78 dodge van door seals? where to get? #2774828
05/15/20 12:42 PM
05/15/20 12:42 PM
N.Y.
sixpacksteve Offline OP
N.Y.
need the side and rear doors .
i tried Metro , No luck!
tried a few others No luck!
any ideas?
Hell Hath No Fury Like Mine
Re: 78 dodge van door seals? where to get? [Re: sixpacksteve] #2774918
05/15/20 05:18 PM
05/15/20 05:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm ignorant about the van door seals, if they have a special contour, etc.
But if it's a fairly basic perimeter seal, try restorationspecialties.com and check their online catalog.
Re: 78 dodge van door seals? where to get? [Re: topside] #2774928
05/15/20 05:57 PM
05/15/20 05:57 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Steele Rubber Products
800-230-5816
Joe
Re: 78 dodge van door seals? where to get? [Re: jlatessa] #2774933
05/15/20 06:15 PM
05/15/20 06:15 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
800-230-5816
Joe
nope
Re: 78 dodge van door seals? where to get? [Re: Sniper] #2775011
05/16/20 12:57 AM
05/16/20 12:57 AM
Between Houston & Galveston TX
SattyNoCar Offline
SattyNoCar  Offline
Did a quick google search for weatherstripping not door seals, and came up with the following. I have no experience with the company.
https://weatherstripdepot.com/collections/dodge-full-size-van-weatherstripping
And the actual company that makes the product.....
https://fairchildindustries.com/automotive/
Also shows available thru Summit Racing......
https://www.summitracing.com/search...section/weatherstripping-rubber-details?
Maybe you were using the wrong wording?
John
Re: 78 dodge van door seals? where to get? [Re: SattyNoCar] #2775044
05/16/20 09:16 AM
05/16/20 09:16 AM
RWG75
RWG75
fwiw: I used the fairchild seals on my 70s dodge truck doors and it's pretty good stuff. If the version that's rubber extruded over a metal channel so just clips on and was really easy to install. Less easy to cut to length but my tin snips are pretty dull.
