Ramcharger shift prob afte torque converter R&R #2765838
04/19/20 10:16 AM
04/19/20 10:16 AM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
Changed out torque converter, took out oil pump and changed bushing and seal. Everything went back together fine. After starting and filling I only get 1st manual and reverse. I don't get anything when I shift into 2nd or Drive.
Parking gear is not locking either and I am getting a high pitched grind when going to park.
when in reverse or first with wheel off the ground, the drive train seems bound up.
Any help would be appreciated.
Re: Ramcharger shift prob afte torque converter R&R [Re: 70mopes] #2766935
04/21/20 10:02 PM
04/21/20 10:02 PM
Id
mopeman Offline
mopeman  Offline
Id
Did you remove the valve body?
Mopar or no car
MoPar=Massivly Over Powered And Respected!
'93 W250 Ram
'68 Charger
'67 Coronet 500 my steet/strip rod-now a 6BBL!
Re: Ramcharger shift prob afte torque converter R&R [Re: mopeman] #2766938
04/21/20 10:17 PM
04/21/20 10:17 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
His other post said he solved the issues.
