4500 on a 4150 intake?
#2772864
05/09/20 12:44 PM
05/09/20 12:44 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
Anyone know if the flange is big enough on a trick flow or victor low deck intake to accept a 4500 carb if I fill the holes and re-tap it?
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
Re: 4500 on a 4150 intake?
[Re: 68 HEMI GTS]
#2772873
05/09/20 01:33 PM
05/09/20 01:33 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Just lay a 4500 gasket on it and run a sharpie around the inside of it and see how it looks.
[Re: fast68plymouth]
#2772878
05/09/20 01:38 PM
05/09/20 01:38 PM
68 HEMI GTS
Temperance, MI
Yeah, I don’t have one. Was hoping to find the answer before I ordered one up.
[Re: 68 HEMI GTS]
#2772879
05/09/20 01:41 PM
05/09/20 01:41 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Can you run a 4150/4500 spacer or are you fighting hood clearance? Can you weld aluminum? Because...on the 383 Victor the bolt holes on the 4500 are very close to the edge of the casting. Besides that.....the 4150/4500 bolt holes overlap. Correction......there is sufficient sealing surface after opening the the mounting area to 4500 throttle bore size. It's just the bolt holes will be very close to the edge of the casting and may break out.
[Re: LaRoy Engines]
#2772881
05/09/20 01:47 PM
05/09/20 01:47 PM
68 HEMI GTS
Temperance, MI
Ok, yeah hood clearance is an issue. I run a tm6 currently with a 2” adaptor. I wouldn’t mind trying a modern intake but i won’t have the room to run an adaptor.
[Re: 68 HEMI GTS]
#2772883
05/09/20 01:58 PM
05/09/20 01:58 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Ok, yeah hood clearance is an issue. I run a tm6 currently with a 2” adaptor. I wouldn’t mind trying a modern intake but i won’t have the room to run an adaptor. I see, make sure you see the correction on my previous post.
[Re: 68 HEMI GTS]
#2772892
05/09/20 02:38 PM
05/09/20 02:38 PM
fast68plymouth
So. Burlington, Vt.
Jim, didn’t you “do” one of the victors like that? 4150 to 4500?
I thought I saw you guys do something like that but I don’t recall if it was a BB or SB.
#2772914
05/09/20 03:47 PM
05/09/20 03:47 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
I thought I saw you guys do something like that but I don’t recall if it was a BB or SB. We did it to a 383 Victor. But we used a 4150/4500 4-into-1, 2" HVH spacer and opened the intake manifold carburetor mounting flange to very nearly 4500 throttle bore size and matched the 4150 side of the 2" spacer to the intake manifold. I keep holding on to it in hopes of someday running it on a standard port sized 400 based stroker. I sold the Indy Dominator single plane and the 2" spacer we used for 787 HP on the pump gas 451, so this 383 Victor is my next best bet.
[Re: AndyF]
#2772940
05/09/20 05:37 PM
05/09/20 05:37 PM
68 HEMI GTS
Temperance, MI
Andy, I thought without major porting the M1 was poor?
[Re: 68 HEMI GTS]
#2772965
05/09/20 06:54 PM
05/09/20 06:54 PM
fast68plymouth
So. Burlington, Vt.
One thing to keep in mind with the Victor or TF intake is, they don’t have the carb pad angle “corrected”. So in a typical door car where the engine is tipped back.......with carb pad corrected the carb sits level.
With the uncorrected carb pad, the carb will be angled/tipped back..... parallel to the crankshaft.
This can impact how the air filter/hood clearance situation plays out.
In 1990, before there were any 4500 std port intakes available(if there were any, I wasn’t aware of them), I built one out of a Holley SD.
#2772975
05/09/20 07:34 PM
05/09/20 07:34 PM
68 HEMI GTS
Temperance, MI
In 1990, before there were any 4500 std port intakes available(if there were any, I wasn’t aware of them), I built one out of a Holley SD. Nice looking work Dwayne, how well did it work?
