Shortage of Edelbrock Magnum heads?
#2769894
04/30/20 05:56 PM
04/30/20 05:56 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I've been building a Magnum based stroker for a friend and he's been getting run around from Mancini about the availability of Eddy Magnum cylinder heads. Any body else having trouble getting Magnum heads? Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Shortage of Edelbrock Magnum heads?
[Re: fourgearsavoy]
#2769912
04/30/20 06:37 PM
04/30/20 06:37 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I've been building a Magnum based stroker for a friend and he's been getting run around from Mancini about the availability of Eddy Magnum cylinder heads. Any body else having trouble getting Magnum heads? Gus Check out the Speedmaster heads. You may be surprised with how they look and perform after a nice valve job. Or better yet ProMax if they offer a Magnum Head. 10 percent off sale ends today I think.
[Re: J_BODY]
#2769970
04/30/20 09:36 PM
04/30/20 09:36 PM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
NS1 since May of 2018... I don’t show any in inventory Gone with the rest of the product line. Thanks for checking! Guess a person would have to pair it up with regular edelbrock then.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2769976
04/30/20 09:49 PM
04/30/20 09:49 PM
fourgearsavoy
Rittman Ohio
Thanks a lot Rich I will check with my buddy in the morning for a status report. He's working with Wes up at Mancini now to try and get this resolved because they already have his money. Gus
[Re: fourgearsavoy]
#2769986
04/30/20 10:25 PM
04/30/20 10:25 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If he, you, or a friend belong to some of the Mopar Facebook groups and post a wanted ad you will get responses
[Re: pittsburghracer]
#2769999
04/30/20 11:06 PM
04/30/20 11:06 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
KInda sucks when a private equity firm buys up a quality, iconic American company that has been investing in the odd stuff like Mopars, Pontiacs, flathead stuff, etc., and decides you aren't worth the trouble if you don't have an LS.
Next stop, China junk in an Edelbrock box.
[Re: ZIPPY]
#2770000
04/30/20 11:08 PM
04/30/20 11:08 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Mancini had Edelbrock Magnum heads on clearance a few months ago. Not sure they'd get any more. Promaxx deosn't have the Magnum style head either that i've seen.
I got two NHRA unmarked ones on that sale. Paid $659 each full assembled. But charged me $100 shipping after the invoice was billed and paid. I would not trust Mancini's staff. I've been lied to too many times over the years. And their rip off shipping system. [/rant] Summit says the RPM 61775 will ship tomorrow. These do have the Edelbrock RPM markings on the ends. This is the Dual spring one. The single spring will ship 5/21/2020 https://www.summitracing.com/parts/edl-61775
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: J_BODY]
#2770083
05/01/20 10:30 AM
05/01/20 10:30 AM
ZIPPY
S.E. Michigan
Worth a phone call to an actual human being, and a reuqest for a stock check for sure.
Rich H.
Esse Quam Videri
[Re: fourgearsavoy]
#2770098
05/01/20 11:06 AM
05/01/20 11:06 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I've been building a Magnum based stroker for a friend and he's been getting run around from Mancini about the availability of Eddy Magnum cylinder heads. Any body else having trouble getting Magnum heads? Gus Just throwing this out there but did he ever consider running a much better Trickflow head. Made in the good old USA and better flowing. Notes:Magnum engines must use Harland Sharp S72025K (1.5 ratio) or S72026K (1.6 ratio) shaft mount roller rocker arms for proper oiling. https://www.trickflow.com/search/department/cylinder-heads
[Re: 2boltmain]
#2770230
05/01/20 06:29 PM
05/01/20 06:29 PM
fourgearsavoy
Rittman Ohio
Well he talked to Wes again and the heads are supposed to be shipped from Mississippi around the 16th of this month, I guess thats where they do the finish machining and assembly. Thanks again guys for the responses. We are really in no hurry because I'm probably not going back to work until next month. Gus
#2770632
05/03/20 03:10 AM
05/03/20 03:10 AM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
I've been building a Magnum based stroker for a friend and he's been getting run around from Mancini about the availability of Eddy Magnum cylinder heads. Any body else having trouble getting Magnum heads? Gus Just throwing this out there but did he ever consider running a much better Trickflow head. Made in the good old USA and better flowing. Notes:Magnum engines must use Harland Sharp S72025K (1.5 ratio) or S72026K (1.6 ratio) shaft mount roller rocker arms for proper oiling. https://www.trickflow.com/search/department/cylinder-heads John Mike at B3 Racing is setting me up with some PRW Roller rocker arms that will do push rod oiling for the trick flow heads, that I put on my 2000 magnum 360 engine.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
[Re: mopar65]
#2770659
05/03/20 08:33 AM
05/03/20 08:33 AM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I've been building a Magnum based stroker for a friend and he's been getting run around from Mancini about the availability of Eddy Magnum cylinder heads. Any body else having trouble getting Magnum heads? Gus Just throwing this out there but did he ever consider running a much better Trickflow head. Made in the good old USA and better flowing. Notes:Magnum engines must use Harland Sharp S72025K (1.5 ratio) or S72026K (1.6 ratio) shaft mount roller rocker arms for proper oiling. https://www.trickflow.com/search/department/cylinder-heads John Mike at B3 Racing is setting me up with some PRW Roller rocker arms that will do push rod oiling for the trick flow heads, that I put on my 2000 magnum 360 engine. Nice. TrickFlow delayed their release of these heads many months and redesigned it to meet a larger need. Intakes were delayed for casting issues and I’m not sure if they are available yet or not. I look forward to more Mopar products from them in the future.
[Re: b1dartsport]
#2770802
05/03/20 02:34 PM
05/03/20 02:34 PM
fourgearsavoy
Rittman Ohio
Kind of why we wanted to stick with Magnum heads so we could use a really nice set of rockers and oil through the pushrods. Gus
