Re: Covid-572: Pandhemi [Re: Hemi_Joel] #2772939
05/09/20 05:37 PM
05/09/20 05:37 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Originally Posted by Hemi_Joel
Looks awesome Zippy! Is it going on the dyno?
I was quoted 800 bucks a day for engine dyno awhile back, which pretty much told me I was probably going to head right back to JAKE68's Dynojet soon as I can swing it.
I need to put that into the rest of the car more right now.
Rich H.
Esse Quam Videri
Re: Covid-572: Pandhemi [Re: ZIPPY] #2772980
05/09/20 07:49 PM
05/09/20 07:49 PM
AndyF Offline
AndyF  Offline
Using both ears on the alternator is a very good idea if you can. Are sure that alternator is going to fit in between the K frame and the motor plate? It looks like it might be too big to fit. If you are going to be testing different intake manifolds and carb combinations then you might as well make your fuel supply setup in the engine compartment really flexible. Same with the wiring and stuff like that. That is another reason why I wouldn't worry too much about cosmetic details since if you are going to be swapping parts around a lot of little nicks and dings happen. Not to mentions drilling some holes here or there.
I have no idea where you'll end up for a carb and manifold combo that work on that engine. 572 inches is a little past my experience. The numbers say you'll need a Dominator for WOT but I'm not so sure I'd want to live with a Dominator on a street car. If it was me I'd sell all the carbs and switch to EFI now but I don't think that is where you're at yet. A dual Sniper setup on a Stage V intake would probably be just about ideal for street driving and WOT use.
Re: Covid-572: Pandhemi [Re: AndyF] #2772986
05/09/20 08:16 PM
05/09/20 08:16 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
You have had carownersvirus for over 30 years! HEMI-ITIS too!!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Covid-572: Pandhemi [Re: AndyF] #2773045
05/10/20 12:45 AM
05/10/20 12:45 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
I know for sure it's a little further from the K frame than the oil filter is, on the opposite side. From studying other vehicles I know it's a little further from the K frame than the Mike Doty bracket with a much larger GM alternator on an E body. Tape measure looks good, using the B engine in the car as datum. I'll find out during mockup if I got it wrong and make whatever adjustments are needed, in case I overlooked something.
That's the idea. Flexible and easy as possible. It's been that way since the '90s, I just intend to move things around, integrate it all better and make it look like it belongs, and make it easier to work on at the same time.
I get that, but it's not really the details I'm chasing, it's more the big picture. You haven't seen the hole in the top of the RF fender that I can almost put my fist through, or seen the old repair from the '70s to the cowl that has now failed and cracked, and stuff like that. You'd understand if you got a close look. It's quite a long way from patina and needs attention.
Right, EFI is cool and all, but not for me right now, maybe later.
I can probably drop most concerns of having too large a carburetor, now the issue will be 'what is enough'?
I have one 1.450 venturi/1 and 3/4 baseplate "950".
I could potentially get another matching one and put those on the tunnel ram.
The Edelbrock single plane 2x4 looks to be worthy. Chuck told me that intake and two
750 Edelbrocks runs really good on a street 572 so I have been looking at those ever since. That's probably the best one for hood clearance/stock height. Might try that later.
Rich H.
Esse Quam Videri
Re: Covid-572: Pandhemi [Re: hemi-itis] #2773049
05/10/20 12:59 AM
05/10/20 12:59 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
True words, Al.
My condition is normally aspirated, though.
I'll never be as serious as many of the total animals (in the most respectful sense!) on this site are.
If it weren't for the time given by Covid..........
(2 hours commute I don't have to do: Very good. All the band's gigs cancelled: Very Bad. But....time is time)
No way would it be done, already fired on the ground and so on.
I'd probably be wondering when I'd get a chance to work on it.
I hope to attend Carlisle or another event out east again someday, shake hands and talk again.
Rich H.
Esse Quam Videri
Re: Covid-572: Pandhemi [Re: tboomer] #2773050
05/10/20 01:01 AM
05/10/20 01:01 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Originally Posted by tboomer
Nice Rich! Really looks great! bow
thanks Ted.
Rich H.
Esse Quam Videri
Re: Covid-572: Pandhemi [Re: ZIPPY] #2773135
05/10/20 11:23 AM
05/10/20 11:23 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Looks good......I like it a lot...Have a similar engine myself......The 572 is a great size for all around fun and reliability...
Couple of things I have learned, you didn't mention if yours is an iron block or not...Assuming it is, if you have trouble cooling, switch to a FlowKooler water pump. those things are awesome.
Carb looks a tad small.....Hemi has a big chamber and can be a cold blooded B$tch to get up to temp....Recommend calling Thumper when you decide to upgrade..
