cutting braided AN #2770449
05/02/20 02:02 PM
05/02/20 02:02 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
down So I'm installing my fuel system. -10 up -8 back. the -8 cuts and the fittings are easy. The -10 is being a PITA. The -10 is all Summit brand and is giving me fits. The -8 is a mixture of used fittings and another brand of hose, I can't recall. Is it that the Summit stuff sucks or what? I'm using an air cut off tool to cut the line. The Summit stuff seems to want to come apart even with a decent cut, plus the black "anodizing" is gone once you put a wrench on it...
Coming soon!!!!
Re: cutting braided AN [Re: Mr.Yuck] #2770451
05/02/20 02:05 PM
05/02/20 02:05 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Have you tried to wrap the area to be cut with electrical tape? I do this when cutting braided oil hose,helps keep the fraying down.
RT
Re: cutting braided AN [Re: Mr.Yuck] #2770458
05/02/20 02:35 PM
05/02/20 02:35 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
X2 on the tape. Wrap it real tight. I leave the tape on. Oil up the male end, helps assembly.
Re: cutting braided AN [Re: rickraw] #2770461
05/02/20 02:47 PM
05/02/20 02:47 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I quit using the braided SS hose, I'd wrap it with electrical tape, cut it with a grinder, I still ended up bleeding to death, The black is a lot easier, but I never had luck with summit hose.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: cutting braided AN [Re: Adobedude] #2770462
05/02/20 02:48 PM
05/02/20 02:48 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
yes wrapping it with tape. the braided wants to push back of the line when you push the fitting on.
Coming soon!!!!
Re: cutting braided AN [Re: Mr.Yuck] #2770479
05/02/20 03:58 PM
05/02/20 03:58 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Summit stuff sucks. Putting their stuff together is like herding cats. And I've done a lot of braided hoses over the years. Just seems like the sizing is off on all of it. I have some here that the guy brought for me to use. We recreated the McAmis video, including the language, after I got stuck for the tenth time. Aeroquip goes together like butter in comparison.
3/4" wide packing tape with the strands in it is what you want to use.
Re: cutting braided AN [Re: CMcAllister] #2770482
05/02/20 04:05 PM
05/02/20 04:05 PM
I have had similar problems with the Summit brand of their SS covered AN hoses, both Teflon and neopreme lined.
I now use Fragola brand and love it up scope
I use 3 or 4 inch wide duct tape and wrap the hose as tight as I can get it and then use a small 4 inch cut off wheel in my Harbor freight Chicago brand air dremel up
Re: cutting braided AN [Re: Cab_Burge] #2770490
05/02/20 04:24 PM
05/02/20 04:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wrap it with electrical tape and cut it with my air grinder and a .040 cut off wheel.. zero issues... leave
the tape on it to put on the fitting
wave
Re: cutting braided AN [Re: Mr.Yuck] #2770491
05/02/20 04:27 PM
05/02/20 04:27 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Some fittings only work with certain hose
Earls fittings only work with Earl's hose.
That's probably your problem
Re: cutting braided AN [Re: Sammy] #2770510
05/02/20 06:08 PM
05/02/20 06:08 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
i have used Jegs and Summit hose, both are inconsistent in sizing and quality. THE fittings seem to be good, the hose not so much.
After this whole Covid19 deal and what China has done to my racing this season, im about to never buy anything made in China again, no matter what the cost ! ! Is it worth it now?? with NO racing ? and not mention other things !
sorry for the rant
I use masking tape
and cut it with a hacksaw, works for me
....BAD A$$ STREET CAR.....
Re: cutting braided AN [Re: n20mstr] #2770521
05/02/20 07:05 PM
05/02/20 07:05 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Try the black hose and you will never go back to braided stainless
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: cutting braided AN [Re: pittsburghracer] #2770525
05/02/20 07:43 PM
05/02/20 07:43 PM
What are you using as a assembly lube to get the hose to seat all the way on the fittings?
I use the Fragola brand of their black #12 AN hose and fittings and could not get the hose to slide all the way up to the plastic cup (even using heat on the hose before and during the installation help) on the end of the fittings work
Re: cutting braided AN [Re: pittsburghracer] #2770526
05/02/20 07:47 PM
05/02/20 07:47 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
https://www.harborfreight.com/28-inch-cable-cutters-6649.html?cid=paid_google|||6649&utm_source=google&utm_medium=cpc&utm_campaign=&utm_content=&gclid=EAIaIQobChMInoKVmK2W6QIVx56zCh2z_AbqEAQYASABEgIPjvD_BwE
This is the cheapest one I see, but there are nicer ones. Basically a large cable cutter
Use this, and forget about tape, grinding, cutting, cleaning whatever. This will cut the hose clean as a lazer, and it has the added benefit of slightly reducing the end from the radial compression. making it easy to put the fittings on. literally, one second and the cleanest cut you can get. Even works on double braid.
Re: cutting braided AN [Re: Mr.Yuck] #2770527
05/02/20 07:48 PM
05/02/20 07:48 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I wrap tightly with a couple layers of either 200mph duct tape or strapping tape (the yellow-ish translucent stuff
With fibers inside), and use a cut off wheel. For me the exact kind of tape I use makes a difference. I learned to Use
The strapping tape from aeroquip since they used to deliver their hose with that kind of tape on it where it had been cut.
I tried Fragola for -12 in this external pickup Deal I’ve been messing with, so far
I like the anodizing better than the aeroquip or jegs brands I worked with
Previously. It seems a little more durable.
Rich H.
Esse Quam Videri
Re: cutting braided AN [Re: ZIPPY] #2770529
05/02/20 07:51 PM
05/02/20 07:51 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Also get yourself an aluminum bench mount rod vise. Cheap, and holds the fitting without a scratch, allowing you to carefully tighten them.
Re: cutting braided AN [Re: Sammy] #2770540
05/02/20 08:34 PM
05/02/20 08:34 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Summit Hose Summit fittings.
Coming soon!!!!
Re: cutting braided AN [Re: dthemi] #2770541
05/02/20 08:34 PM
05/02/20 08:34 PM
Brookeville, Md
Mr.Yuck Offline OP
Mr.Yuck  Offline OP
Brookeville, Md
Thanks have a HF not too far
Re: cutting braided AN [Re: Mr.Yuck] #2770544
05/02/20 08:38 PM
05/02/20 08:38 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I use the technique shown on the Earl's web site how-to videos. A block of brass, a big, sharp brick chisel and a 5 lbs maul and I get clean, crisp cuts every time.
Watch and be amazed. I was.
https://www.anplumbing.com/hose_cutting
Re: cutting braided AN [Re: Cab_Burge] #2770552
05/02/20 09:06 PM
05/02/20 09:06 PM
PA.
"Little"John
"Little"John
PA.
The only lube I use is a little oil on the stud going inside the hose. Nothing fancy. I do mark my hose with a white paint stick on the outside so I know I have it bottomed out and the hose didn’t push out any. I love working with this stuff and I’m over 7 years tank to carb with alcohol use will h zero issues.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: cutting braided AN [Re: Mr.Yuck] #2770556
05/02/20 09:18 PM
05/02/20 09:18 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
I've never had a problem with Summit hose ends but who's hose are you using? I hope it's not Earls.
It won't work.
