1970 E-body, I think the hazard flasher switch is on there too.
Who has a good repro, or is OE going to be a better bet ?
Or..........Does someone specialize in fixing these ?
Yes, I do restore the two different 70 style turn signal switches. On my JS Restorations thread on the Hot Deals and New Products folder, on my post dated 5.18.15 shows the restoration of a 2947905 E body switch if you would like to see the pictures from receiving this part to restored.
I did write at the beginning of these pictures the following statement that describes the differences between the E body only style and B and other body parts. Completely different parts:
"This is the restoration of a 70 only E body 2947905 turn signal switch. One unique marking on this switch is the position of the arrow on the knob. To turn on the four way flashers, you needed to pull the knob out away from the column, the triangle points away from the column, too. The 70 only B body 2947509 and the C body 2947503 turn signal triangles points toward the steering column and needed pushed in to turn on the four way flashers. The terminal wiring is reversed to accommodate the difference of pulling out or pushing in to activate."
