Re: Front k member complete kit?
[Re: b1dartsport]
#2769401
04/29/20 10:35 AM
04/29/20 10:35 AM
Posts: 34,925 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I have the Gerst Kit on my car, it installed easily, lined up perfectly. I never had a problem getting in touch with Carl Gerst and he answered all of even my dumb questions. Call him at regular business hours at 319-759-9461. Me also , his customer service and product are both great
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: dvw]
#2769405
04/29/20 10:42 AM
04/29/20 10:42 AM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I put a Alterkation in the Valiant , before I knew about Gerst stuff ..
Its ok, I found Bill to be slow to respond, his front costs more than Gersts , and I just can't understand why after all the fronts he has sold, he can't find a mandrel bender to bend the tubes
[Re: dvw]
#2769514
04/29/20 02:50 PM
04/29/20 02:50 PM
Posts: 10,032 MN
JERICOGTX
MN
I'd like to see the modified ball joint/steering arm. Any pics? Doug I'll have to find the spindle picture. All I did to the lower ball joint, was cut off the factory steering arm. It bolts into place just like normal, and still has the stops that hit the lower control arm to limit the steering. As for the spindle, I welded on some arms to the inside of the spindle, with taking into consideration to Ackerman. Tony, as for getting 5* caster, everything is stock, no tricks. When the car sits very low getting that much is simple. I actually had to cut down the LCA bump stops, so it wasn't riding on them. I literally could drive the car one handed, even with it being a stick car.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2769622
04/29/20 07:30 PM
04/29/20 07:30 PM
Posts: 6,144 Melbourne , Australia
LA360
Jeff, your front end is similar to the one that LRT used to make. Looks great! I think when I eventually get back to my car, I'll do something similar I think.
Alan Jones
[Re: LA360]
#2769684
04/29/20 10:49 PM
04/29/20 10:49 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Lots of great options out there these days, I'm super happy with the HDK kit in my Challenger. Denny always answered my calls, texts, and emails. First time I did that kind of conversion and he was very helpful.
[Re: ProSport]
#2771966
05/07/20 12:03 AM
05/07/20 12:03 AM
Posts: 22,696 Bitopia
jcc
Bitopia
A disclosure, I have an AlterK, that I modified.
That being said, I read in the May 2020 issue of "RaceCar Engineering" the following comment by contributor Mike Blanche,t page 7, that I think is very pertinent to this discussion:
"Generally attempted copies of winning racecars result in them being unsuccessful as designers egos, and the need to justify their positions, mean they try to put their own stamp on the design, which unknowingly screws up the overall package.
Or financial issues cause manufacturing compromises, with a similar effect."
Most would agree AlterK was the first to offer this much copied design solution.
[Re: jcc]
#2772528
05/08/20 04:34 PM
05/08/20 04:34 PM
ProSport
Akron, Ohio
I think several of the kits work very well, plus there's some that a lot of people don't even know about such as Tory Shellehamer's kits. Hopefully with all these options the prices will come down some eventually. I could not run an RMS AlterK kit because my inner fenders are custom re-inforced so my only option is the kits that use the stock upper shock mounts. So the HDK was my only option other than MF and I will never use MF, and HDK was within driving distance so I saved the shipping money, win win situation for me.
[Re: Sammy]
#2772563
05/08/20 06:12 PM
05/08/20 06:12 PM
Posts: 20,183 Park Forest, IL
slantzilla
Park Forest, IL
My Valiant has the rack in a stock K-frame. It can be done, but the rack is really too far forward. Bump steer was pretty bad.
I had it redone with different tie rods this winter, but haven't really driven it other than on and off the trailer.
