Park takes too long to engage #2774644
05/14/20 08:06 PM
05/14/20 08:06 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Put the car in park and it takes too long to stop rolling.after I take my foot off the brake.
What could be the problem Torqueflite 727
Re: Park takes too long to engage [Re: Sammy] #2774658
05/14/20 08:36 PM
05/14/20 08:36 PM
A727Tflite Offline
A727Tflite  Offline
How far does it roll?
Does it ratchet or is it quiet then it just locks without noise.
Re: Park takes too long to engage [Re: A727Tflite] #2774663
05/14/20 08:42 PM
05/14/20 08:42 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What linkage stock or aftermarket?
Re: Park takes too long to engage [Re: stumpy] #2774669
05/14/20 09:17 PM
05/14/20 09:17 PM
A727Tflite Offline
A727Tflite  Offline
When did this start. Did it ever work properly or is this a new build, or did you just do some work on the car?
Re: Park takes too long to engage [Re: A727Tflite] #2774762
05/15/20 09:32 AM
05/15/20 09:32 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
It just rolls about a foot then engages.
I had it rolling and tried to put it in park to stop it rolling and it was ratcheting and wouldnt stop.
Re: Park takes too long to engage [Re: Sammy] #2774782
05/15/20 10:55 AM
05/15/20 10:55 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Check the linkage for worn bushings. The plastic bushings can become oval and allow too much slop in the linkage. The metal pivot rod on my Challenger was worn in the lower bushing as well. So check that too. I had to weld mine up and grind it back down to the correct size.
Re: Park takes too long to engage [Re: Sammy] #2774803
05/15/20 11:51 AM
05/15/20 11:51 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
"I had it rolling and tried to put it in park to stop it rolling and it was ratcheting and wouldnt stop. "
That is perfectly normal.
Re: Park takes too long to engage [Re: stumpy] #2774818
05/15/20 12:27 PM
05/15/20 12:27 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
And something you shouldn't be doing.
Re: Park takes too long to engage [Re: Sniper] #2775001
05/15/20 11:10 PM
05/15/20 11:10 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Exactly, park isn't designed to stop a moving vehicle, it's there to lock a STOPPED vehicle in place.
