Re: Best compression for max power on methanol?
[Re: gregsdart]
#2763115
04/12/20 04:17 PM
04/12/20 04:17 PM
Posts: 630 Ct
Wirenut
Ct
Title says it. What would you or do you run? I use meth and am at 12.5 . I would think or from what I have read this is almost as low as you want to be. I don’t know that there is a max / perfect compression. I would think it is a combo as with any set up.
[Re: gregsdart]
#2763164
04/12/20 07:18 PM
04/12/20 07:18 PM
Posts: 4,209 New York
polyspheric
New York
There is a point where more compression needs a very complex dome shape with big valve reliefs which masks the valves during overlap. Torque goes up, but peak power doesn't because high RPM VE is down. This is worst with a "real" hemi like the Gen-2 426, and somewhat in BBC, Ford 385, Cleveland because of the valve angles. A wedge with nearly vertical valves and long stroke can run CR than these. It also varies with bore/stroke ratio: longer strokes have more compact chambers for the same displacement and static CR. You won't get the same benefit with lower CR, but I assure you that sidevalve engines with 6:1 CR and huge cams like methanol a lot.
Boffin Emeritus
[Re: polyspheric]
#2763197
04/12/20 08:48 PM
04/12/20 08:48 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
There is a point where more compression needs a very complex dome shape with big valve reliefs which masks the valves during overlap. Torque goes up, but peak power doesn't because high RPM VE is down. This is worst with a "real" hemi like the Gen-2 426, and somewhat in BBC, Ford 385, Cleveland because of the valve angles. A wedge with nearly vertical valves and long stroke can run CR than these. It also varies with bore/stroke ratio: longer strokes have more compact chambers for the same displacement and static CR. You won't get the same benefit with lower CR, but I assure you that sidevalve engines with 6:1 CR and huge cams like methanol a lot. I follow on the dome issue. Mine is .078 high and flat so no problem there. I was told a long time ago (2002) that 15.25 to 15.5 was about max due to more compression wanting a tuneup that negated any gains, plus it got harder on parts. I am curious if that has proven to be the case with 440-1 strokers. Since 2002 I would expect there have been a number of big motors built with 15+ compression.
[Re: Mopar_Rich]
#2770487
05/02/20 04:09 PM
05/02/20 04:09 PM
Posts: 8,165 Left Coast
BobR
Left Coast
15:1 if NA. 12:1 if boosted. That greatly depends on how much boost. We use less than 12:1.
[Re: BobR]
#2770578
05/02/20 10:24 PM
05/02/20 10:24 PM
Posts: 903 Saskatchewan, Canada
cudabin
I went to 15.5 to 1 compression using custom Diamond pistons with a dome shape to match the Indy 440-1 heads. Makes good HP at 976hp...
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...)
70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
[Re: Biginchmopar]
#2770661
05/03/20 08:36 AM
05/03/20 08:36 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Works great at 11:1 too and I know guys running far less with great results.
[Re: pittsburghracer]
#2770666
05/03/20 09:00 AM
05/03/20 09:00 AM
Posts: 251 Saskatchewan (SK)
79410aspenrt
Saskatchewan (SK)
Works great at 11:1 too and I know guys running far less with great results. i'm going to give it a try at 11:1 on my 360''. a few racers around here have had awesome results with 10.5-11:1 compression.
