14x32 M/T Pro Bracket Radial #2766299
04/20/20 12:54 PM
04/20/20 12:54 PM
CEDAR RAPIDS
Plymouth340 Offline OP
CEDAR RAPIDS
I would like to switch from 14x32 slicks to the M/T pro bracket radial 14x32. Wondering if anybody had any experience with the swap?
Re: 14x32 M/T Pro Bracket Radial [Re: Plymouth340] #2766309
04/20/20 01:17 PM
04/20/20 01:17 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
All I can say is when my buddy first put them on he had some learning to do in his low 9 second car. I heard him spin from the staging lanes like he was on water. He has since lost .20 in the 1/4 mile. (Gone faster) Another buddy had handling issues with the same tire in his 8 second Pontiac. Pretty sure he is still running them now too. Everyone I know that has switched from a slick to a radial has picked up a lot but so far I’m sticking with a 14-32 M/T slick.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 14x32 M/T Pro Bracket Radial [Re: pittsburghracer] #2766317
04/20/20 01:53 PM
04/20/20 01:53 PM
CEDAR RAPIDS
CEDAR RAPIDS
interesting...My car runs 9.0s..leaving on the brake at 5500 and 7300 stall..so I'm hitting the tire pretty hard
Re: 14x32 M/T Pro Bracket Radial [Re: Plymouth340] #2766422
04/20/20 05:53 PM
04/20/20 05:53 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
like most who swap . There will be a learning period as shock adjustment is quite different plus of course different psi requirements .
I can only speak for the smaller versions , 28 and 29.5( actual 30") . I leave @ 4500 , 6000 stall . but likely am heavier than you .
Very consistent , rare to more than scrabble the tyre and I do not run radial prepped tracks , I bracket race .
Good luck if you go there .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 14x32 M/T Pro Bracket Radial [Re: tex013] #2766427
04/20/20 06:18 PM
04/20/20 06:18 PM
PA.
"Little"John
"Little"John
PA.
I know one other thing. My son has the 10-28 on his Duster and I think he checks tire pressure once a day and no longer uses a line lock to heat his tires.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 14x32 M/T Pro Bracket Radial [Re: pittsburghracer] #2766461
04/20/20 07:53 PM
04/20/20 07:53 PM
Massillon, Ohio
cudatom Offline
cudatom  Offline
Massillon, Ohio
Ok
I can see that working on my wagon I basically just clean off the tires and thats it
Ok
Re: 14x32 M/T Pro Bracket Radial [Re: cudatom] #2766606
04/21/20 09:01 AM
04/21/20 09:01 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
I wanted to do the switch from my Good year 2078's that I have ran pretty much exclusively since 2003 and did a lot of searching on the net for success stories, most are not as most gave up and went back to bias with big tires. But still I persisted and ordered a set from one of the big retailers, that set came and were 2.5 years old, everybody said send them back and I researched even M/T said there life is 4 years from manufacture, I emailed said big retailer ans told them of this and please send a set 1 year old or less and second set was 2.5 years old as well so they went back and about this time I talked to a few others that had bad experiences with them. So now when we can race again I am going to order up a new set of M/T 2074's bias. Most people don't understand that they are made to dead hook , not wrinkle, ect. and some that have ran them told me they can be hard on drive line components since no give. I really like the idea of no tubes and rim screws but with running two cars just don't have the time to test anymore. I have ran the little 30x9x15 Hoosier radials on my '68 road runner for 12+ years and they work great but for what ever reason it seems not a lot of success stories with the 32x14x15 radials. Good luck would like to hear your feedback if you change.
10426593_823939334284770_1329891318531776718_n.jpgSKMBT_C36420012705550_0001 (2).jpg
Re: 14x32 M/T Pro Bracket Radial [Re: Keith Richards] #2766731
04/21/20 01:31 PM
04/21/20 01:31 PM
CEDAR RAPIDS
CEDAR RAPIDS
thank for your input..i'm still on the fence about ordering a set. I have ran goodyears and hosiers both with good results..I hear radials are quicker which is good but I bracket race and need consistency..Im hitting the tire hard. 2775 lbs. leaving at 6000 and 7300 stall. back of car is 52 percent of weight
Re: 14x32 M/T Pro Bracket Radial [Re: Plymouth340] #2766740
04/21/20 02:05 PM
04/21/20 02:05 PM
I ran M/T ET Street radials and the same size ET Street bias ply on my old Duster on the street and at the track. The radials are faster (.1+ and 1.5+ MPH) and quicker on a good track but suck on bad surfaces, once the radials started to spin I had to let off or almost loose control do to the back of the car drifting to the left tsk
The bias ply might turn, spin, a 1/4 to 3/4 of a turn and then hook and stay hooked, not so on the radials twocents
The radials are heavier but they do hook better and roll easier on a good track up
Re: 14x32 M/T Pro Bracket Radial [Re: Cab_Burge] #2766956
04/21/20 10:54 PM
04/21/20 10:54 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Sounds like 2 sets of tires are needed. If the radials don't hook than switch to the bias and save the day!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: 14x32 M/T Pro Bracket Radial [Re: Cab_Burge] #2767077
04/22/20 12:01 PM
04/22/20 12:01 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
Pro Bracket Radials are NOT the same as any other type of Radial slick, people continue to compare them and they don't compare. They don't need a radial prep'ed track, they work great on standard prep tracks whether that be a sanctioned track or an outlaw track. They were built and designed for the typical bracket racer, not the NHRA event prep'ed tracks.
