Master cylinder problem #2773022
05/09/20 11:01 PM
05/09/20 11:01 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
My brake fluid is draining from the small reservoir and overfilling the rear reservoir,after driving it ..Its the 2 or 3 rd one doing it,,,proportioning valve bad??????thanks in advance.
Re: Master cylinder problem [Re: 70RR383] #2773027
05/09/20 11:41 PM
05/09/20 11:41 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Sounds like its bypassing internally and that happens when the master is bad
Re: Master cylinder problem [Re: stumpy] #2773666
05/11/20 08:23 PM
05/11/20 08:23 PM
St.Louis,Mo.
70RR383 Offline OP
70RR383  Offline OP
St.Louis,Mo.
Thanks for the advice STUMPY,I guess since I am not on here much anymore,no one will chime in....
Re: Master cylinder problem [Re: 70RR383] #2773673
05/11/20 08:45 PM
05/11/20 08:45 PM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
No this is a very unusal problem, I've been fixing cars for over 30 yrs and never seen this. No idea why it might happen good thing brake parts are generally cheap.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Master cylinder problem [Re: HemiRick] #2773759
05/12/20 07:06 AM
05/12/20 07:06 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
I'm experiencing this problem on my 92 pickup too. The original master did it and a new, not rebuild, master is doing it too. My 77 pickup with the same master does not do it.
Trucks have identical brakes except the 77 has a adjustable p valve. Im suspicious that the 92 p valve is allowing the bypass.
Im thinking of eliminating the p valve on the 92.
Angry white pureblood male
Re: Master cylinder problem [Re: 70RR383] #2775048
05/16/20 09:27 AM
05/16/20 09:27 AM
Motor City
JTECDN Offline
JTECDN  Offline
Motor City
If you have power brakes I would check that the output shaft from the booster isn't adjusted slightly too long which isn't allowing the MC piston to travel completely back to zero. When that happens the MC does crazy things. There should be a VERY small amount of dead travel before the booster pushes the piston
Re: Master cylinder problem [Re: JTECDN] #2775305
05/17/20 06:39 AM
05/17/20 06:39 AM
VA
dragon slayer Offline
VA
It would help if you identified the car/brake system. Old type, vice a modern car with antilock brakes etc... Not enough info to even start helping you.
