Running stamped R arms with mild HYD Roller? #2774443
05/14/20 09:45 AM
05/14/20 09:45 AM
Holland MI Ottawa
2
2boltmain Online content OP
2boltmain  Online Content OP
Holland MI Ottawa
The "what went wrong with flat tappet cam" In the race thread just drives home the risk of flat tappet/ poor quality valve train in 2020. With a mopar the switch to roller is very expensive - we must pay high price up front for the conversion to avoid even higher price potential engine damage by circulating debris thru our new engine. Im all in. Conversion is around $1300. Im talking mild HYD roller like 235 ish DUR @ .050" So question- could healthy stamped steel rockers be used with a HYD roller with 235ish Dur @.050? I realize push rods would need to be custom made after measuring. The least expensive adjustable rocker arms I would trust (no ebay roller R arms for $100) are the iron adjustables that Mancini sells. They resemble the Cranes and 273 arms from the past and are priced under $275.
Keep old mopars alive.
Re: Running stamped R arms with mild HYD Roller? [Re: 2boltmain] #2774568
05/14/20 03:49 PM
05/14/20 03:49 PM
North Dakota
6PakBee Online content
6PakBee  Online Content
North Dakota
I would think the duration isn't the concern but the lift.
Re: Running stamped R arms with mild HYD Roller? [Re: 2boltmain] #2774660
05/14/20 08:37 PM
05/14/20 08:37 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
I would wonder about the spring pressure also. I've never retrofitted a roller cam into an older motor but I believe roller cams usually require stiffer valve springs and don"t know if the stamped rockers would handle the added spring pressure. I'm no expert so this is just something you might want to check out.
Re: Running stamped R arms with mild HYD Roller? [Re: Ply72rr] #2774666
05/14/20 08:54 PM
05/14/20 08:54 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Stock roller cam LA's used stamped rockers.
Re: Running stamped R arms with mild HYD Roller? [Re: Sniper] #2774723
05/15/20 06:13 AM
05/15/20 06:13 AM
Holland MI Ottawa
2
Holland MI Ottawa
Very true that roller cams have alot more lift per DUR than flat tappet cams. This is what I will most likely run:
https://www.manciniracing.com/maraenadroar.html
Re: Running stamped R arms with mild HYD Roller? [Re: 2boltmain] #2774797
05/15/20 11:36 AM
05/15/20 11:36 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I run Crane ductile iron rockers with a hydraulic roller cam on an RB engine.
They work great!
'63 Dodge 330
11.19 @ 121 mph
Re: Running stamped R arms with mild HYD Roller? [Re: 2boltmain] #2774816
05/15/20 12:25 PM
05/15/20 12:25 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Except those pesky stock roller cams
Even comparing aftermarket cams the increased lift per duration is minor.
Using the PO's advertised duration @ 0.050 number, 235, I compared two cams from the same manufacturer, Howards Cams Rattler for the B/RB.
0.050" more exhaust lift and 0.42" more intake lift are the only differences, well that and more than double the price for just the cam.
So I looked at the same cams but for the LA.
Exactly the same specs as the B/RB cams across the line.
What I think you means is the RATE of lift can be much quicker with a roller. It can open it faster and hold it longer than a flat tappet cam. But that isn't a spec cam makers really list.
