Welding stock block
#2771948
05/06/20 10:42 PM
05/06/20 10:42 PM
Posts: 5,618 long island NY
Ari440
long island NY
Hello
I put together a B-1 combo and is using a stock 440 block
Just as I was going to drop the distributer in I found a crack on the front lifer bore
A machine shop told me they can fix it by putting a bar across the lifter valley and have it welded up
I have about $1.500 worth of machine work into this block
1975 440 block half fill, billet main caps , cam is 800/284 at @50
Seems this is a lot of side load and it cracked across the bore
Anyone do anything like this to a stock block
1.39 9.85 - 137 mph
Re: Welding stock block
[Re: Ari440]
#2771977
05/07/20 01:28 AM
05/07/20 01:28 AM
Posts: 43,173 Bend,OR USA
Cab_Burge
Me thinks your fooling with faith starting with a bad block, I wouldn't do that Do you want to have this one fail at or above 100 MPH with you in the car Time to think about a new race block, aluminum or cast iron
[Re: dthemi]
#2772024
05/07/20 09:36 AM
05/07/20 09:36 AM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Nobody wants to throw away $1,500 but you have a lot more than that in the engine. And if it blows it's going to take out a lot of good parts. Do what you don't want to do. Throw that POS away and find another block. My 2 cents.
2011 Drag Pak Challenger
[Re: camastomcat]
#2772053
05/07/20 10:41 AM
05/07/20 10:41 AM
Posts: 1,839 NW Indiana
fbs63
NW Indiana
Make a coffee table out of it or use it for mock up. B1's are too much power for a stock block. This. Save your money and get an aftermarket block. Its GOING to break again. The engine is telling you its too much strain.
[Re: Ari440]
#2772077
05/07/20 11:59 AM
05/07/20 11:59 AM
Cab_Burge
I've had 3 RB blocks that had cracks in the main webbing from racing them, luckily none of them hurt me when they fialed If you absolutely wanted to fix and use that block on another less powerful combination you could have the crack ground out and welded and then bush the lifters bores to make the block usable agian Be safe, don't take chances
[Re: fourgearsavoy]
#2772095
05/07/20 12:56 PM
05/07/20 12:56 PM
Posts: 17,844 S.E. Michigan
ZIPPY
S.E. Michigan
Ari can you post a picture of the damage?
I like the idea of repairing it and using it, but more for a street/fun car kind of a build with regular port heads.... Not for anything with B1s.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2772182
05/07/20 05:48 PM
05/07/20 05:48 PM
Ari440
long island NY
Thank you for the reply,s everyone
I'm afraid if I do an other block will this be a problem again
The motor hasn't started yet
Big cam duration put alot of stress on it
This is #1 cylinder on the exhaust bore there is no support there
It's next to the oilpump gear drive
Can't post a pic on here but it you like on Facebook look up Ari Kostopoulos
Maybe some one can post it here
Can't afford a after market block maybe best to sell the B-1s
Just want to see if anyone else has this problem
Thank you 😊
1.39 9.85 - 137 mph
[Re: Ari440]
#2772191
05/07/20 06:20 PM
05/07/20 06:20 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thank you 😊
[Re: Ari440]
#2772204
05/07/20 07:09 PM
05/07/20 07:09 PM
Posts: 3,831 N.E. Ohio
6bblFLASH
N.E. Ohio
Are you sure that is a crack? Looks more like a casting flaw.??? Mine has several places that look like that. Hasn't been a problem yet.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2772218
05/07/20 07:50 PM
05/07/20 07:50 PM
Ari440
long island NY
Are you sure that is a crack? Looks more like a casting flaw.??? Mine has several places that look like that. Hasn't been a problem yet. I cranked the motor over hole got bigger and oil coming out of it Primed the motor too oil cam out of it too
1.39 9.85 - 137 mph
[Re: Ari440]
#2772256
05/07/20 09:19 PM
05/07/20 09:19 PM
6bblFLASH
N.E. Ohio
Are you sure that is a crack? Looks more like a casting flaw.??? Mine has several places that look like that. Hasn't been a problem yet. I cranked the motor over hole got bigger and oil coming out of it Primed the motor too oil cam out of it too Oh. I see...crap.😕 Stitches would seal it. But that's for the machinist to decide. Sorry bud.🤞
[Re: 6bblFLASH]
#2772259
05/07/20 09:36 PM
05/07/20 09:36 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Ari Sorry to hear about this, man! What is the difference in spring pressure from this cam/springs to the other motor you ran with Indy heads? That was a big cam with high pressures also, right? Just trying to reason if the block was weak in that area or spring pressure is just too high for stock lifter bores.
[Re: Ari440]
#2772292
05/07/20 10:59 PM
05/07/20 10:59 PM
Posts: 2,499 PA
moparacer
PA
Hello
Anyone do anything like this to a stock block Also interested in hearing how much spring pressure you are running. The exhaust lifter really shouldn't have much side load on it I think?
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
