Correct fuel pump for 440-6BBLwith 3/8” fuel lines #2773878
05/12/20 01:17 PM
05/12/20 01:17 PM
none
The Black Car Offline OP
none
I’m not sure on what type of Carter that was used on a 440-6BBL with 3/8” lines. SPD OCT 10 1969
Any help is appreciated!!
Re: Correct fuel pump for 440-6BBLwith 3/8” fuel lines [Re: The Black Car] #2773898
05/12/20 02:16 PM
05/12/20 02:16 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Pretty sure you are looking for Carter 4845S. Now sold under part number M4845.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Correct fuel pump for 440-6BBLwith 3/8” fuel lines [Re: 70gtx440dana] #2774382
05/14/20 02:00 AM
05/14/20 02:00 AM
none
none
Thank you! Perfect.
Any ideas on a 70 440-6BBL with 5/16” lines?
Re: Correct fuel pump for 440-6BBLwith 3/8” fuel lines [Re: The Black Car] #2774430
05/14/20 08:59 AM
05/14/20 08:59 AM
Lansing, MI
Lansing, MI
All 1970 440 and 440-6 B & E bodies had 3/8 fuel line. You will want to look up the 383/400 pump for your car with 5/16 lines, could be Carter 267-A. Not sure how well that set-up will work on a 440-6. You may want to change over to 3/8 fuel lines.
