99 Ram Custom dashboard ? #2765722
04/18/20 11:48 PM
04/18/20 11:48 PM
Arizona
Chucklehead Offline OP
Arizona
My dashboard inner structure is crumbled on my 99 1500. If I build a custom dash and use aftermarket gauges how will that effect the ECM if by not having the factory instrument cluster plugged in? Or will it have no effect on the truck running properly? If it wont work that way then I will need to find away to mount the factory instrument cluster. Open for suggestions.
Still Broke
Re: 99 Ram Custom dashboard ? [Re: Chucklehead] #2765725
04/19/20 12:00 AM
04/19/20 12:00 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Why not replace the inner structure? They run about $500 but they hold all the dash stuff like heater and a/c controls and glove box and radio Etc. Not just the gauge cluster
Re: 99 Ram Custom dashboard ? [Re: stumpy] #2765728
04/19/20 12:11 AM
04/19/20 12:11 AM
Arizona
Arizona
I can not find a good inner structure in AZ . The heat makes the plastic brittle.
Still Broke
Re: 99 Ram Custom dashboard ? [Re: Chucklehead] #2765907
04/19/20 12:35 PM
04/19/20 12:35 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I see them on Ebay.
Re: 99 Ram Custom dashboard ? [Re: Chucklehead] #2766037
04/19/20 05:39 PM
04/19/20 05:39 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Hey Chuckles!! I just redid my 01 with a LMC dash. I used a soldering gun and gorilla glue to get my substructure up to par. I understand Permatex make a better epoxy. The LMC will be $330 to your door. Nice piece!
Jay
