Re: guy insists his 66 Coronet is pos ground.
[Re: Sniper]
#2772130
05/07/20 03:32 PM
05/07/20 03:32 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Starter will work either way, as will any motor in the car. BTDT when I converted my 51 to 12V negative ground from 6v positive ground. No radio in the car so that wasn't an issue. I did swap out the gauges to an aftermarket setup so I dunno about them. I do not see how any 12 volt DC motor will spin the same direction when reversing polarity. This is exactly how power widows reverse to roll up and down . They may still work but when you push the button for up, they will go down and Vice-versa. And power door locks work this way too, power antenna will also work but in reverse. I have used a Mopar starter as a electrical motor on a powered cement wheelbarrel. No bendix spring, direct drive, sprocket welded on the shaft. When 12 V Neg grounded it moved forward. When switched to Pos ground it backed up. My observations over the years: Radios may burn out. Light bulbs do not care. Ign Coils will spark backwards and burn out sparkplugs tips. Gauges may reflect backwards. Electric Puller fans will become Pushers.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: BSharp]
#2772214
05/07/20 07:47 PM
05/07/20 07:47 PM
Posts: 6,571 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Permanent-magnet DC motors change direction with the polarity of the applied current. Wound-field motors do not, because the armature and field currents both reverse but not relative to each other. This. ^^^ Kevin
[Re: HemiRick]
#2772399
05/08/20 10:42 AM
05/08/20 10:42 AM
Posts: 17,918 S.E. Michigan
ZIPPY
S.E. Michigan
Wait....does his car also have a reverse rotation 383 Hemi 12 pack with a 727 Turbo and a posi locker detroit sure grip rear end?
I think I know the guy (he used to call the Mopar Tech Line).
Rich H.
Esse Quam Videri
[Re: HemiRick]
#2772419
05/08/20 11:24 AM
05/08/20 11:24 AM
Posts: 16,164 Mesa, Arizona
dart4forte
Mesa, Arizona
We've got a new member of our local mopar club and he insists his 66 Coronet is pos ground. the pos cable is going to the block and the neg to the starter he says...Is he badly mistaken?...How is this possible?
Thanks for your thoughts Rick You guys should make it a requirement to join your club that members have some basic automotive knowledge. He’s going to be a reflection of your club when he’s out representing you. Somebody needs to school the young man.
Abe Lincoln
[Re: dart4forte]
#2772422
05/08/20 11:36 AM
05/08/20 11:36 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
Thanks for your thoughts Rick You guys should make it a requirement to join your club that members have some basic automotive knowledge. He’s going to be a reflection of your club when he’s out representing you. Somebody needs to school the young man. see Zippy's response, that is what I think when I hear car club lol
68 Barracuda Formula S 340
[Re: dart4forte]
#2772564
05/08/20 06:12 PM
05/08/20 06:12 PM
Posts: 4,452 Michigan
MarkZ
Worthy
Worthy
Thanks for your thoughts Rick You guys should make it a requirement to join your club that members have some basic automotive knowledge. He’s going to be a reflection of your club when he’s out representing you. Somebody needs to school the young man. There are those in this hobby that don't turn their own wrenches. He might be one of them.
[Re: RoadRunnerLuva]
#2772582
05/08/20 07:08 PM
05/08/20 07:08 PM
Posts: 4,848 Memphis
HemiRick
Memphis
I've met JJ and he's not near as redneck IRL as portrayed on TV, actually seems to me to be a smart guy.
Found out the guy w the Coronet is in Southern Missouri about a couple hours away from Memphis....If he was in town I was going to go look.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: dart4forte]
#2772588
05/08/20 07:24 PM
05/08/20 07:24 PM
Posts: 1,235 Phoenix, AZ
Jjs72D
Deep in the closet
Deep in the closet
Phoenix, AZ
Nobody mentioned the age of this person, just that he was a new member. Age is no reflection of intelligence either. I have met smart and stupid of all ages. It is especially sad when it is an older person though. Backing up slightly, you can't mandate intellect for new members. Part of the reason that some join a club is to learn. I was in a car club after I bought my Duster. I was 25 and didn't know much. I'm still learning. Aren't we all ?
[Re: HemiRick]
#2772675
05/09/20 12:42 AM
05/09/20 12:42 AM
Posts: 5,351 Planet Earth
RoadRunnerLuva
Planet Earth
Found out the guy w the Coronet is in Southern Missouri about a couple hours away from Memphis....If he was in town I was going to go look. Well to me, I guess he is smart enough to snag a TV show, that seems to be more popular than the OG Street Outlaws show ? His son though "doughboy"...he is, or at least plays the part really good, of a stone cold redneck!
Plymouth Makes It!
