Trouble compressing shocks for install? #2774175
05/13/20 11:31 AM
05/13/20 11:31 AM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
I had to swap the shocks on my 92 D250. The new Bilsteins were too much to compress by hand so I had to get creative. Quick and easy!
Give it a shot next time you have to do that job.
- Stu Harmon
Re: Trouble compressing shocks for install? [Re: feets] #2774184
05/13/20 11:49 AM
05/13/20 11:49 AM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Thanks for the tip. I’ll try it when I replace my A100 shocks this week.
It really doesn't matter whether you win or loose...
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK 350
Re: Trouble compressing shocks for install? [Re: BloFish] #2774216
05/13/20 01:02 PM
05/13/20 01:02 PM
Central Florida
larrymopar360 Offline
I'm tired...Very tired.
Central Florida
Good for rears, but man did I have a rough time with KYB fronts several years back. Coincidentally, I made a remark about it a few days ago on thread asking about KYB's and likes or dislikes.
Thanks for tip.
Facts are stubborn things.
Re: Trouble compressing shocks for install? [Re: larrymopar360] #2774323
05/13/20 06:47 PM
05/13/20 06:47 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
It
Thanks for tip.
Especially c bodies holy cow!
Re: Trouble compressing shocks for install? [Re: moparjim79] #2774331
05/13/20 07:00 PM
05/13/20 07:00 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
Originally Posted by moparjim79
It
Thanks for tip.
No kidding. I put some KYB GR2 shocks on the front of the Imperial and really dislike them. They were a huge PITA to get in there and I'm not looking forward to doing that again.
- Stu Harmon
Re: Trouble compressing shocks for install? [Re: feets] #2774761
05/15/20 08:31 AM
05/15/20 08:31 AM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
It
Thanks for tip.
So, building on the ratchet strap idea, I developed a similar shade tree way to install fronts on the c bodies with the "tube"--- I used zip ties and went through the shock eye then over the top stud. Some I had to make up 2 separate zip tie straps( they need to be good zip ties). When the eye is resting in the lower control arm shock slot , after it's been inserted through the tube of the frame, you cut the zip ties and it will release the shock. You just have to guide it into the upper control arm slot. It's a PITA
Re: Trouble compressing shocks for install? [Re: feets] #2775155
05/16/20 02:08 PM
05/16/20 02:08 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Did you try hitting it with your purse? tonguue
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Trouble compressing shocks for install? [Re: GoodysGotaCuda] #2775161
05/16/20 02:19 PM
05/16/20 02:19 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I did`t like KYB`s we had on our F Body. They were a pain to remove the fronts. I ended up using a floor jack to compress them due to the limited access.
Re: Trouble compressing shocks for install? [Re: mopars4ever] #2775432
05/17/20 12:58 PM
05/17/20 12:58 PM
Phoenix, AZ
Jjs72D Offline
Kerndog
Jjs72D  Offline
Kerndog
Phoenix, AZ
If you don't plan to use these crappy shocks (KYB), Drill a hole in them to remove.
Re: Trouble compressing shocks for install? [Re: Jjs72D] #2775460
05/17/20 02:18 PM
05/17/20 02:18 PM
Irving, TX
feets Offline OP
Senior Management
feets  Offline OP
Senior Management
Irving, TX
That doesn't make it any easier to install the new ones.
- Stu Harmon
Re: Trouble compressing shocks for install? [Re: GoodysGotaCuda] #2775705
05/18/20 11:53 AM
05/18/20 11:53 AM
Tucson AZ,
MadMopars Offline
MadMopars  Offline
Tucson AZ,
haha
Re: Trouble compressing shocks for install? [Re: MadMopars] #2775893
05/18/20 05:18 PM
05/18/20 05:18 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
I put new Gabriels on the front of the Dakota a couple months ago. I couldn't compress and hold them by hand long enough to start the lower bolts. After thinking about it, I got the small portable jack, stood a large 1/2" socket up on it, and jacked it into place. Would also work with the factory scissor jack but be a little more work. wink
Going out in the morning to put in new control arms and springs so I'll probably get to do it all over again. blush
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Trouble compressing shocks for install? [Re: feets] #2781973
06/06/20 01:41 AM
06/06/20 01:41 AM
central IL reg Nov 18, 1999
Stroker Offline
Stroker  Offline
I put a pair of Bilsteins on the front of the T&C last year.
I was able to compress them, but not long enough to get them positioned to where they'd explode into the right place.
I was able to use some butt-kickin' cable ties I had to keep them compressed.
Not easy with a bayonet mount on top, lol.
After I got one in, I remember thinking that I hoped I'd never have to take them out!
Re: Trouble compressing shocks for install? [Re: Stroker] #2783234
06/09/20 01:02 PM
06/09/20 01:02 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
straps are a good idea until you need to remove the hooks..
