Page 37 of 48 1 2 35 36 37 38 39 47 48
Re: Modern Bullitt build [Re: Greenwood] #2802278
07/28/20 07:53 PM
07/28/20 07:53 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Larry & Don, thank you!
Originally Posted by Greenwood
This is absolutely the finest GenII Charger build out there, bar none. I have to comment on your wheels. Your "template" was always a good looking wheel, and you have done a masterful job of turning a wheel cover into a wheel. They're stunningly perfect. Outstanding!
I’m not sure about your first statement, but thank you sir!
Pat
Re: Modern Bullitt build [Re: Keepat] #2802425
07/29/20 10:14 AM
07/29/20 10:14 AM
NJ
rdrnr6970 Offline
Your #1 source for current events
rdrnr6970  Offline
NJ
Great stuff thanks!
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: Modern Bullitt build [Re: rdrnr6970] #2804755
08/03/20 08:30 PM
08/03/20 08:30 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I received a note from a member on the Pro Touring forum. He said he has been following my charger build thread and that it was his favorite thing on the Internet, well almost! He says it hurts his feelings every time he opens an update on the Charger and sees the tires I’m using on the car.
It turns out he works for Michelin North America. He said they would like to give me a set of their tires because I’m building exactly the level of vehicle and build that they want to be associated with.
Needless to say I said YES! So cool that a large corporation like Michelin would think that my home built project car is worthy of their attention.
The rear wheel (335/35-17 Michelin Pilot Sports) showed up today and I should see the front wheels (275/40-17) soon.
This is very cool, I am very honored, and I will pay it forward!!
Thank you Michelin!!
Pat
Re: Modern Bullitt build [Re: Keepat] #2804851
08/04/20 06:46 AM
08/04/20 06:46 AM
Virginia
larry4406 Online content
larry4406  Online Content
Virginia
Free is good!
What does the Michelin tire offer that the Pirelli doesn't?
Re: Modern Bullitt build [Re: larry4406] #2804911
08/04/20 09:56 AM
08/04/20 09:56 AM
NJ
rdrnr6970 Offline
rdrnr6970  Offline
NJ
You should really feel proud of what you've done with the charger!And Michelin tire sponsorship is great!
Re: Modern Bullitt build [Re: rdrnr6970] #2805162
08/04/20 07:32 PM
08/04/20 07:32 PM
Superfreak
Superfreak
Since you want to pay it forward, does this mean you will give me the car and keep the older tires? whistling
Re: Modern Bullitt build [Re: ] #2805479
08/05/20 04:21 PM
08/05/20 04:21 PM
Oakville, Ontario, Canada
CDN72SE Offline
CDN72SE  Offline
Good job Michelin, very cool.
Re: Modern Bullitt build [Re: CDN72SE] #2825552
09/27/20 09:10 AM
09/27/20 09:10 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I finally got around to that time consuming and tedious job of painting the grill. As suggested by others I use SEM trim black #39143 and titanium metallic #15253. The Testors 1/16 fine line tape works perfect!
Pat
Re: Modern Bullitt build [Re: Keepat] #2825770
09/27/20 06:59 PM
09/27/20 06:59 PM
Medford OR
FrankenScamp Offline
Medford OR
Tedious indeed, but fun. I put hours and hours into prepping/painting the grille I got for my car.
Someone had probably 4 coats of black, brushed on( rolleyes ) house paint on there I had to meticulously scrape off before I could do anything.
I only put the effort in because it was basically free, and I really wanted a 70-71 style grille to replace my 72 grille.
Thanks for the update! Looks great thumbs I’ve been jones’n beer
Re: Modern Bullitt build [Re: FrankenScamp] #2826215
09/28/20 07:13 PM
09/28/20 07:13 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Four coats of paint ouch!! The things we do for the love of the car hobby;-)
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2826653
09/29/20 08:54 PM
09/29/20 08:54 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
With a little massaging the new replacement grill trim fits very nice. Was able to clean, Paint and reuse all of the original trim clips. Note there are two different size heads as well as two different length trim fasteners.
Pat
Re: Modern Bullitt build [Re: Keepat] #2826738
09/30/20 05:36 AM
09/30/20 05:36 AM
Virginia
Virginia
Pat that grille looks fantastic!. Looks like very tedious work to accomplish that.
Re: Modern Bullitt build [Re: larry4406] #2827661
10/02/20 12:02 AM
10/02/20 12:02 AM
Superfreak
Superfreak
up bow
Re: Modern Bullitt build [Re: larry4406] #2827973
10/02/20 04:49 PM
10/02/20 04:49 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
It was fun and I’m looking forward to doing another one......... NOT:-)
Pat
Re: Modern Bullitt build [Re: Keepat] #2828045
10/02/20 07:36 PM
10/02/20 07:36 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
This car 100% deserves to be in all the car magazines when it's done.
Re: Modern Bullitt build [Re: Neil] #2828690
10/04/20 07:49 PM
10/04/20 07:49 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Neil, That would be great, But right now I just wanted to be able to drive in and out of my garage ;-)
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2835866
10/21/20 09:05 PM
10/21/20 09:05 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Lots of small details but still making progress on the reassembly of the Charger. Mounted all of the LED lights in the grill frame along with the hood latch hardware.
Pat
Re: Modern Bullitt build [Re: Keepat] #2836196
10/22/20 05:56 PM
10/22/20 05:56 PM
South Dakota
hotairballoonpilot Offline
South Dakota
are those LED head lights? Wondering what you did to get them to sit in the buckets? Reason I ask is we just did a 72 GMC that the customer bought all 4 LED headlights to the tune of over a grand. They don't sit in the buckets worth a crap.
Contact Me about AMD Prices
Re: Modern Bullitt build [Re: hotairballoonpilot] #2836364
10/23/20 05:49 AM
10/23/20 05:49 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Yes LED lights by Delta. Click on the link below and you can see that I had to open up the hole in the buckets to fit the new lights.
Pat
https://www.facebook.com/495913940789909/posts/735293970185237?d=n&sfns=mo
Re: Modern Bullitt build [Re: Keepat] #2836997
10/24/20 05:23 PM
10/24/20 05:23 PM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Would you happen to have any part numbers?
I saw in your facebook link where you bought them, but I'm not 100% clear on what you bought.
I'm looking at #'s 15093 and 15094. Are these what you used?
Thanks!
John
