Re: Big block timing cover, for serious cam thrust?
[Re: jlatessa]
#2775070
05/16/20 10:17 AM
05/16/20 10:17 AM
Posts: 8,908 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
It's chinese rubbish, I wouldn't touch it myself So this is actual first hand experience from using THIS product, correct ?!?!?
[Re: dvw]
#2775179
05/16/20 05:16 PM
05/16/20 05:16 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
They aren’t that expensive guys. Probably cheaper places to get them possibly without shipping https://www.manciniracing.com/incaaltico.html
[Re: jlatessa]
#2775200
05/16/20 06:43 PM
05/16/20 06:43 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Thanks all. Looks like a stock steel cover reinforced and a button will work well. I don't want to put any pressure against the electric waterpump.
[Re: gregsdart]
#2775227
05/16/20 08:06 PM
05/16/20 08:06 PM
Posts: 9,871 MI, usa
dvw
MI, usa
Thanks all. Looks like a stock steel cover reinforced and a button will work well. I don't want to put any pressure against the electric waterpump. If an aluminum cover works, certainly the water pump is stiff enough. Doug
[Re: dvw]
#2775403
05/17/20 12:51 PM
05/17/20 12:51 PM
gregsdart
Thanks all. Looks like a stock steel cover reinforced and a button will work well. I don't want to put any pressure against the electric waterpump. If an aluminum cover works, certainly the water pump is stiff enough. Doug Doug, you are probably right. But i have backed my [censored] into a buzzsaw to often to take even small risks.
[Re: Stanton]
#2775590
05/17/20 09:56 PM
05/17/20 09:56 PM
Posts: 6,149 Melbourne , Australia
LA360
It's chinese rubbish, I wouldn't touch it myself So this is actual first hand experience from using THIS product, correct ?!?!? A friend's customer supplied one for an engine, similar experience to the 440 source unit mentioned already. I'd rather spend a little extra and buy something that fits and support my local manufacturing base wherever possible. A part like a timing cover, I would just machine myself.
Alan Jones
