Re: E-vac check valves.
[Re: rickraw]
#2771170
05/04/20 06:22 PM
05/04/20 06:22 PM
Posts: 11,526 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
You could look at a NAPA CRB 229000. Not sure how they are made anymore. I do know they all break eventually and have to be replaced.
[Re: Locomotion]
#2771239
05/04/20 09:23 PM
05/04/20 09:23 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I think that NAPA piece is correct. 3/4 nipple, 1/2"NPT. The Moroso valves are 20 couple dollars and I have no issue with anything they sell. Like I said, I consider those things to be consumables. Always had to replace a couple during the season.
[Re: rickraw]
#2771269
05/04/20 11:25 PM
05/04/20 11:25 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
STANDARD MOTOR PRODUCTS AV7T or AV7 about $9 @rockauto
Joe
Without Data, you’re just another guy with an opinion.
[Re: sr4440]
#2771314
05/05/20 08:07 AM
05/05/20 08:07 AM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
Joe Yep. Original application.....1983 Chrysler Fifth Avenue 318, (among many others).... A.I.R./smog pump check valve. Breather caps-same, or pretty much any chrysler product down to 1970.
Rich H.
Esse Quam Videri
[Re: rickraw]
#2771450
05/05/20 02:16 PM
05/05/20 02:16 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
NAPA website is good for looking stuff up by application and getting photos, specs, etc. I expect it will take a trip to the store to physically look at the thing to see how it's made. 3/4 nipple with 1/2NPT threads is the typical deal. Late 70s-80s GM used them on their AIR systems as well.
The breathers are not all the same. The breathers Moroso sells for the Vac-u-pan are different from the ones used strictly for a vent. Looser I believe to allow the system to be more efficient. At least that's how it used to be.
