Re: 1968 Roadrunner Post car w/ 6.1L Hemi & 6-speed
[Re: 70B5Cuda]
#2757222
03/29/20 01:39 PM
03/29/20 01:39 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
wow great job kid . so over the top . I love the color . you gave me a great idea for my front suspension brace . I will be bending up 1/4 inch and 1/8th inch plate tomorrow. I am splitting mine over 2 inches in the 1/4 and 1 inch in the door.
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
[Re: 76orangewagon]
#2770682
05/03/20 09:28 AM
05/03/20 09:28 AM
Posts: 1,064 Newton, KS
70B5Cuda
Newton, KS
Thanks all! The 6.1L engine and TR6060 transmission are mated and on the RMS K frame. The engine is a 50K mile factory built short block. I added an Arrington cam shaft and CNC ported heads. The intake manifold has also been ported. From the factory it was rated at 425hp. It should comfortably make 500hp. Holley wiring harness added
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: DynoDave]
#2772533
05/08/20 04:56 PM
05/08/20 04:56 PM
Posts: 4,669 Wichita
GY3
Wichita
Looking forward to seeing this one on the road!
[Re: GY3]
#2772768
05/09/20 09:59 AM
05/09/20 09:59 AM
70B5Cuda
Newton, KS
Looking forward to seeing this one on the road! Me too!!!! Rear suspension is loaded! The axles are from DSS and they slipped right in.
[Re: 76orangewagon]
#2780481
06/01/20 07:03 PM
06/01/20 07:03 PM
70B5Cuda
Newton, KS
I love seeing a quality build...That thing is awesome...great job. Thanks! Wiring and plumbing in progress...
[Re: 70B5Cuda]
#2780897
06/02/20 09:08 PM
06/02/20 09:08 PM
Superfreak
Superfreak
