1973 Challenger Brake Booster #2773450
05/11/20 10:39 AM
05/11/20 10:39 AM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
I have a 73 Challenger with manual front disc brakes. I would like to convert them to
power. I can get the booster through our local NAPA. I know I need a new firewall
plate and rod. Will this kit work, or do I need more?
https://www.ebay.com/itm/Mopar-70-71-72-73-74-B-Body-E-Body-Brake-Booster-Mounting-Plate-Bracket/174194399662?fits=Year%3A1973%7CModel%3AChallenger&hash=item288ecb99ae:g:6FAAAOSwgZpdvIcD
Thanks in advance!!
Re: 1973 Challenger Brake Booster [Re: jim6346] #2773455
05/11/20 10:51 AM
05/11/20 10:51 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
that kit should work. looks like all the unique pcs are there. however if buying a new booster I suggest getting one from a late model Cordoba say 79-81, these mount the same way as the challenger ones however you can use a 2 bolt aluminum master cylinder with them.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 1973 Challenger Brake Booster [Re: Jerry] #2773553
05/11/20 02:57 PM
05/11/20 02:57 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
You definitely need the reinforcement plate. Not sure about the other stuff. Here is my original 73 Challenger booster. The rod is already connected to the back. I can't remember if the rod connects directly to the brake pedal or if it uses another pivot point.
Re: 1973 Challenger Brake Booster [Re: burdar] #2773567
05/11/20 03:30 PM
05/11/20 03:30 PM
Newark Valley, NY
jim6346 Offline OP
jim6346  Offline OP
Newark Valley, NY
I'm thinking the other part is so I can still use the manual brake pedal?
Thanks,
Re: 1973 Challenger Brake Booster [Re: jim6346] #2773626
05/11/20 06:03 PM
05/11/20 06:03 PM
ILL
Greentween Offline
Greentween  Offline
ILL
That is what you need. The brake pedal is the same one, and that new linkage bolts to the same hole in the pedal arm where your old manual master connected.
