Page 2 of 3 1 2 3
Re: To cold spark plugs? [Re: lewtot184] #2772691
05/09/20 02:37 AM
05/09/20 02:37 AM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
Originally Posted by lewtot184
[quote=Mopar493][quote=lewtot184][quote=Mopar493][quote=lewtot184i know Don at FBO likes full manifold vacuum for the vacuum advance, I don't; unless the vacuum is so low you need the extra advance at low rpm. I wouldn't do that with as high of vacuum as your engine is making. I bet that engine is making a bunch of low to mid rpm cylinder pressure with that cam closing the intake valve so early and this could lead to some detonation. don't be afraid to try the timed port. those vacuum units are adjustable.
Yes he told me to use it, i did a compression test and it shows 200 psi on all 8,i test in 4 pulses on every cylinder and the gauge swings up to 150 psi on the first pulse. The cam close the intake valve 64 degrees after BDC so its pretty mild for the cui's. I have not heard any pinging so far or not seen any signs of it on the piston tops but i have only drive it with the msd pro billet distributor set at 16 initial and full advance at 3000rpm and 34 degrees, so i dont know yet how it respond to vacuum advance, i have to test it some and see
it's not rocket science just be patient and don't put your head in a box. 200psi is high for pump gas so you may have to walk a fine line to stay out of detonation. I use the mopar distributors in both my cars and I do mimic mopars centrifugal curve set-ups for street along with the vacuum advance. I went thru a bunch of different configurations to come up with something I liked.
Thanks for your answer
Re: To cold spark plugs? [Re: calrobb2000] #2772692
05/09/20 02:39 AM
05/09/20 02:39 AM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
Originally Posted by calrobb2000
hi
what is the thermostat and engine temp ?
were they long or short trips ?
The engine run pretty cold, it never go over 180F, its short trips and before i take out this plugs(the day after) it have stand on idle for about 5-10 minutes when i check vacuum and ignition timing.
Re: To cold spark plugs? [Re: BSB67] #2772694
05/09/20 02:44 AM
05/09/20 02:44 AM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
......... the engine runs great but slight misses on idle, the engine have about 400 miles on it since cam break in.
You cannot learn anything by reading plugs from a motor that has a miss at idle. They will look like want you have, and it could be a lean miss.
Thank you
Re: To cold spark plugs? [Re: Cab_Burge] #2772708
05/09/20 07:05 AM
05/09/20 07:05 AM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
Originally Posted by Cab_Burge
If it shines it, the spark plug inside the combustion chamber, is oil, if it doesn't shine it has no oil shruggy
It looks like oil to me shruggy
Hi i tried with hotter projected tip plugs, ngk 6, one step hotter. No shining but rich maybe
Re: To cold spark plugs? [Re: Mopar493] #2772710
05/09/20 07:09 AM
05/09/20 07:09 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
I think your going in the right direction with a little warmer plug with a projected tip. the dry carbon is a rich condition. when you install the vacuum advance it will help clean-up the cruise a/f mix some. what carb/manifold and jetting are you using? you might take a magic marker and draw a line on the length of the plug where the clean spot on the rim of the plug is. try to see if that line lines up with the intake valve location.
Re: To cold spark plugs? [Re: Mopar493] #2772725
05/09/20 07:52 AM
05/09/20 07:52 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
My little 383/432 Stroker
Same cam as you
NGK 6
Angled Plug E Street 75cc Heads = 10.5 Compression - Same 200psi cold cranking on all eight
16 initial / 18 mechanical = 34
Factory HP Manifolds
Box Stock Edelbrock AVS 2 800 Brand new that I installed last year
Idle is perfect - Off idle perfect - 12" vacuum
However I just ordered some metering rods , plugs look a little rich
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: To cold spark plugs? [Re: lewtot184] #2772731
05/09/20 08:20 AM
05/09/20 08:20 AM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
Hi, im using a Edelbrock avs2 800cfm, primary jet 104 and secondary 104, i go one step leaner with the needle from factory. Ok and whats the case if that clean spot line up with the intake valve?
Re: To cold spark plugs? [Re: bee1971] #2772733
05/09/20 08:30 AM
05/09/20 08:30 AM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
Same cam as you
NGK 6
Hi, nice set up. I have about 17-18 inch of vacuum on idle but also more cubes. It idles fine but when it stands on idle for a few minutes it starts to miss slightly, i dont really know why, i can see with the stroboscope light that the mark moves slightly when it miss. The mark is steady but it moves a few degrees off and on like that, it also showes up on the vacuum gauge when it miss it dops 1 inch, its not a steady miss but little now and than when it idles for ahwile.
Re: To cold spark plugs? [Re: Mopar493] #2772742
05/09/20 09:08 AM
05/09/20 09:08 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You might consider using a ColorTune to see what's going on. It will tell you if you are rich or lean and if you run it on each cylinder you can see which one is misfiring.
Re: To cold spark plugs? [Re: Sniper] #2772757
05/09/20 09:28 AM
05/09/20 09:28 AM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
Thanks for the tip
Re: To cold spark plugs? [Re: Mopar493] #2772823
05/09/20 11:34 AM
05/09/20 11:34 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the clean spot is probably the intake wash. if you can take your finger and wipe it off clean then there may be some oil (the detergency in the oil will clean the rim up). if it's dry or gummy then it's the gas. it's just a simple check. I think your ok but sometimes you can't look at enough stuff. I wouldn't change that primary jet. maybe one step leaner on the cruise side of the metering rod, or perhaps the best thing to do is nothing until you've tried the vacuum advance out.
