Why would my 440 just die ? #2774120
05/13/20 09:56 AM
05/13/20 09:56 AM
69x Offline OP
69x  Offline OP
Started up the GTX after it has been sitting since last Nov. Before I started I charged the battery, then poured some gas in the carb. the car started right up and smoothed out after about 1 mn. so I get out and am watching the motor run and after about 5 mn it just kills, like a ghost turned it off, its never done that before, I tried starting it and it fired right back up, I let it run for about 30 mn, then shut it off and started it a few times and it was fine.
Any idea why it would kill like that ? car is stock. tank was full and treated with Stable. could something be failing or ?
Re: Why would my 440 just die ? [Re: 69x] #2774127
05/13/20 10:19 AM
05/13/20 10:19 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Sounds like it's electrical since it dies instantly like you turned off the key. If it was fuel, it should start running rough and die slower I would think.
When the car is running, the ignition gets power from the blue wire coming from the ignition switch. When it dies(before you touch anything) make sure you still have power on the blue wire. Test for power at the base of the steering column at that connector. Also check for power on that wire at the bulkhead connector and work your way into the engine compartment.
I'm not sure if a failing ballast resistor will cause the issue or not. It could be getting hot and not passing any current. Usually they just fail completely though. It could also be a problem with the coil. I'd start by confirming power on the blue "run" wire when it dies though.
EDIT: I just re-read your post and it sounds like it only died once. I thought it died multiple times. Since it only happened the one time, I'd start by cleaning all the contacts on the steering column connector and the bulkhead connector. If there is some condensation in the connectors it will cause them to get hot and possibly melt. When you take those connectors apart, make sure there are no signs of heat. Once they are clean, use some dielectric grease on them to keep out the moisture.
Re: Why would my 440 just die ? [Re: burdar] #2774143
05/13/20 11:05 AM
05/13/20 11:05 AM
69x Offline OP
69x  Offline OP
Thanks burdar, there was a bit of white smoke coming from the area below the last spark plug on the drivers side closest to the firewall, it took about 10 mn to stop, could this be related ?
Re: Why would my 440 just die ? [Re: 69x] #2774146
05/13/20 11:14 AM
05/13/20 11:14 AM
Kirkland, Washington
Pacnorthcuda Offline
Oh hell yes. My 70 Cuda died on me years ago from he bulkhead connector, melted connection is common. Some people even bypass the connection with a new wire through the firewall.
Disconnect it and inspect before you drive it again, you might be surprised at what you find.
Re: Why would my 440 just die ? [Re: 69x] #2774148
05/13/20 11:14 AM
05/13/20 11:14 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
run a jumper wire from the positive side of the battery to the positive side of the coil. if it starts it's probably the ballast resistor.
Re: Why would my 440 just die ? [Re: lewtot184] #2774157
05/13/20 11:47 AM
05/13/20 11:47 AM
moparx Offline
moparx  Offline
"magic smoke" appearing anywhere near electrical wiring MUST be investigated !
even when captured, it can not be returned to the wire[s] involved.
look close at both sides of the bulkhead for ANY signs of "meltyness".
beer
Re: Why would my 440 just die ? [Re: moparx] #2774161
05/13/20 11:57 AM
05/13/20 11:57 AM
69x Offline OP
69x  Offline OP
Well guys I have to admit I am not very good with electrical stuff on these cars, if it stops smoking is it safe to drive it to my Mechanic to have him check/fix or should I have it towed ?
Re: Why would my 440 just die ? [Re: 69x] #2774173
05/13/20 12:29 PM
05/13/20 12:29 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You don't have to be good at electrical to look for burnt wires.
Re: Why would my 440 just die ? [Re: stumpy] #2774188
05/13/20 12:53 PM
05/13/20 12:53 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Well 69x, if you were close by, maybe a member could stop by and take a look-see. But I see no location in your signature. I have been known to ride 100 miles to help someone for a free sandwich and a cold beer.
I have the tools and suppies to do most of these type repairs.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Why would my 440 just die ? [Re: stumpy] #2774196
05/13/20 01:08 PM
05/13/20 01:08 PM
69x Offline OP
69x  Offline OP
True
Re: Why would my 440 just die ? [Re: Dave_J] #2774198
05/13/20 01:09 PM
05/13/20 01:09 PM
69x Offline OP
69x  Offline OP
Originally Posted by Dave_J
Well 69x, if you were close by maybe a member could stop by and take a look-see. But I see no location in your signature. I have been known to ride 100 miles to help someone for a free sandwich and a cold beer.
If you were closer I would take you up on that. Minnesota is a bit to far for you I think.
Re: Why would my 440 just die ? [Re: 69x] #2774204
05/13/20 01:17 PM
05/13/20 01:17 PM
69x Offline OP
69x  Offline OP
Any one here in Minnesota ? Beer and food for you, The car does not get out much and its fun to show it to people and talk Mopars.
Re: Why would my 440 just die ? [Re: 69x] #2774477
05/14/20 11:54 AM
05/14/20 11:54 AM
69x Offline OP
69x  Offline OP
The smoke was not anywhere near the bulkhead connector. the smoke came from way down below the steering column. but thanks for the input, I will get it figured out somehow.
Re: Why would my 440 just die ? [Re: 69x] #2774555
05/14/20 03:32 PM
05/14/20 03:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
So is this a '69 GTX (I assume from username) ?
Only electrical things I can think of in that area:
Starter & solenoid
AT neutral safety switch wires
On left frame rail, brake warning lamp wire
How those would cause shut-off, I don't know.
This is where a factory service manual comes in handy to look at the circuits.
Fairly common spot for the valve cover gasket to leak, and that can generate smoke.
Cleaning the bulkhead contacts is always a good idea if it hasn't been done before; it's just good maintenance.
Re: Why would my 440 just die ? [Re: topside] #2774570
05/14/20 04:12 PM
05/14/20 04:12 PM
69x Offline OP
69x  Offline OP
Thanks Topside, yes its a 69 GTX
Re: Why would my 440 just die ? [Re: 69x] #2774575
05/14/20 04:40 PM
05/14/20 04:40 PM
SE Pa.
LimeliteAero Offline
SE Pa.
My first thought was the fuseable link? nobody else leaning that way?
Re: Why would my 440 just die ? [Re: LimeliteAero] #2774586
05/14/20 05:04 PM
05/14/20 05:04 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Quote
The car still runs. It just died the one time. If the fueable link was fried, the car wouldn't run.
Quote
Re: Why would my 440 just die ? [Re: LimeliteAero] #2774683
05/14/20 10:29 PM
05/14/20 10:29 PM
Cab_Burge Online work
Cab_Burge  Online Work
Many, many 1969 Mopars have had the same electrical problems, not good electrical parts to start with whiney
