Torqueflite dilemma - Need Trans pros.
#2765721
04/18/20 11:40 PM
04/18/20 11:40 PM
Posts: 1,228 Maple Valley, WA
70mopes
Maple Valley, WA
Working on a 78 360 Ramcharger with an A727. Had a massive leak. Split the trans and removed torque converter which had a badly worn snout. I replaced the converter, removed pump and changed bushing and re-installed everything. Other than the leak, the trans worked prior to starting the job.
After many hours re-assembling, i finally fired it up and topped it off, went through the gears to get the fluid everywhere. No leaks but now it only engages 1 and a Reverse. 2nd and Drive have a whirring noise but are not engaging. Seems like 1st and reverse are bound up too. With the wheels off the ground the wheels do not freely spin in either R or 1st.
Also, in park, the wheels do not set/lock as expected and still spin.
Any help or guidance would sure be appreciated. It has been a less than stellar day.......
Re: Torqueflite dilemma - Need Trans pros.
[Re: buildanother]
#2765749
04/19/20 04:48 AM
04/19/20 04:48 AM
Posts: 5,749 ohio
ruderunner
ohio
No park? Is the transfer case in neutral?
Angry white pureblood male
[Re: 70mopes]
#2766001
04/19/20 03:59 PM
04/19/20 03:59 PM
Posts: 16,923 NC
440Jim
NC
I tightened the kickdown band before pulling front oil pump and then re-adjusted it prior to firing it up.
.... Never took off pan or touched anything other than front pump (to replace seal and bushing) and kickdown band adjust. I am thinking that since you didn't pull the pan, the only things I can think of are: 1) Front drum with clutch pack not engaged correctly when reassembled (as somebody mentioned). But typically cannot get things back together if this happened. 2) The rings on the support or input shaft were damaged when reassembled. Leaking fluid passages to wrong places.
[Re: 440Jim]
#2766011
04/19/20 04:26 PM
04/19/20 04:26 PM
Posts: 3,068 Michigan
A727Tflite
Sorry, I read your first post that you did a complete when all you did was pull the pump.
So, for the ratcheting - sounds like you still have something wrong with the shifter. Move the lever all the way forward, then count how many detents you need to get to park. 1,2,D,N,R,P = 5. You need to address that first. Until a shifter is properly adjusted you should never do any diagnosis or repair.
If you installed the pump with the front band tight you likely damaged the input shaft seal/s. Like 440Jim mentioned, you may have had the front drum move forward when you pulled the pump then when installing the pump you crowded the first clutch disc and bend the teeth.
If you damaged the large reaction shaft seals you shouldn’t have a strong reverse.
[Re: moparx]
#2766354
04/20/20 03:22 PM
04/20/20 03:22 PM
Posts: 11,484 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I was going to say - if it grinds the park pawl going into park, the output shaft is turning. If the output shaft is turning and the drive shaft is not, the issue is between those two. Sounds like you found that out.