I've been running on them on my wife's '68 Barracuda for 4 years now and they work fantastic. They last for ever, much more stable going down the track and pick up your 60' times and mph. Doing nothing but switching to them picked up the wheelies by about 3". They are the 28x10.5s.
My car has been on jack stands for the past 4 years while I've been focused on Jr Dragster racing with my daughter but I'm finally putting my KB/B1 motor together and planning to get back to the track this year. I'm planning to go to the 14x32 PBRs. I've spoken to the MT techs with the trailers at the NHRA events and they do say that if you have a light car, like an S-10 or a chassis car, they have had some issues because they don't weight transfer as well but your typical bracket car they work great, so I'm looking forward to running them.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: 14x32 M/T Pro Bracket Radial [Re: WadeMetzinger] #2793317
07/06/20 10:33 AM
07/06/20 10:33 AM
IL
Dart451 Offline
Dart451  Offline
IL
How well do these tires hold air?
Re: 14x32 M/T Pro Bracket Radial [Re: Dart451] #2793352
07/06/20 11:52 AM
07/06/20 11:52 AM
Tulsa, Ok
Tulsa, Ok
My 28x10.5s hold air great. I've got 4 weeks and they may have only lost 1 pound.
I was planning to run 14x32 PBRs on my '71 Cuda but before I ordered them I spoke to one of the MT techs that bring the semi to the NHRA events and he recommended I stay with the standard bias ply stiff side wall slicks to I'm taking his advise and staying with the 3074S 14x32 stiff sidewall slicks.
But I will keep running the PBRs on my wife's '68 because they've worked so great over the past 5 or so years.
Re: 14x32 M/T Pro Bracket Radial [Re: Dart451] #2793382
07/06/20 12:34 PM
07/06/20 12:34 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have some 28x10.50s and they hold air as good as any daily driver tire. Mine haven't been on the car in 18 months and are still inflated.
68 Barracuda Formula S 340
Re: 14x32 M/T Pro Bracket Radial [Re: WadeMetzinger] #2793515
07/06/20 04:26 PM
07/06/20 04:26 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
...my season is short but put mine on last fall (14x32 pbrs 3200lb backhalf car,maybe a dozen hits in total)and still don't have mine sorted..
it duck walks unless i drop pressure to 14 then it feels like they're wadding up?...getting frustrated i think im just going to put the slicks back on
Re: 14x32 M/T Pro Bracket Radial [Re: 605ply] #2794150
07/08/20 02:12 AM
07/08/20 02:12 AM
gregsdart Offline
gregsdart  Offline
I tried a set of MT drag radial slicks size 14.5 x 33 x15 back in 2004 . i ran into a problem others tagged as "radial rock". The car would twist back and forth like a gorrilla was pushing sideways on the front and back of the car. I wound up having to lift on half of the passes because it was so bad i thought i would lose control. The car would not settle down till i lifted. People asked me why i didn't lift on a couple of runs, one of which was the fastest the car ever went. Nobody has ever come up with why this happens, or at least haven't shared the info.
Re: 14x32 M/T Pro Bracket Radial [Re: gregsdart] #2794377
07/08/20 02:59 PM
07/08/20 02:59 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
...thank you! No seems to know anyhting about this
...so i phoned M/T (should have done first) says to start at 12lbs and go up from there
Re: 14x32 M/T Pro Bracket Radial [Re: 605ply] #2794398
07/08/20 03:51 PM
07/08/20 03:51 PM
PA.
"Little"John
"Little"John
PA.
I have a couple friends that run the big radial but I also know they had some learning to do. I would love the free seat gains the radials offer but I’ve been holding off too. I have my chassis set where I need just a puff of smoke off my slicks and it will go
1.25-1.28 sixty foots and get long wear from my slicks.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: 14x32 M/T Pro Bracket Radial [Re: pittsburghracer] #2794489
07/08/20 08:09 PM
07/08/20 08:09 PM
gregsdart Offline
gregsdart  Offline
Back when i ran them they needed a very well prepped track and 12 psi to work. If they spun the 60 ft went from 1.27 to 1.34 instantly. I had 50/50 WEIGHT DIST at that time. They don't play well with a high SLR like 11.17 that i had, 4.56x2.45 low.
Re: 14x32 M/T Pro Bracket Radial [Re: gregsdart] #2794520
07/08/20 09:51 PM
07/08/20 09:51 PM
Alberta,Canada
605ply Offline
605ply  Offline
Alberta,Canada
...interesting. Just put 5.13's in over the winter, i have a th400 with stock ratios but have a griner second gear leave, will try that,
https://www.dropbox.com/s/3u6chzpk5bivh4u/IMG_0447.mov?dl=0
