Covid-572: Pandhemi
#2772790
05/09/20 10:51 AM
05/09/20 10:51 AM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
Good morning Ladies and Germs.....
Today, for your viewing pleasure.....
I give you the Covid-572: Pandhemi.
Born on 4-26-20
(Painted and all that sometime afterward whenever it was I got around to it)
Not really. I'm not too into the process of "naming everything" like that but maybe this name will stick? Ah, who knows.
Been a fun project.
Rich H.
Esse Quam Videri
Re: Covid-572: Pandhemi
[Re: GY3]
#2772809
05/09/20 11:19 AM
05/09/20 11:19 AM
ZIPPY
S.E. Michigan
Thank you Mark! Have I mentioned it is stock appearing ? (.....in this one spot, where the white plastic things go) If I’m getting too technical let me know 😂
Rich H.
Esse Quam Videri
[Re: 340Cuda]
#2772852
05/09/20 12:28 PM
05/09/20 12:28 PM
ZIPPY
S.E. Michigan
Congratulations to the proud father! Medium Daddy says thank you very much
Rich H.
Esse Quam Videri
[Re: topside]
#2772855
05/09/20 12:30 PM
05/09/20 12:30 PM
ZIPPY
S.E. Michigan
and I like the name, that's clever. Thank you... I probably binge watched one too many Motor Trend on Demand shows during this whole deal, which led to the whole naming thing.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2772865
05/09/20 12:49 PM
05/09/20 12:49 PM
Posts: 20,189 PA.
pittsburghracer
"Little"John
"Little"John
PA.
He either has a twin or someone stole your idea in the other 572 post. LOL. It's an identical twin.
[Re: pittsburghracer]
#2772871
05/09/20 01:19 PM
05/09/20 01:19 PM
ZIPPY
S.E. Michigan
He either has a twin or someone stole your idea in the other 572 post. LOL. It's an identical twin. I probably overdid it with the posts here but will stop soon. It's so slow around this place, it's kinda sad.... but it's like that all over except social media.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2772886
05/09/20 02:05 PM
05/09/20 02:05 PM
Posts: 20,189 PA.
pittsburghracer
"Little"John
"Little"John
PA.
He either has a twin or someone stole your idea in the other 572 post. LOL. It's an identical twin. I probably overdid it with the posts here but will stop soon. It's so slow around this place, it's kinda sad.... but it's like that all over except social media. I think we need to put the pedal to the metal to remember how great that feels. 6 months and counting for me since the Halloween Classic at Norwalk.
[Re: ZIPPY]
#2772897
05/09/20 03:03 PM
05/09/20 03:03 PM
Posts: 31,052 Oregon
AndyF
Born on 4-26-20
Been a fun project.
Looks good. Do the pulleys all line up at this point or do you need to move the alternator out to line up with the water pump? Looks like you have the correct throttle bracket and return setup, you'll need a long throttle cable to reach up to that intake! The coil mount location looks good. What else do you need to sort out before it is ready to go into the car? Is the fuel system ready for that engine? Where will the adjuster strap for the alternator go? Over to the engine or run it the other way to the frame?
[Re: AndyF]
#2772910
05/09/20 03:36 PM
05/09/20 03:36 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Looks good Zippy! I finally own my first Hemi too, they are not real fun to work on but definitely fun to drive.
[Re: ProSport]
#2772925
05/09/20 04:44 PM
05/09/20 04:44 PM
Posts: 7,496 Minnesota
Hemi_Joel
Minnesota
Looks awesome Zippy! Is it going on the dyno?
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
#2772930
05/09/20 05:06 PM
05/09/20 05:06 PM
ZIPPY
S.E. Michigan
He either has a twin or someone stole your idea in the other 572 post. LOL. It's an identical twin. I probably overdid it with the posts here but will stop soon. It's so slow around this place, it's kinda sad.... but it's like that all over except social media. I think we need to put the pedal to the metal to remember how great that feels. 6 months and counting for me since the Halloween Classic at Norwalk. Well, yeah that would help! I'm sure not any sort of hardcore racer but I do enjoy testing and going at it once in awhile. A year ago for me May 5th. What would really do me a whole lot of good is to do an entire day of nothing but 60 foot, adjust shocks and try to learn something about suspension, as I feel I know next to nothing at the moment. Can't do that, so time to start changing things and make sure I confuse myself as much as possible....
Rich H.
Esse Quam Videri
[Re: AndyF]
#2772934
05/09/20 05:25 PM
05/09/20 05:25 PM
ZIPPY
S.E. Michigan
Born on 4-26-20
Been a fun project.
Looks good. Do the pulleys all line up at this point or do you need to move the alternator out to line up with the water pump? Looks like you have the correct throttle bracket and return setup, you'll need a long throttle cable to reach up to that intake! The coil mount location looks good. What else do you need to sort out before it is ready to go into the car? Is the fuel system ready for that engine? Where will the adjuster strap for the alternator go? Over to the engine or run it the other way to the frame? Hey thanks. Adjuster strap will go down to the K member (Weld a small 3/8 ID tube, run a bolt through it and attach the strap). The alternator fits well but the bracket should be 1.040" thicker for it to line up, so I made a spacer to use in that location + drilled the tapped hole on the bracket out for 3/8" through bolt so I could use both "ears" on the alternator. I got the pulleys to line up within 1/32" using the motor plate as a datum line, after a little lathe work. Hopefully the motor plate isn't too difficult to live with for limited street use...I will find out. I do need to repair or replace that Demon carb shown in the pic, as somehow I managed to warp the secondary metering block a couple years ago. Will probably buy a pair of replacements from BLP. Picked up a QFT 950 and have been using that for awhile....but it is too small for even the 451 per track testing, so I don't want to use it on the 572 unless I swap the main body for something larger (I actually have one on the shelf I forgot I had, and might go down that road). I have a pretty overkill fuel system, 250gph pump, it's older, need to test it and make it all fit the car a little better than it does currently. The car itself needs more prep than anything else at this point. I do want to replace and repair some sheetmetal and have started doing some of that while waiting for engine parts. This is a baby step forward towards the RBRE/MP single plane and/or the tunnel ram later on. I know I need to experiment a little or I'll get bored.
Rich H.
Esse Quam Videri
[Re: ProSport]
#2772936
05/09/20 05:29 PM
05/09/20 05:29 PM
ZIPPY
S.E. Michigan
Looks good Zippy! I finally own my first Hemi too, they are not real fun to work on but definitely fun to drive. Congrats to you too PS! Thanks!
Rich H.
Esse Quam Videri
