Page 2 of 3 1 2 3
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775864
05/18/20 05:32 PM
05/18/20 05:32 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
You'd spend a good chunk of cash buying and reworking some clapped out old 286 heads to get them even be close in flow to some mildly reworked 088 BBC heads.
Re: Max wedge big block vs w2 small block [Re: fast68plymouth] #2775867
05/18/20 05:40 PM
05/18/20 05:40 PM
Fort Madison iowa
Moparpuller Offline OP
Fort Madison iowa
Alright. I wasn’t sure how well they would actually compare. I’m not sure which heads the Chevy guys are actually running
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775870
05/18/20 05:43 PM
05/18/20 05:43 PM
So. Burlington, Vt.
So. Burlington, Vt.
If they’re allowed to run rectangle port heads, there are plenty of good ones to pick from.
Re: Max wedge big block vs w2 small block [Re: fast68plymouth] #2775882
05/18/20 06:00 PM
05/18/20 06:00 PM
Fort Madison iowa
Fort Madison iowa
The ones I saw at the machine shop for a Chevy were rectangle. It made over 800 on there dyno
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775905
05/18/20 07:05 PM
05/18/20 07:05 PM
AndyF Offline
AndyF  Offline
Yeah I don't think you'll have any luck making more power than the Chevy guys with those rules. Not so sure on the Ford engines, the SCJ heads for the 460 weren't all that great but the rectangle port BB Chevy heads are pretty decent. Ma Mopar wasn't that generous with the cylinder heads.
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775907
05/18/20 07:10 PM
05/18/20 07:10 PM
AndyF Offline
AndyF  Offline
Originally Posted by Moparpuller
If I could be around 700 I would be happy. We can run a vac pump also to help squeeze the most out of it as possible. Rules state the engine must match the truck. I already have the chassis done so I’m stuck with Mopar powered which I would prefer anyways. I could step up to the pro stock class that allows aluminum heads and 485ci. My buddy runs a ford in that class with kaase p51s that makes 950 and is getting the new sr71s next year. They really limit the Mopar heads in that class as well. No b1s. So victors or indys would be the better choices for it.
If your buddy is making 950 then you would have your work cut out for you to match that with a 485 inch Mopar. You would need an aftermarket block (good luck there) as well as a really good set of Indy heads. Maybe the full on -1 heads or step up to the 572 heads. I'm not positive which would be the best way to go to hit 950 hp at 485 cubes but you can figure that out in a few phone calls. It wouldn't be a cheap engine that is for sure. Probably start at $20,000 and go up from there. Dry sump, belt drive, big cam, big springs, super high quality valve train, etc.
Re: Max wedge big block vs w2 small block [Re: AndyF] #2775908
05/18/20 07:10 PM
05/18/20 07:10 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Any good head porter that you pick can easily get 320 plus cfm out of a W2 Head with 2.08 valves. Put a big enough cam in it to use that cfm with a nicely ported W2 Victor intake and go have some fun.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775913
05/18/20 07:19 PM
05/18/20 07:19 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Do the small blocks get some kind of weight break for the smaller displacement?
Re: Max wedge big block vs w2 small block [Re: jwb123] #2775915
05/18/20 07:29 PM
05/18/20 07:29 PM
Fort Madison iowa
Fort Madison iowa
The 485 is in a different class so I won’t have to worry about it. Nope all trucks need to weigh 6,200 with the driver in it. No more
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775924
05/18/20 07:54 PM
05/18/20 07:54 PM
No more or no less? shruggy
Re: Max wedge big block vs w2 small block [Re: Cab_Burge] #2775940
05/18/20 08:44 PM
05/18/20 08:44 PM
Fort Madison iowa
Fort Madison iowa
Sorry. It can weigh less. You don’t want it to tho. You want as much weight on the front end as possible. A good pro stock truck you can pick the rear of the truck up with one guy. The weight of the sled makes the rear hook. The weight in the box on the truck helps keep the front end pinned down
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2775968
05/18/20 09:19 PM
05/18/20 09:19 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
So they need to weigh the same, as close to 6200 as possible. The big block is heavier where you want the weight. There's a cubic inch penalty of 40 inches with a small block and no breaks or advantage for running one.
Either I'm missing something or the question is why would you even consider a small block when the heaviest 472 big block you can find sounds like the best combo?
Re: Max wedge big block vs w2 small block [Re: CMcAllister] #2775972
05/18/20 09:28 PM
05/18/20 09:28 PM
Fort Madison iowa
Fort Madison iowa
I need to make the most power possible within the restraints of the cylinder heads allowed. If the max wedge heads won’t make the power of the w2s then I’d rather not run them. And they are worth more to somebody restoring a max wedge car
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2776010
05/18/20 11:30 PM
05/18/20 11:30 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I think the big block is the best option because of the +120 pounds on the front. twocents
Mo' Farts
Moderated by "tbagger".
Re: Max wedge big block vs w2 small block [Re: Grizzly] #2776015
05/18/20 11:53 PM
05/18/20 11:53 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Wouldn’t the best bet here be to see if they allow the factory replacement max wedge head with a low deck 470 cu in? It seems like 800hp could be possible or more?
Re: Max wedge big block vs w2 small block [Re: viperblue72] #2776018
05/18/20 11:59 PM
05/18/20 11:59 PM
Fort Madison iowa
Fort Madison iowa
Are the replacement heads available anymore?
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2776020
05/19/20 12:07 AM
05/19/20 12:07 AM
V
viperblue72 Offline
viperblue72  Offline
V
I don’t believe they’re available anymore but it doesn’t seem impossible that some could be found. Hopefully some people can chime in.
Re: Max wedge big block vs w2 small block [Re: viperblue72] #2776061
05/19/20 08:24 AM
05/19/20 08:24 AM
Fort Madison iowa
Fort Madison iowa
Ok. Thanks for the reply’s
Re: Max wedge big block vs w2 small block [Re: Moparpuller] #2776074
05/19/20 09:45 AM
05/19/20 09:45 AM
So. Burlington, Vt.
So. Burlington, Vt.
Quote
The weight of the motor doesn’t really matter.
If you are running a lighter motor, it just allows you to add more weight to the weight bar at the very front of the truck.
You’re still working within the 6200lb max limit.
As for any advantage for the SB.......
Most of the rigs need wheel speed, so they turn a lot of rpm.
The OP is looking for 8000-8500 capability.
At those kinds of rpm, I think a 434 built around a Ritter block would have better reliability than a 472 built around a stock 400 block.
Re: Max wedge big block vs w2 small block [Re: fast68plymouth] #2776084
05/19/20 10:29 AM
05/19/20 10:29 AM
Fort Madison iowa
Fort Madison iowa
Correct. Even tho the big block is heavier on the front it still isn’t as far forward as we would like to have it. Getting the weight concentrated as far forward as possible helps use the mechanical advantage. Wheel speed is very important in truck pulling. Normally around 33-34mph is how fast the tires turn and the actual truck will do 27-30 pulling the sled with the slippage from the tires. Are max effort w2s capable of supporting 434 inches at 8,500?
Page 2 of 3 1 2 3
