Welded up dist slots/FBO plate? #2769817
04/30/20 01:14 PM
04/30/20 01:14 PM
Missouri
Challenger Offline OP
Missouri
I did a distributor about 25 years ago with welding up the slots but cant remember what side I welded up.. Is it the inside of slot or the outside of slot?? I seen on abodies that there was a thread and it had welded up the inside. By looking at pictures of the FBO plate it looks like that it limits timing by taking up the space on the outside of the slot, Make any sense? LOL Ive got the measurements for welding of the slots/timing. So what are some opinions. Inside slot, outside slot or just getting a FBO plate? THANKS
Re: Welded up dist slots/FBO plate? [Re: Challenger] #2769819
04/30/20 01:19 PM
04/30/20 01:19 PM
VA
dragon slayer Offline
VA
Outside. In theory it doesn't matter, though if you weld up the inside you have added advance you remove by rotating the distributor. The only issue would be vacuum cannister clearance. Example Cross Ram Manifold. Welding outside would put orientation in stock location and then limit how much mechanical adv.
Re: Welded up dist slots/FBO plate? [Re: dragon slayer] #2769858
04/30/20 03:28 PM
04/30/20 03:28 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i bought two of the FBO plates and the stated advance numbers on the plates are far from accurate. welding up an existing plate is a better option.
Re: Welded up dist slots/FBO plate? [Re: lewtot184] #2769862
04/30/20 03:44 PM
04/30/20 03:44 PM
Missouri
Missouri
lewtot184
So I presume you welded your on the outside of slot?
Re: Welded up dist slots/FBO plate? [Re: Challenger] #2769920
04/30/20 06:55 PM
04/30/20 06:55 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted by Challenger
lewtot184
outside
Re: Welded up dist slots/FBO plate? [Re: lewtot184] #2769938
04/30/20 07:46 PM
04/30/20 07:46 PM
CA
crackedback Offline
crackedback  Offline
CA
I do the inside to preload the springs more.
If you want the advance fast, do outside, slower do inside
Re: Welded up dist slots/FBO plate? [Re: crackedback] #2769943
04/30/20 08:09 PM
04/30/20 08:09 PM
on a side note there was something awhile back & the guy said the center hole on the FBO plate is too big (dont remember the rest of it)
Re: Welded up dist slots/FBO plate? [Re: RapidRobert] #2769958
04/30/20 08:55 PM
04/30/20 08:55 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
I would weld the inside, the geometry of factory Chrysler distributors is such that the outside of the travel combined with a heavy spring helps get a very slow progressive curve, which is actually what you want (1-2 degrees / 1000 RPM).
If you're going to set it all in at 2000 or 2500 it won't really matter much though. But still will pre-load a super light spring (like the Mr Gasket/Trans Dapt/Mopar springs which are all the same) more to keep you steadier at idle.
And if you do a bad job welding and it falls out you won't end up with too much advance.
Re: Welded up dist slots/FBO plate? [Re: GTX MATT] #2769987
04/30/20 10:26 PM
04/30/20 10:26 PM
Missouri
Missouri
Right now these advance slots are setting at .470. This distributor came with the rebuilt engine. I can tell it was cheaply made. Whoever put the distributor together somehow managed to get both roll pins in the reluctor pin holes. LOL Was a pain getting reluctor off. It raises another question as to what hole should the roll pin be located in. the hole that is even with tooth or the hole that is off a little from the tooth. bb engine. My personal engine it is in the offset hole. a buddy of mine has 2 distributors and one is even with tooth and the other offset, Lol
Re: Welded up dist slots/FBO plate? [Re: Challenger] #2770037
05/01/20 08:02 AM
05/01/20 08:02 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I recently installed the FBO plate,very easy. How accurate? Haven't tested yet. In the past I've also welded them. How accurate is that without a distributor machine? Try doing the math to figure it out. I would say its way more inaccurate to weld. It's trial and error, weld/grind. At least with the plate you can just move it. I'm assuming FBO researched the math before it was made.
Doug
Re: Welded up dist slots/FBO plate? [Re: dvw] #2770047
05/01/20 08:28 AM
05/01/20 08:28 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
one distributor degree is .0154" of travel. very easy to verify with number drills. the FBO pates I have are using .010" of travel for each distributor degree. so, the numbers on the FBO plates I have don't match up with the mopar stuff. can you still use the plate? sure, just verify with the number drills what the travel is and having a timing tape or degrees marked on the dampner can get you where you need to be. to me the FBO plates are an unnecessary hassle compared with modifying a stock plate.
