Can't Adjust fuel bowl height #2773245
05/10/20 05:03 PM
05/10/20 05:03 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Having a problem adjusting the height of the fuel in the bowl.
I set them low and fuel goes all the way to the top. I pulled needle and seats and cleaned them. Everything seems to work correctly. Needle moves freely but when I turn on the fuel pump, the bowl fills and starts dumping some fuel into the carb flooding it out. I turn off the fuel pump and bowls drop and engine runs fine till I turn the pump back on. Then bowls fill up too much and problem happens again. So basically, no matter where I turn the adjusting nut on the carb bowl, the fuel raises up too much.
I lowered the floats all the way down and turned my fuel pressure down to 4psi to make sure that wasn't the problem.
Re: Can't Adjust fuel bowl height [Re: Sammy] #2773262
05/10/20 05:44 PM
05/10/20 05:44 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
do you have a return fuel line ? If so check its not blocked
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Can't Adjust fuel bowl height [Re: Sammy] #2773265
05/10/20 05:50 PM
05/10/20 05:50 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If one of the O-rings on the float valve body is damaged then it will overfill the bowls.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Can't Adjust fuel bowl height [Re: Sammy] #2773266
05/10/20 05:51 PM
05/10/20 05:51 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I'm wondering if the Q16 killed the viton o ring?
The needle moves freely.
Re: Can't Adjust fuel bowl height [Re: tex013] #2773267
05/10/20 05:53 PM
05/10/20 05:53 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Tex
I do have a return system. How can this get blocked?
Re: Can't Adjust fuel bowl height [Re: fourgearsavoy] #2773268
05/10/20 05:54 PM
05/10/20 05:54 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Gus beer
Where are these o rings that you are talking about?
Are you taking needle and seat o ring?
Re: Can't Adjust fuel bowl height [Re: Sammy] #2773277
05/10/20 06:20 PM
05/10/20 06:20 PM
Rittman Ohio
Rittman Ohio
Gus beer
Yeah I have seen these leak before.
64 Plymouth Savoy
Dana 60
Re: Can't Adjust fuel bowl height [Re: Sammy] #2773280
05/10/20 06:26 PM
05/10/20 06:26 PM
Which type of floats are in that carb?
I would check the weights on them to make sure they are not damaged or hurt some way or the other scope twocents
Re: Can't Adjust fuel bowl height [Re: fourgearsavoy] #2773282
05/10/20 06:40 PM
05/10/20 06:40 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Gus beer
I guess you just can't get the o ring? Everything else looks fine.
Re: Can't Adjust fuel bowl height [Re: Sammy] #2773286
05/10/20 07:00 PM
05/10/20 07:00 PM
Rittman Ohio
Rittman Ohio
Summit sells a kit or there is a guy on E-bay that sells a pack of 10 O-rings
https://www.summitracing.com/parts/sum-200400?rrec=true
Gus beer
64 Plymouth Savoy
Dana 60
Re: Can't Adjust fuel bowl height [Re: fourgearsavoy] #2773289
05/10/20 07:17 PM
05/10/20 07:17 PM
edmonton alberta canada
500dart Offline
500dart  Offline
Check fuel pressure and replace needle and seats
Re: Can't Adjust fuel bowl height [Re: 500dart] #2773304
05/10/20 08:02 PM
05/10/20 08:02 PM
South Lyon, Michigan
6bblRoadrunner Offline
I'm having the same problem. I ordered the o-rings along with some other misc pieces from Allstate Carburetor. Never tried them before, but seem to have good prices.
https://allcarbs.com/
Re: Can't Adjust fuel bowl height [Re: 6bblRoadrunner] #2773309
05/10/20 08:11 PM
05/10/20 08:11 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I should have waited. These are better pricing than the Ebay ones.
I paid $11.13 for 10 shipped.
Your guy alllcarbs is $6.23 shipped for 10.
Plus I'm going to have to wait longer too.
I hope my needles are ruined from the Q16 fuel.
Re: Can't Adjust fuel bowl height [Re: Sammy] #2773319
05/10/20 08:24 PM
05/10/20 08:24 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Tex
any thing going through the system . Fuel line post carb collapsing or breaking up internally . Especially if older and you have changed fuel ?
Tex
New best MPH 130.32
Re: Can't Adjust fuel bowl height [Re: 500dart] #2773326
05/10/20 09:00 PM
05/10/20 09:00 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
This...Verify the gauge is right too. Needle and seats, as stated, I've had the O-rings shrink and not seal. If you screw the thing out and pull it out of the bore there should be a little felt resistance if its snug enough in the bore. Make sure the floats aren't heavy too.
Re: Can't Adjust fuel bowl height [Re: tex013] #2773328
05/10/20 09:03 PM
05/10/20 09:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Carb parts are consumables just like almost everything else. I change out my floats every 2-3 years, stainless or titanium needles and seats, Gaskets, pumps, etc. routine maintenance with little costs.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Can't Adjust fuel bowl height [Re: CMcAllister] #2773411
05/11/20 09:06 AM
05/11/20 09:06 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
There is no resistance at all o rings definitely look smaller and not plump.
All 4 are bad.
Never seen this happen before. This Q16 stuff is nasty.
Re: Can't Adjust fuel bowl height [Re: fourgearsavoy] #2773443
05/11/20 10:28 AM
05/11/20 10:28 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
the o ring problem is new to me .I figured he just over adjusted it and no more contact with the adj nut.
Gus beer
Re: Can't Adjust fuel bowl height [Re: Clanton] #2773449
05/11/20 10:34 AM
05/11/20 10:34 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Isnt going down in the needle and seat lowering the floats?
I'm pretty low now but can still get the adjusting nut on the threaded part of the needle and seat.
Re: Can't Adjust fuel bowl height [Re: Sammy] #2773484
05/11/20 12:00 PM
05/11/20 12:00 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I'm pretty sure if you try to go to low it will flood also o-ring goes below machining in bowl.
