Wilwood brakes
#2769569
04/29/20 05:09 PM
04/29/20 05:09 PM
Posts: 859 lancaster,california
johnnycuda
Hey guys, I'm going to ordering front and rear disc brakes for my '70 'cuda street/strip car, 95% (street honestly), the car is a factory disc brake car, was power but I removed the booster and used the manual brake rod years ago. It weighs about 3850, Dana with 11" drums, is a mid-10 N/A car, but going to step it up a little very soon. My question is, for you guys that have done this swap, did you replace the factory proportioning valve or retained the stock one?, what bore size master cylinder did you use and were happy with when driving?
Thanks!
1970 'Cuda,Lime Light,499 Indy S/R's 10.70's @125,street driven ALOT! 1966 Barracuda 360,now a 5spd,Hemi Orange,Hot Rod Air, New daily driver-2003 Ram 2500 Cummins 5.9 '69 Valiant 2-dr, sleeper! New project---1938 Dodge truck, plan is a 360 with a A500, AC, Calvert rear susp., rack and pinion front with coils.
Re: Wilwood brakes
[Re: johnnycuda]
#2769579
04/29/20 05:47 PM
04/29/20 05:47 PM
Posts: 11,678 W. Kentucky
justinp61
W. Kentucky
I have Strange on the front and Wilwoods on the back, no proportioning valve at all. The valve s gutted and used as a T for the fronts, the rear goes straight from the m/c to the rear. My m/c is 15/16”, if it ever goes bad I’ll use a 7/8”. The car is 3350# or so with me in it.
Re: Wilwood brakes
[Re: justinp61]
#2769604
04/29/20 06:40 PM
04/29/20 06:40 PM
johnnycuda
I had heard from someone before about doing that, but didn't know how well it stopped in traffic etc., ..spongy or rock hard. I talked to a guy at Wilwood, and he told me Mopar two different brake pedals, I told him I'd never seen or heard that, that they had 2 different brake rods, power and manual.
Re: Wilwood brakes
[Re: Sammy]
#2769624
04/29/20 07:31 PM
04/29/20 07:31 PM
justinp61
W. Kentucky
Wilwoods didnt fit on a weld rear wheel. Had to grind on the caliper to get them to work. They are 15x10s
Strange rears fit perfectly and installation is easier than the Wilwoods. What back space? Mine clear fine with 3 1/2" back space.
Re: Wilwood brakes
[Re: justinp61]
#2769653
04/29/20 09:00 PM
04/29/20 09:00 PM
Posts: 11,408 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
With the normal race calipers using the 1.75" bore, a four caliper with 4 piston all around would use a 1.125" MC. The Wilwoods use a smaller piston 1.375" on some of their stuff for some reason. We got caught with that one time years ago. With a 1.125 MC pedal was hard as a rock and the car wouldn't stop with 2 feet. Figured out what was going on, put an .875 on it and it would put you through the windshield if you wanted. Pedal was a little low for my taste, but it wasn't my car.
Ask Wilwood what they want on it. They will know what parts you're getting.
Modifying the system/replacing OEM parts = ditch the factory prop valves. Some people use an adjustable prop valve, but if the components are matched according to the parts used and application for the car, it ends up being run wide open and useless.
Re: Wilwood brakes
[Re: CMcAllister]
#2769675
04/29/20 10:10 PM
04/29/20 10:10 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
I run wilwoods front and rear, I use a Dr Diff master cylinder kit with the smaller piston. I do not have a proportioning valve. The front kit has vented rotors but the rear kit is not vented and the rotors are drilled. The fronts have been on there for 18-20 years and the rears just a year or two. I have been very pleased with them and couldn't imagine something else working much better.
My car is 3550 on the starting line and 4000-4100 on the road for drag week. In 2018 we were up in the hills and mountains and stopping was never a concern.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
Re: Wilwood brakes
[Re: Bad340fish]
#2769789
04/30/20 11:35 AM
04/30/20 11:35 AM
johnnycuda
Thanks everybody for the help and advice, as always the Moparts family comes thru, I will need to ask Wilwood about the calipers not clearing Weld wheels, mine are a 15x10 with 6.5" backspace.
Re: Wilwood brakes
[Re: johnnycuda]
#2769806
04/30/20 12:45 PM
04/30/20 12:45 PM
Posts: 1,823 Wind Gap,Pa.
Sammy
Wind Gap,Pa.
Thanks everybody for the help and advice, as always the Moparts family comes thru, I will need to ask Wilwood about the calipers not clearing Weld wheels, mine are a 15x10 with 6.5" backspace. They won't work. They will tell you they work but they don't on certain Welds. Get Strange rear brakes
Re: Wilwood brakes
[Re: Wirenut]
#2769814
04/30/20 01:12 PM
04/30/20 01:12 PM
johnnycuda
I have the Weld Draglites on the rear, I have Strange's spool/axles in the Dana, they built them using a 2.600 offset, so need to see if they offer that brake kit for that. I have fairly skinny tires up front, a 205/70-15 I believe?, 28" tall, wheels are 3.5" wide.
Re: Wilwood brakes
[Re: Sammy]
#2769827
04/30/20 01:47 PM
04/30/20 01:47 PM
justinp61
W. Kentucky
Thanks everybody for the help and advice, as always the Moparts family comes thru, I will need to ask Wilwood about the calipers not clearing Weld wheels, mine are a 15x10 with 6.5" backspace. They won't work. They will tell you they work but they don't on certain Welds. Get Strange rear brakes Wilwoods and Welds, 12.19" rotors, 2.36" offset.
Re: Wilwood brakes
[Re: johnnycuda]
#2769842
04/30/20 02:43 PM
04/30/20 02:43 PM
Posts: 3,275 West Coast, USA
jbc426
West Coast, USA
Matching the clamping force of the front & rear brakes by choosing the correct size caliper bores and master cylinder is dramatically better than trying to use an adjustable proportioning valve as a bandaid. 4 wheel disc systems need a distribution block like 4 wheel drum brake cars have. There is no proportioning valve in them.
Experts like Dr Diff or Wilwood's tech guys can steer you to the correct sizing and matching of parts. Make sure you use DOT approved braided lines, which will help you modulate the brake pedal better.
There is also a small device commonly used in race cars that helps cushion the shock wave of a sudden brake application to the rear brakes. It doesn't lower the pressure, but it does soften the spike to reduce the tendency of the rear brakes to lock up during panic like stops/slowing. It's around $100, and it works amazingly well.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
