Re: cutting braided AN
[Re: rickraw]
#2770461
05/02/20 02:47 PM
05/02/20 02:47 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I quit using the braided SS hose, I'd wrap it with electrical tape, cut it with a grinder, I still ended up bleeding to death, The black is a lot easier, but I never had luck with summit hose.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Mr.Yuck]
#2770479
05/02/20 03:58 PM
05/02/20 03:58 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Summit stuff sucks. Putting their stuff together is like herding cats. And I've done a lot of braided hoses over the years. Just seems like the sizing is off on all of it. I have some here that the guy brought for me to use. We recreated the McAmis video, including the language, after I got stuck for the tenth time. Aeroquip goes together like butter in comparison.
3/4" wide packing tape with the strands in it is what you want to use.
[Re: CMcAllister]
#2770482
05/02/20 04:05 PM
05/02/20 04:05 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
I have had similar problems with the Summit brand of their SS covered AN hoses, both Teflon and neopreme lined. I now use Fragola brand and love it I use 3 or 4 inch wide duct tape and wrap the hose as tight as I can get it and then use a small 4 inch cut off wheel in my Harbor freight Chicago brand air dremel
[Re: Mr.Yuck]
#2770491
05/02/20 04:27 PM
05/02/20 04:27 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
yes wrapping it with tape. the braided wants to push back of the line when you push the fitting on. Some fittings only work with certain hose Earls fittings only work with Earl's hose. That's probably your problem
[Re: Sammy]
#2770510
05/02/20 06:08 PM
05/02/20 06:08 PM
Posts: 4,673 On the parachute mount
n20mstr
i have used Jegs and Summit hose, both are inconsistent in sizing and quality. THE fittings seem to be good, the hose not so much. After this whole Covid19 deal and what China has done to my racing this season, im about to never buy anything made in China again, no matter what the cost ! ! Is it worth it now?? with NO racing ? and not mention other things !
sorry for the rant
I use masking tape and cut it with a hacksaw, works for me
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2770521
05/02/20 07:05 PM
05/02/20 07:05 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Try the black hose and you will never go back to braided stainless
[Re: pittsburghracer]
#2770525
05/02/20 07:43 PM
05/02/20 07:43 PM
Cab_Burge
What are you using as a assembly lube to get the hose to seat all the way on the fittings? I use the Fragola brand of their black #12 AN hose and fittings and could not get the hose to slide all the way up to the plastic cup (even using heat on the hose before and during the installation ) on the end of the fittings
#2770526
05/02/20 07:47 PM
05/02/20 07:47 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
https://www.harborfreight.com/28-inch-cable-cutters-6649.html?cid=paid_google|||6649&utm_source=google&utm_medium=cpc&utm_campaign=&utm_content=&gclid=EAIaIQobChMInoKVmK2W6QIVx56zCh2z_AbqEAQYASABEgIPjvD_BwE This is the cheapest one I see, but there are nicer ones. Basically a large cable cutter Use this, and forget about tape, grinding, cutting, cleaning whatever. This will cut the hose clean as a lazer, and it has the added benefit of slightly reducing the end from the radial compression. making it easy to put the fittings on. literally, one second and the cleanest cut you can get. Even works on double braid.
[Re: Mr.Yuck]
#2770527
05/02/20 07:48 PM
05/02/20 07:48 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
I wrap tightly with a couple layers of either 200mph duct tape or strapping tape (the yellow-ish translucent stuff With fibers inside), and use a cut off wheel. For me the exact kind of tape I use makes a difference. I learned to Use The strapping tape from aeroquip since they used to deliver their hose with that kind of tape on it where it had been cut.
I tried Fragola for -12 in this external pickup Deal I’ve been messing with, so far I like the anodizing better than the aeroquip or jegs brands I worked with Previously. It seems a little more durable.
Rich H.
Esse Quam Videri
[Re: Sammy]
#2770540
05/02/20 08:34 PM
05/02/20 08:34 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yes wrapping it with tape. the braided wants to push back of the line when you push the fitting on. Some fittings only work with certain hose Earls fittings only work with Earl's hose. That's probably your problem Summit Hose Summit fittings.
[Re: dthemi]
#2770541
05/02/20 08:34 PM
05/02/20 08:34 PM
Mr.Yuck
Brookeville, Md
https://www.harborfreight.com/28-inch-cable-cutters-6649.html?cid=paid_google|||6649&utm_source=google&utm_medium=cpc&utm_campaign=&utm_content=&gclid=EAIaIQobChMInoKVmK2W6QIVx56zCh2z_AbqEAQYASABEgIPjvD_BwE This is the cheapest one I see, but there are nicer ones. Basically a large cable cutter Use this, and forget about tape, grinding, cutting, cleaning whatever. This will cut the hose clean as a lazer, and it has the added benefit of slightly reducing the end from the radial compression. making it easy to put the fittings on. literally, one second and the cleanest cut you can get. Even works on double braid. Thanks have a HF not too far
[Re: Mr.Yuck]
#2770544
05/02/20 08:38 PM
05/02/20 08:38 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I use the technique shown on the Earl's web site how-to videos. A block of brass, a big, sharp brick chisel and a 5 lbs maul and I get clean, crisp cuts every time. Watch and be amazed. I was. https://www.anplumbing.com/hose_cutting
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: Cab_Burge]
#2770552
05/02/20 09:06 PM
05/02/20 09:06 PM
Posts: 20,159 PA.
pittsburghracer
"Little"John
"Little"John
PA.
What are you using as a assembly lube to get the hose to seat all the way on the fittings? I use the Fragola brand of their black #12 AN hose and fittings and could not get the hose to slide all the way up to the plastic cup (even using heat on the hose before and during the installation ) on the end of the fittings The only lube I use is a little oil on the stud going inside the hose. Nothing fancy. I do mark my hose with a white paint stick on the outside so I know I have it bottomed out and the hose didn’t push out any. I love working with this stuff and I’m over 7 years tank to carb with alcohol use will h zero issues.
[Re: Mr.Yuck]
#2770556
05/02/20 09:18 PM
05/02/20 09:18 PM
Sammy
Wind Gap,Pa.
yes wrapping it with tape. the braided wants to push back of the line when you push the fitting on. Some fittings only work with certain hose Earls fittings only work with Earl's hose. That's probably your problem Summit Hose Summit fittings. I've never had a problem with Summit hose ends but who's hose are you using? I hope it's not Earls. It won't work.