Re: Covid-572: Pandhemi [Re: ZIPPY] #2773148
05/10/20 11:52 AM
05/10/20 11:52 AM
AndyF Offline
AndyF  Offline
Yes the Edelbrock dual setup with a couple of Edelbrock carbs would be fairly inexpensive (by Hemi standards) and should work really well. If it was me I'd use the Edelbrock carbs that are jetted for duals. I think they make them in 500 and 600. I have a set of the dual 500 Edelbrocks for the dyno room that we've used on a ton of engines over the years. Those carbs always work great regardless of what they go on. Blower motors, tunnel rams, cross rams, etc. A pair of them will easily handle 700+ hp and they don't cost much to buy.
Re: Covid-572: Pandhemi [Re: AndyF] #2773155
05/10/20 12:02 PM
05/10/20 12:02 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Now you've done it!
You have me contemplating the Hemi lifestyle! work
'63 Dodge 330
11.19 @ 121 mph
Re: Covid-572: Pandhemi [Re: ZIPPY] #2773167
05/10/20 12:30 PM
05/10/20 12:30 PM
central il.
second 70 Offline
second 70  Offline
central il.
Rich you need some quick disconnects on your fuel lines like my friends mild vette. Lol Mike
83962929_10213456034510402_5779044819376537600_o.jpg84881234_10213456029750283_1298965626919845888_o.jpg
Re: Covid-572: Pandhemi [Re: AndyF] #2773169
05/10/20 12:34 PM
05/10/20 12:34 PM
Dragula Offline
Dragula  Offline
Not to be a PITA, but dual 500-600 eddy carbs on a 572 will make things worse. Right from edlebrock the 500cfm rated carb flows a little over 350cfm....
We run dual eddy 800 Thunder series....They were very close OOTB on a 572 Hemi....
Re: Covid-572: Pandhemi [Re: GY3] #2773249
05/10/20 05:12 PM
05/10/20 05:12 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Originally Posted by GY3
Now you've done it!
Mark I came up with a couple little ideas (nothing earth shattering) to help spread the cost out which made a noticeable difference. If you need a push, sometimes stuff like that can help. Feel free to PM, or FB Messenger, or call. But if you call pls use the actual phone...not that goofy messenger thing.
Randy and Andy, thanks to you both for the input even though it may not agree 100%. Opinions are welcome.
Randy I know you've played with them for years and have done some street driving, so I def. see the value in what you have to say. I think I would want at least 750s as an end setup.
I do have three or four Edelbrock 600s kicking around here, and that could potentially be the baby/starter kit setup for the Tunnel Ram. Two of them are already rebuilt and tested to be working well on an old big block. So I could slap those on just to start somewhere.
burning question:
I already have one newer "950" carb on hand (1.450/1.75, probably doesn't even flow 900).
I could buy a second matching carb.
Could be an eventual big dog (for me anyway) setup for the Weiand.
Are two of those "950"'s on the Weiand tunnel ram too much?
It doesn't seem so, but I have no clue.
Rich H.
Esse Quam Videri
Re: Covid-572: Pandhemi [Re: ZIPPY] #2773298
05/10/20 07:48 PM
05/10/20 07:48 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
HEMI.... for lazy mans choice for spark plug swaps! Great looking mill Zip! I’m afraid I’ll go to the grave not have owned that awesome wideness!
Re: Covid-572: Pandhemi [Re: ZIPPY] #2773330
05/10/20 09:05 PM
05/10/20 09:05 PM
Mt. Eden Ky.
Hemi Allstate Online content
Hemi Allstate  Online Content
Mt. Eden Ky.
It's looking good Rich !
I like the picture with the GTX in the background best.
I have run my 572 with the same intake you have and a Race Demon RS 950 anular converted to 1050 down leg booster. I have about 15 passes on the car. All but one pass on the strip was done with that manifold and carb. I switched to 426-3 and a Gen III Ultra Dominator and I don't have a good pass on that set up to date. I tried an OTB baseline pass and it was way too rich . I do have some street miles with the Dominator and I like it now after I did some mods to it. I still need to change the linkage to slow the secondaries opening. Things get real exciting when you try to ease into the throttle passed a certain point.
I am really happy with my 572" and I bet you will be too !
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Covid-572: Pandhemi [Re: Hemi Allstate] #2773531
05/11/20 01:57 PM
05/11/20 01:57 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thanks for the support!
Need to get started on a list of next steps for the GTX.
Rich H.
Esse Quam Videri
Re: Covid-572: Pandhemi [Re: ZIPPY] #2773532
05/11/20 01:58 PM
05/11/20 01:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Looks good...
Re: Covid-572: Pandhemi [Re: Al_Alguire] #2773782
05/12/20 09:01 AM
05/12/20 09:01 AM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Thx Al.
Your standards have historically been pretty high, so thanks for the acknowledgement.
I'm trying to move up a level or three in that department.
Rich H.
Esse Quam Videri