[Re: 68 HEMI GTS]
#2772976
05/09/20 07:36 PM
05/09/20 07:36 PM
Posts: 31,025 Oregon
AndyF
Andy, I thought without major porting the M1 was poor? The M1 isn't a great intake but the M1 4500 works really well. (If the engine needs it) Very few people have any experience with the M1 4500 since it just wasn't a very popular intake. It should be perfect for you application though since a Dominator carb will bolt on plus it is fairly low profile. The only challenge will be to find one. The real question is what does your engine need. A Trick Flow intake with a 1050 size 4150 might make more power on your engine than a Dominator on a M1 4500. Nobody knows the answer until you test it since it depends on a complex relationship between engine size, camshaft design and cylinder flow. I did a lot of testing with my low deck 470 engine and eventually picked up about 100 hp over my first test results but I had to try multiple cams, intakes, carbs, etc. Nobody knew what the recipe was and much of the advice I got along the way was wrong.
[Re: 68 HEMI GTS]
#2772991
05/09/20 09:05 PM
05/09/20 09:05 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
Ok Andy, I thought without major porting the M1 was poor? I believe there was a LD M1 for the 4500 listed either on moparts or forbbodiesonly. I put one on my wagon and it worked real well. I plan on doing some minor blending and clean up and I'm sure it will be even better.
Ok
[Re: 68 HEMI GTS]
#2773087
05/10/20 09:03 AM
05/10/20 09:03 AM
Posts: 16,925 NC
440Jim
NC
Ok, yeah hood clearance is an issue. I run a tm6 currently with a 2” adaptor. I wouldn’t mind trying a modern intake but i won’t have the room to run an adaptor. Buy that low deck M1 4500 for $300, good deal in my opinion for that intake. You might even have room for a 1/2" or 1" spacer, and I think those will help too. A 1" tapered 4-hole spacer typically works well. Back around 2003, I welded the inner runners of a low deck TM-6 to port out the notches, and that thing flowed great on the flow bench. Those notches suck... It was a 4150 intake, and I ran a 2" 4500 adapter.
[Re: 440Jim]
#2773091
05/10/20 09:10 AM
05/10/20 09:10 AM
68 HEMI GTS
Temperance, MI
Ok, yeah hood clearance is an issue. I run a tm6 currently with a 2” adaptor. I wouldn’t mind trying a modern intake but i won’t have the room to run an adaptor. Buy that low deck M1 4500 for $300, good deal in my opinion for that intake. You might even have room for a 1/2" or 1" spacer, and I think those will help too. A 1" tapered 4-hole spacer typically works well. Back around 2003, I welded the inner runners of a low deck TM-6 to port out the notches, and that thing flowed great on the flow bench. Those notches suck... It was a 4150 intake, and I ran a 2" 4500 adapter. I was thinking about welding the notches. The TM6 runs good with the dominator. I was just looking for a little more. I sent the guy a pm on the M1 yesterday.
[Re: 68 HEMI GTS]
#2773109
05/10/20 10:11 AM
05/10/20 10:11 AM
Posts: 1,030 ohio
67mprfan
ohio
Wilson makes a 1 inch 4500/4150 adapter if that would help with hood clearance
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2773114
05/10/20 10:21 AM
05/10/20 10:21 AM
fast68plymouth
So. Burlington, Vt.
Maybe 17-18 years ago I had a pump gas 493 on the dyno with a roller cam and std port SR heads (mild porting by MM.....about 300cfm). I tested a std M1 with a spacer and my good ported 850 annular, and a 1050/4500 on a 2” adapter, and then swapped the intake for a M1/4500 with no spacers. I’d have to see if I could dig out the sheets, but my recollection is there wasn’t much difference in power between the 3 tests...... maybe like 7-10hp. That motor was in the 660-670hp range. There are some manifold tests in this old archived thread(along with a pic of the “Holley SD-4500” before I cut a bunch of extra “stuff” off it). http://www.moparts.org/Tech/Archive/bb/8.html
