Re: Can't Adjust fuel bowl height
[Re: Sammy]
#2773262
05/10/20 05:44 PM
05/10/20 05:44 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
do you have a return fuel line ? If so check its not blocked
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: Sammy]
#2773265
05/10/20 05:50 PM
05/10/20 05:50 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
If one of the O-rings on the float valve body is damaged then it will overfill the bowls. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: tex013]
#2773267
05/10/20 05:53 PM
05/10/20 05:53 PM
Posts: 1,824 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Tex I do have a return system. How can this get blocked?
[Re: fourgearsavoy]
#2773268
05/10/20 05:54 PM
05/10/20 05:54 PM
Sammy
Wind Gap,Pa.
If one of the O-rings on the float valve body is damaged then it will overfill the bowls. Gus Where are these o rings that you are talking about? Are you taking needle and seat o ring?
[Re: Sammy]
#2773277
05/10/20 06:20 PM
05/10/20 06:20 PM
fourgearsavoy
Rittman Ohio
If one of the O-rings on the float valve body is damaged then it will overfill the bowls. Gus Where are these o rings that you are talking about? Are you taking needle and seat o ring? Yeah I have seen these leak before.
[Re: fourgearsavoy]
#2773282
05/10/20 06:40 PM
05/10/20 06:40 PM
Sammy
Wind Gap,Pa.
If one of the O-rings on the float valve body is damaged then it will overfill the bowls. Gus Where are these o rings that you are talking about? Are you taking needle and seat o ring? Yeah I have seen these leak before. I guess you just can't get the o ring? Everything else looks fine.
[Re: 6bblRoadrunner]
#2773309
05/10/20 08:11 PM
05/10/20 08:11 PM
Sammy
Wind Gap,Pa.
I'm having the same problem. I ordered the o-rings along with some other misc pieces from Allstate Carburetor. Never tried them before, but seem to have good prices. https://allcarbs.com/ I should have waited. These are better pricing than the Ebay ones. I paid $11.13 for 10 shipped. Your guy alllcarbs is $6.23 shipped for 10. Plus I'm going to have to wait longer too. I hope my needles are ruined from the Q16 fuel.
[Re: Sammy]
#2773319
05/10/20 08:24 PM
05/10/20 08:24 PM
tex013
Sydney,Australia
Tex I do have a return system. How can this get blocked? any thing going through the system . Fuel line post carb collapsing or breaking up internally . Especially if older and you have changed fuel ? Tex
[Re: 500dart]
#2773326
05/10/20 09:00 PM
05/10/20 09:00 PM
Posts: 11,608 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Check fuel pressure and replace needle and seats This...Verify the gauge is right too. Needle and seats, as stated, I've had the O-rings shrink and not seal. If you screw the thing out and pull it out of the bore there should be a little felt resistance if its snug enough in the bore. Make sure the floats aren't heavy too.
[Re: tex013]
#2773328
05/10/20 09:03 PM
05/10/20 09:03 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Carb parts are consumables just like almost everything else. I change out my floats every 2-3 years, stainless or titanium needles and seats, Gaskets, pumps, etc. routine maintenance with little costs.
[Re: CMcAllister]
#2773411
05/11/20 09:06 AM
05/11/20 09:06 AM
Sammy
Wind Gap,Pa.
Check fuel pressure and replace needle and seats This...Verify the gauge is right too. Needle and seats, as stated, I've had the O-rings shrink and not seal. If you screw the thing out and pull it out of the bore there should be a little felt resistance if its snug enough in the bore. Make sure the floats aren't heavy too. There is no resistance at all o rings definitely look smaller and not plump. All 4 are bad. Never seen this happen before. This Q16 stuff is nasty.
[Re: fourgearsavoy]
#2773443
05/11/20 10:28 AM
05/11/20 10:28 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
the o ring problem is new to me .I figured he just over adjusted it and no more contact with the adj nut. If one of the O-rings on the float valve body is damaged then it will overfill the bowls. Gus Where are these o rings that you are talking about? Are you taking needle and seat o ring? Yeah I have seen these leak before.
