Correct spade for Key buzzer switch? #2768840
04/27/20 07:51 PM
04/27/20 07:51 PM
MO
cdp Offline OP
cdp  Offline OP
MO
Can someone tell me the correct type of spade used on the key buzzer switch for my 71 GTX? I need to repair it and want to keep it OEM.
Here's a pic for an example. I wasn't sure what the correct nomenclature is.
Re: Correct spade for Key buzzer switch? [Re: cdp] #2768857
04/27/20 08:21 PM
04/27/20 08:21 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
those are bullet connectors . . .
Re: Correct spade for Key buzzer switch? [Re: a12rag] #2769021
04/28/20 10:10 AM
04/28/20 10:10 AM
California
biggE Offline
biggE  Offline
California
plugs directly into the turn signal harness connector that exits the steering column
Re: Correct spade for Key buzzer switch? [Re: biggE] #2769033
04/28/20 10:42 AM
04/28/20 10:42 AM
moparx Online content
moparx  Online Content
i believe the correct name for those terminals is Mollex [ might be spelled Molex ?]
readily available on the bag or elsewhere as singles or kits. the plastic terminal holders are also available.
beer