Re: Welded up dist slots/FBO plate? [Re: lewtot184] #2770105
05/01/20 11:19 AM
05/01/20 11:19 AM
West Coast, USA
jbc426 Online content
jbc426  Online Content
West Coast, USA
To limit the mechanical advance mechanism's travel, you weld the end of the slots that the advance arms contact when it advances. I found that chainsaw files are the perfect size to file and shape the slot with after welding. It's a bit of trial and error, but you must use a dial back timing light to see the effects your welding and filing have resulted in.
Re: Welded up dist slots/FBO plate? [Re: jbc426] #2770110
05/01/20 11:47 AM
05/01/20 11:47 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
if the slots are being welded up a person needs to keep in mind that .0154" is one distributor degree. the pin on the centrifugal weight is real close to .25". so, if you want 9 distributor degrees for example all you need is a 9/64" drill bit to fit between the open section of the slot and the centrifugal weight pin. very simple, no special timing lights or anything needed. it's always best to set total timing in a performance application but by simply doing the math initial timing settings will get you pretty close to the desired total. I've been doing this for decades on mopar distributors; it's not rocket science.
Re: Welded up dist slots/FBO plate? [Re: lewtot184] #2770135
05/01/20 12:43 PM
05/01/20 12:43 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Thanks Lew. Your method makes it easy.
Doug
Re: Welded up dist slots/FBO plate? [Re: lewtot184] #2770220
05/01/20 05:35 PM
05/01/20 05:35 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Me too.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Welded up dist slots/FBO plate? [Re: Dave_J] #2770450
05/02/20 02:05 PM
05/02/20 02:05 PM
VA
VA
While choosing which side to weldup based on spring advance desired maybe a method, isn't just as easy to curve it and if you want preload, bend the spring tab or turn the offset stud on a Prestolite? What if your going from a 15 to an 8, do you really want to preload the spring that much?
Re: Welded up dist slots/FBO plate? [Re: dragon slayer] #2770480
05/02/20 04:00 PM
05/02/20 04:00 PM
I weld up the outside due to that being easier for me to Tig or Mig weld with it held in my vise work
I do use both Mr. Gasket 925B springs also shruggy
Re: Welded up dist slots/FBO plate? [Re: Cab_Burge] #2770530
05/02/20 07:54 PM
05/02/20 07:54 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
welding the outside of the slot duplicates what the factory did to reduce distributor degrees. truth is either side will work but the curve will be a little slower welding the inside. the FBO plate slots are shortened on the outside.
Re: Welded up dist slots/FBO plate? [Re: lewtot184] #2770589
05/02/20 10:53 PM
05/02/20 10:53 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
It's always worth checking the advance curve first!
You can do it on the engine with timing tape.
Measuring the slots will usually give a close idea, but there are other variables.
In general, with 'hot' cam (ie more overlap) and same compression, the engine wants more initial timing. So shortening the inside of the slot compensates for that. Bonus of doing it that way is, the timing will stay in the right range to work with vacuum advance. The real win at the track doing that way is the engine never sees any loss of tiiming in the upper rpms due to slew rate. The extreme example of that is the DC/MP race distributors. (aka 'tach drive')
Here's an illustration of how welding effects the advance.
Its the acceptable timing for a smogged '68 set at the suggested initial. But it could be any distributor with a longer advance than will work with the initial.
The heavy black line shows what happens when the slots are shortened on the inside.
It's drawn at 12.5* because that was the recommended initial timing for non-CAP version of the same engine in 1967.
Re: Welded up dist slots/FBO plate? [Re: Mattax] #2770601
05/02/20 11:11 PM
05/02/20 11:11 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
If the above distributor was on a 'hot' engine, it might be fine that the advance doesn't start until 800 or 900 rpm.
But if that's too late, then slightly reduce the tension of the light spring. That's done by bending the tab or rotating the perch.
With less tension, there will be slightly less force holding the weight and it will move out at lower rpm.
Spring perch is mounted on an eccentric
File a screwdriver to fit
Advance starts round 700 rpm
