Power Steering pulley help
#2770065
05/01/20 09:47 AM
05/01/20 09:47 AM
Posts: 6,224 JERSEY
RJS
JERSEY
On a 71 383 does anyone know the correct PS pulley diameter and or P/N??? I'm speaking of the Saginaw style with the 3 openings. Also I see 440 source sells them any feedback on the quality and size?
Thanks Ron
Re: Power Steering pulley help
[Re: RJS]
#2770131
05/01/20 12:38 PM
05/01/20 12:38 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Did some more research with a friend and came up with this is this correct??
Ron
[Re: RJS]
#2770241
05/01/20 07:38 PM
05/01/20 07:38 PM
Posts: 4,404 Michigan
MarkZ
Worthy
Worthy
Both factory replacement (keyed and press fit) that Mancini sells are 6 7/8". I just installed the keyed one onto a Saginaw pump two nights ago and took the car out today. Worked good.
[Re: MarkZ]
#2770360
05/02/20 09:28 AM
05/02/20 09:28 AM
Posts: 1,978 USA
Suregrip391
USA
Both factory replacement (keyed and press fit) that Mancini sells are 6 7/8". I just installed the keyed one onto a Saginaw pump two nights ago and took the car out today. Worked good. I wonder if there is only one mfg for this because 440 source sells it cheaper.
[Re: Suregrip391]
#2770397
05/02/20 11:05 AM
05/02/20 11:05 AM
Posts: 6,224 JERSEY
RJS
JERSEY
Both factory replacement (keyed and press fit) that Mancini sells are 6 7/8". I just installed the keyed one onto a Saginaw pump two nights ago and took the car out today. Worked good. I wonder if there is only one mfg for this because 440 source sells it cheaper. Yes 440 source is only $50 bucks so I think they are the source but I'm going with a factory piece I'm getting from a friend. Ron
