Re: Thoughts on adjustable strut rods?
[Re: justinp61]
#2771765
05/06/20 11:11 AM
05/06/20 11:11 AM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
If your front end can freely travel at least 5 inches (gleened from Caltrac tech), the adjustable strut rods will have little or no effect on that. They do benefit the suspensions ability to increase the positive caster by pulling the lower control arm farther forward in relation to the upper control arm. You must be careful not to bring the lower control arm into a bind as it moves through its travel however.
The old Mopar suspension manual has a lot of tried and tested information in it that is still applicable today.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: justinp61]
#2771780
05/06/20 12:00 PM
05/06/20 12:00 PM
Thumperdart
State of confusion
Both mods helped me to a 1.33 foot-brakin 60 foot so far so yes on both imo....
[Re: Thumperdart]
#2771782
05/06/20 12:03 PM
05/06/20 12:03 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Both mods helped me to a 1.33 foot-brakin 60 foot so far so yes on both imo.... Who's rods?
[Re: Thumperdart]
#2771796
05/06/20 12:33 PM
05/06/20 12:33 PM
Posts: 630 Ct
Wirenut
Ct
Both mods helped me to a 1.33 foot-brakin 60 foot so far so yes on both imo.... What was your 60’ before those mods ?
[Re: justinp61]
#2771824
05/06/20 01:59 PM
05/06/20 01:59 PM
Posts: 608 TN
1DGEMAN
TN
Caltracs now makes adjustable strut rods. A good friend put them on his Stock and Super/Stock Dusters.
Real Men shift for themselves
[Re: 1DGEMAN]
#2771828
05/06/20 02:25 PM
05/06/20 02:25 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
I HAVE A BRAND NEW SET OF THOSE QA1 STILL IN BOX I NEVER USED. SOLD MY CAR. I'LL SELL THEM FOR 200.00 SHIPPED.
JAKES AUTOMOTIVE
[Re: JAKE68]
#2771831
05/06/20 02:36 PM
05/06/20 02:36 PM
justinp61
W. Kentucky
I HAVE A BRAND NEW SET OF THOSE QA1 STILL IN BOX I NEVER USED. SOLD MY CAR. I'LL SELL THEM FOR 200.00 SHIPPED. You have a PM.
[Re: Ody1003]
#2771863
05/06/20 05:13 PM
05/06/20 05:13 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Question. QA1 strut rods in B-body. Has anyone tried to install these without removing torsion bars etc. By cutting the OEM strut rod out and being able to install the after market QA1? I understand that it can be done? Input. Thanks. Cut my old ones out with a Sawzall and put the new ones in but mine are the RMS units. I didn't have to remove anything else for the install. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 1DGEMAN]
#2771866
05/06/20 05:17 PM
05/06/20 05:17 PM
Posts: 103 Minnesota
TrackPack
Minnesota
Caltracs now makes adjustable strut rods. A good friend put them on his Stock and Super/Stock Dusters. Do you have a link for them? I couldn't find them on the Calvert Racing site.
[Re: TrackPack]
#2771874
05/06/20 06:17 PM
05/06/20 06:17 PM
justinp61
W. Kentucky
Caltracs now makes adjustable strut rods. A good friend put them on his Stock and Super/Stock Dusters. Do you have a link for them? I couldn't find them on the Calvert Racing site. Mancini sells them.
[Re: TrackPack]
#2771956
05/06/20 11:14 PM
05/06/20 11:14 PM
Posts: 608 TN
1DGEMAN
TN
Caltracs now makes adjustable strut rods. A good friend put them on his Stock and Super/Stock Dusters. Do you have a link for them? I couldn't find them on the Calvert Racing site. They are brand new give them a call.
[Re: justinp61]
#2772013
05/07/20 08:54 AM
05/07/20 08:54 AM
TrackPack
Minnesota
Caltracs now makes adjustable strut rods. A good friend put them on his Stock and Super/Stock Dusters. Do you have a link for them? I couldn't find them on the Calvert Racing site. Mancini sells them. Thanks!
[Re: dvw]
#2772690
05/09/20 02:04 AM
05/09/20 02:04 AM
Posts: 234 Brisvegas, Australia
Alchemi
Look at 60's NASCAR front suspension. Where the strut rod cushions were there is an upper ball joint fastened in the K frame. Then a fabricated strut rod is threaded to to the ball joint stud. Doug Interesting idea, the factory mount is pretty much a caseless BJ, think i would be looking a a particularly chunky one though and frequent inspections.. As the "ideal" result is eliminating the travel arc, I think a replacement system that pivots on the the same centre line as the torsion bar pin is where developers need to be looking
[Re: Alchemi]
#2772724
05/09/20 07:52 AM
05/09/20 07:52 AM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I have the RMS strut rods in my car and have for a long time. They work well. I run the RMS upper arms, RMS strut rods, and poly bushing in the lower arms. With the suspension unloaded you can cycle it through its full travel by hand very easily. When I had poly bushings in the stock upper it was more difficult to move the upper arm by itself than it is to move the whole assembly with the RMS parts. The setup probably has 15000 miles on it now.
68 Barracuda Formula S 340
