Page 2 of 3 1 2 3
Re: A little time at the dyno. [Re: fourgearsavoy] #2768927
04/28/20 01:06 AM
04/28/20 01:06 AM
AndyF Offline
AndyF  Offline
There are lots of other differences between engine dyno and chassis dyno numbers. I'd say that engine would easily make 600 hp on an engine dyno when outfitted with dyno headers. The drivetrain absorbs some power but so does the exhaust system, the cooling system, alternator, extra heat, etc. The car should be able to run low 11's if he can get it to hook.
Re: A little time at the dyno. [Re: AndyF] #2768930
04/28/20 01:25 AM
04/28/20 01:25 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This was done on a Mustang Dyno, they are in the 19 to 22% drive train loss, the Dyno Jet is in the 13 to 15 % loss, from my experience. No matter what it will be a awesome street strip Car
Re: A little time at the dyno. [Re: fourgearsavoy] #2768975
04/28/20 07:28 AM
04/28/20 07:28 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Originally Posted by fourgearsavoy
Originally Posted by polyspheric
15% driveline loss to the wheels makes it 578 bhp.
Very nice!
15% even with a manual transmission???
Gus beer
Rick said there was more to it than adding a percentage on the number. But I'm not too hung up on it. He said it's good for 600+, I'm happy with it, and there will be 100 differing opinions on what the crank number should be. Bottom line, I feel I reached my goal and it puts a smile on my face every time I lay into the throttle. grin drive
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: A little time at the dyno. [Re: OhioMopar] #2768976
04/28/20 07:32 AM
04/28/20 07:32 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
On a side note, I ran it on 90 octane pure gas. He said he would have liked to see some 93, even with the corn. My plan was to get a can of higher octane and make another pull with a mix in it, but I ran myself up against the wall getting ready to load up and go. So that never happened. He said it may have seen 8-10 more with Q-16 in it, but probably not enough to lose any sleep over it.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: A little time at the dyno. [Re: OhioMopar] #2769049
04/28/20 11:09 AM
04/28/20 11:09 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My 434" small block was broke in and tuned on a engine dyno using Crate 98 race gas. After all the tuning we pumped the fuel cell and emptied the carb bowls and poured in a can of pump 93. After bringing it up to temperature it made 30 more hp than the 98 did. I thought it was a fluke or something went wrong with the computer so we cooled it down and made another pull, again 30 more hp.
Re: A little time at the dyno. [Re: justinp61] #2769128
04/28/20 02:09 PM
04/28/20 02:09 PM
Cab_Burge Online work
Cab_Burge  Online Work
Your results back up the old adage of using the lowest octane needed to not ping, it will make more heat quicker pushing down on the pistons harder up
Re: A little time at the dyno. [Re: OhioMopar] #2769150
04/28/20 03:04 PM
04/28/20 03:04 PM
AndyF Offline
AndyF  Offline
Very nice!
Gus beer
I can guarantee you that the crank number would be over 600 hp with those parts. A 512 with 240 heads and a decent solid flat tappet shouldn't have any trouble making between 600 and 625 on the dyno. I've helped out with a bunch of those projects since the 240 heads came out and they make great power as long as the have a good cam and a good intake to work with the heads. You'll have a lot of fun banging gears around town with that car. Just don't get too crazy with it, those old cars aren't so good sometimes at slowing down or going around corners so be careful.
Re: A little time at the dyno. [Re: OhioMopar] #2769167
04/28/20 03:49 PM
04/28/20 03:49 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Congrats on a great running car!I have been to BS3 with a friends car.
Re: A little time at the dyno. [Re: OhioMopar] #2769171
04/28/20 03:53 PM
04/28/20 03:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Hell ya, super happy and impressed with those results and rowin gears to boot.............
Re: A little time at the dyno. [Re: justinp61] #2769189
04/28/20 04:56 PM
04/28/20 04:56 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
That's pretty interesting. Surprising to me. But interesting.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: A little time at the dyno. [Re: AndyF] #2769191
04/28/20 05:00 PM
04/28/20 05:00 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
My crazy days are behind me. With the big'n'littles, it's not going to be trying to carve corners anytime soon. lol. It'll be fun. Cruising, racing, improving. I bought the car in '13 and it's finally getting the to point I can leave the drivetrain alone(aside from tuning more with a wide band). I have the front suspension yet to rebuild, which should happen in the next couple weeks. Then its on to the body and interior, even though everyone that sees the car tells me to leave the "patina" alone. shruggy
1969 Dart GTS 340
2015 Dodge Dart GT
Re: A little time at the dyno. [Re: Clanton] #2769192
04/28/20 05:01 PM
04/28/20 05:01 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Thank you! It's a pretty cool place.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: A little time at the dyno. [Re: Thumperdart] #2769194
04/28/20 05:02 PM
04/28/20 05:02 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Originally Posted by Thumperdart
Hell ya, super happy and impressed woth those results and rowin gears to boot.............
I'm looking forward to dialing it in more once I get the wideband installed.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: A little time at the dyno. [Re: justinp61] #2769221
04/28/20 06:56 PM
04/28/20 06:56 PM
NC
440Jim Offline
440Jim  Offline
NC
One dyno operator I talked to said some combos that can run on pump 93, will sometimes make more power than race gas. He didn't say why, but one thought I had was the oxygenation of the 10% ethanol (need to jet for it). My 10.3CR engine didn't vary more than 1-2 hp going from the dyno shop 112 race gas to my 93 pump gas I brought with we. We used a oxygen sensor in the exhaust to tune my carb. So in my case, the fuel was not the limiting factor (likely my unported 452 iron heads, LOL).
Re: A little time at the dyno. [Re: OhioMopar] #2769397
04/29/20 10:11 AM
04/29/20 10:11 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Will you be able to post a dyno sheet?
Re: A little time at the dyno. [Re: Clanton] #2769399
04/29/20 10:17 AM
04/29/20 10:17 AM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Sure!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: A little time at the dyno. [Re: OhioMopar] #2769410
04/29/20 10:57 AM
04/29/20 10:57 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Nice Roadrunner ! Sounds like a nice combo that should easily hit your goal. Good luck , Ron
Re: A little time at the dyno. [Re: OhioMopar] #2769421
04/29/20 11:18 AM
04/29/20 11:18 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My favorite part is street tuning then when ya hit the track, you are better than half way there w/a bit of fine tuning and nice time slips. With a manual trans, shock settings and tire pressures are your friend..........
Re: A little time at the dyno. [Re: Thumperdart] #2769434
04/29/20 11:53 AM
04/29/20 11:53 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Great combo and that's a tough looking Bee, what kind of fan is on it?
Re: A little time at the dyno. [Re: 383man] #2769438
04/29/20 12:07 PM
04/29/20 12:07 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Thanks Ron. Hopefully it will be as reliable and badass as your Plymouth.
1969 Dart GTS 340
2015 Dodge Dart GT
Page 2 of 3 1 2 3
