump and the carb. If you are still running the electric fuel pump, try bypassing the mechanical pump. A stroker motor should have 3/8" fuel line run from tank to carb.
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: markz528] #2775896
05/18/20 06:37 PM
05/18/20 06:37 PM
NC
440Jim Offline
440Jim  Offline
NC
The above are my initial thoughts too.
Coil, distributor pickup, fuel delivery problem when hot, etc.
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: Jerry] #2775897
05/18/20 06:38 PM
05/18/20 06:38 PM
Berlin, CT
Confused
Confused
Berlin, CT
To answer you questions Mr. Jerry we do not remember what the initial timing is set at, we are running an electronic distributor, the distributor not at 180 degrees, there is a thermostat in the car although you cannot see it in my pictures, the carb that is on it right now is a 750 cfm Demon, and unfortunately yes we did indeed hone the cylinders to .003.
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: markz528] #2775912
05/18/20 07:18 PM
05/18/20 07:18 PM
Berlin, CT
Confused
Confused
Berlin, CT
Thank you we appreciate that. Yes sir he does.
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: SportFuryS/23383] #2775931
05/18/20 08:20 PM
05/18/20 08:20 PM
I think your chasing the wrong thing to fix, take your time to figure out exactly what is causing it to not run good when warmed up twocents scope
I'm not sure where you live or where the car was driven in it life but you could have a grounding problem with the car or ignition system, works good cold and then heats up and then doesn't work good work shruggy
Good luck, keep us in the loop, we, you and all of us on here, will be glad to help you find, identify and fix the problems up
Re: 440 Stroker Engine Problems In A 1967 Plymouth Fury [Re: SportFuryS/23383] #2775948
05/18/20 08:59 PM
05/18/20 08:59 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Are the pistons cast or forged? In one bore you have .002 interference.
best so far 8.53 @ 158.59 MPH 60'1.240
Page 2 of 4 1 2 3 4
