Re: A little time at the dyno.
[Re: Thumperdart]
#2769440
04/29/20 12:10 PM
04/29/20 12:10 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
My favorite part is street tuning then when ya hit the track, you are better than half way there w/a bit of fine tuning and nice time slips. With a manual trans, shock settings and tire pressures are your friend.......... I'm using a set of 28" bias ply slicks. It's got dual adjustable QA-1's in it all the way around. I'm going to see where eveyone starts with their settings (especially stick guys) and start with the Assassin bars in the bottom holes. We'll see what it does there.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: GTX MATT]
#2769441
04/29/20 12:13 PM
04/29/20 12:13 PM
OhioMopar
Mt.Gilead, Ohio
Was Great combo and that's a tough looking Bee, what kind of fan is on it? It's got a 7 blade Mopar fan, I'm not even sure what it came off of, with a Jaguar clutch. I got the part number off GY3 and it has worked very well.
[Re: Clanton]
#2769631
04/29/20 07:47 PM
04/29/20 07:47 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I use M/T stiff wall slicks and tubes with mine just because it feels good on the hit and stable at speed. I would like to get my rod on that dyno it's only 25 minutes from my house. Maybe while I'm laid off I can get over there Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2769935
04/30/20 07:42 PM
04/30/20 07:42 PM
OhioMopar
Mt.Gilead, Ohio
I would like to get my rod on that dyno it's only 25 minutes from my house. Maybe while I'm laid off I can get over there Gus You might want to get on the phone with them. I scheduled a month in advance. They said this is when everything picks up. Probably worse now that the state is about to kinda open up again.
[Re: OhioMopar]
#2770838
05/03/20 04:58 PM
05/03/20 04:58 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Congrats Darin, Should be a fun ride!
[Re: OhioMopar]
#2770952
05/03/20 10:21 PM
05/03/20 10:21 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
is the black line the AFR? If so it looks like it goes pig rich as you rev it up I like to see the AFR (12.5 to 13.5 N/A on pump gas) rock steady after the accelerator pump quits squirting
[Re: Cab_Burge]
#2773395
05/11/20 07:37 AM
05/11/20 07:37 AM
OhioMopar
Mt.Gilead, Ohio
is the black line the AFR? If so it looks like it goes pig rich as you rev it up I like to see the AFR (12.5 to 13.5 N/A on pump gas) rock steady after the accelerator pump quits squirting Yes it is. I'm going to get a wideband in it and do some more tuning. I wanted to make sure it was close and I didn't have any major issues before I put it on the track.
[Re: Clanton]
#2773566
05/11/20 03:30 PM
05/11/20 03:30 PM
OhioMopar
Mt.Gilead, Ohio
How is your timing,Steady?Do you have a collar on the distributor? Seemed steady. I haven't put a collar on, yet. I hadn't thought of that. I had one on the 383 that was in it. I will have to see if I still have it.
