Re: Can't Adjust fuel bowl height
[Re: Sammy]
#2773506
05/11/20 01:10 PM
05/11/20 01:10 PM
Posts: 11,566 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Check fuel pressure and replace needle and seats This...Verify the gauge is right too. Needle and seats, as stated, I've had the O-rings shrink and not seal. If you screw the thing out and pull it out of the bore there should be a little felt resistance if its snug enough in the bore. Make sure the floats aren't heavy too. There is no resistance at all o rings definitely look smaller and not plump. All 4 are bad. Never seen this happen before. This Q16 stuff is nasty. Pump gas is also not good on this stuff. Have had this occur before. O rings shrink and get hard. Q is not supposed to be left in the fuel system. Says on the can.
[Re: Mark Whitener]
#2773827
05/12/20 10:46 AM
05/12/20 10:46 AM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
In addition, I use Vaseline on the needle n seats when installing em.......
[Re: fourgearsavoy]
#2774528
05/14/20 02:21 PM
05/14/20 02:21 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
So I ordered a 10 pack of o rings off of ebay. Shipped $11.25 Was cheaper from all carbs but I'm ok with it. I did order 4 new needle and seats from Summit. The o rings showed up 1st. Lol So i picked out the old o rings and sure enough they were brittle and just snapped off. Going to install the needle and seats in a few after lunch and see if the problem is still there. Hopefully this was the fix. The needles were cleaned and they move freely.
[Re: Cab_Burge]
#2774565
05/14/20 03:45 PM
05/14/20 03:45 PM
Sammy
Wind Gap,Pa.
Are your new O rings Viton, neopreme or what are they made of? Love that Q16, don't we I believe they are viton. I'll have to check but I just installed them and they are a nice tight fit. Adjusted them to where I think they should be and NO MORE FLOODING. And yes this Q16 is nasty stuff. And I do drain the bowls after each use. Putting this on my maintenance schedule.