Re: To cold spark plugs? [Re: lewtot184] #2772825
05/09/20 11:38 AM
05/09/20 11:38 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
another thing is the idle jet. I haven't played with a 800avs 2 but I have played with the regular 800 avs and they do have a large, .040", idle jet. might play with the mixture screws a little.
Re: To cold spark plugs? [Re: lewtot184] #2772840
05/09/20 12:14 PM
05/09/20 12:14 PM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
Ok thanks! I will try it, im not loosing any oil that i can see on the dipstick so it would be surpricing if there is any on the plugs. I get the engine started today with the FBO distributor but the engine running no good with it, its blueprinted with 15 degrees vacuum advance at 15 hg/inch, i have 17 hg at idle but there was no advance at all so something is wrong with it. The engine go worse when i disconnected the vacuum hose but it not show any advance from vacuum when i check with timing light, i installed it at 16 degrees and with the light it shows 16, anyway somethings not right with it so i switched back to the msd pro billet.
Re: To cold spark plugs? [Re: Mopar493] #2772858
05/09/20 12:31 PM
05/09/20 12:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
Try adjusting the idle mixture screws with the motor warmed up or hot and adjust them in, one at a time, until it starts to slow down a tiny bit and back it out 1/8 turn richer and then go drive it normally for 10 to 20 miles and pull one plug and post a picture of that plug on here.
The reason I'm asking you to do this is to see if the idle mixture is to rich or the part throttle mixture is to rich scope
When it starts to miss at idle speed it is talking to you, it is either to rich drowning out that cylinder or to lean, maybe a vacuum leak work
Good luck, stick with us, we will help you make it better up
What intake manifold are you running?
Re: To cold spark plugs? [Re: Cab_Burge] #2772870
05/09/20 01:12 PM
05/09/20 01:12 PM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
Thank you! I will try that out and take a pic to show you here as soon as i can. I running a Edelbrock rpm dual plane manifold. I really appreciate all the help i get, thank you all.
Re: To cold spark plugs? [Re: Mopar493] #2772908
05/09/20 03:34 PM
05/09/20 03:34 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
there shouldn't be any advance at idle when using the timed port. manifold vacuum should pull it in but i'm afraid that may be too much. difficult to diagnose not knowing how the distributor was put together. as far as the carb idle mixture goes; carter says to adjust the mixture screws to the best idle/vacuum and then turn them in until the engine looses 25-50rpm. sometimes this works ok and sometimes not.
Re: To cold spark plugs? [Re: lewtot184] #2773062
05/10/20 03:35 AM
05/10/20 03:35 AM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
Thanks i will try to adjust the carb. The Fbo distributor is a blueprinted original Mopar distributor with restricted mechanical advance 18 degress and restricted vacuum advance 14 degress that should start to pull vacuum at 15 hg/inch, it came with msd conversion cable. I connected the vacuum to manifold vacuum but nothing. I tried to adjust the canister but it is locked in some way, so the distributor not working as adverticed
Re: To cold spark plugs? [Re: Mopar493] #2773130
05/10/20 11:06 AM
05/10/20 11:06 AM
Washington
madscientist Offline
Washington
Your tune up is rich everywhere. I agree with the above about using manifold vacuum rather that ported vacuum for what you are doing. You don’t have nearly enough cam to require manifold vacuum at idle. That’s straight crazy.
If the distributor is curved correctly you don’t need (or want) full manifold vacuum adding timing at idle. Did FBO send you a sheet documenting the curve used, or did he just slam something together and send it out the door?
Either way, no way am I using manifold vacuum on the vacuum can for what you have. Second, you need at least 1 range hotter plug and you need to take some fuel away everywhere.
Re: To cold spark plugs? [Re: madscientist] #2773139
05/10/20 11:40 AM
05/10/20 11:40 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
the more I think about this engine the more I think any kind of performance ignition curve is a waste. your engine, in my opinion, is more efficient than a stocker with that high vacuum. I have a stock 440 I run around in and it's not as efficient as yours. i'd 'bet it's doing well over 20"hg vacuum at cruise speed; maybe 22-24",...? i'd try a curve very similar to the original mopar performance electronic distributors. I think that would be a good baseline and go from there. hopefully your not using a loose torque converter (if this is an automatic transmission) or low rear gears (numerically high).
Re: To cold spark plugs? [Re: madscientist] #2773168
05/10/20 12:30 PM
05/10/20 12:30 PM
Sweden
Mopar493 Offline OP
Mopar493  Offline OP
Sweden
[quote=lewtot184][quote=Mopar493][quote=lewtot184][quote=Mopar493][quote=lewtot184]
Thanks for your answer! I will lean the carb, it looks pretty rich. I did go down from Ngk 7 to Ngk 6, its Ngk 6 in this pic but its to cold too? Right now i dont any vacuum advance at all, im running a Msd pro billet, i wanted to run the FBO distributor but its not working as adverticed, he sent with a cheat how i need to install it, 16 initial, full manifold vacuum bring it up to 30 at idle at 15hg/inch and full mechanical 34 at 3200rpm but like i say its not working properly, the vacuum canister not advance anything and i have 18hg/inch at idle, something is wrong with it, the engine not running good with the FBO distributor with or without vacuum connected so i put the pro billet in instead.
Page 2 of 3 1 2 3
