Need help. need pics #2765347
04/18/20 05:07 AM
04/18/20 05:07 AM
Rhode Island
Caparco Offline OP
Caparco  Offline OP
Rhode Island
Does anyone out there have a edlebrok 600 Carb?. I would love a picture to see how the throttle and the throttle return spring are mounted.
~ 72 Dodge Challenger ~
~ 97 Dodge Neon ~
~ 97 Dodge Ram ~
Re: Need help. need pics [Re: Caparco] #2765416
04/18/20 10:42 AM
04/18/20 10:42 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Should find photos at the Edelbrock and Summit and Jeg's sites.
You need the Mopar throttle arm adapter; then the hookup is obvious.
This assumes the rest of your combo (cable, bracket) is stock.
Re: Need help. need pics [Re: topside] #2765556
04/18/20 04:41 PM
04/18/20 04:41 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Here.
0CC7349F-6BB0-4C61-9282-8CB36C9E0983.jpegAE5585E1-065B-4EF7-AED0-E8DC86FA28CB.jpegF27CAA5E-4020-42DD-8573-4A584B41785A.jpeg
Re: Need help. need pics [Re: GODSCOUNTRY340] #2765570
04/18/20 05:15 PM
04/18/20 05:15 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
Hope it helps
Re: Need help. need pics [Re: 65rbdodge] #2765639
04/18/20 07:58 PM
04/18/20 07:58 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Though this a Magnum the brackets and linkage are 1968. The extension for the throttle pressure linkage is a piece of 1/4" brass pipe. The threaded ends were cut off. Then it was threaded internally to match the threads of the linkage. The original rod was shortened slightly. Then the adaper was threaded into the front portion with a 1/2" long piece of a cut off bolt. Drilled one hole for the spring so it tucks under the carb to the rear. Made a slight extension for the cable as well.
Doug
Re: Need help. need pics [Re: dvw] #2766212
04/20/20 09:09 AM
04/20/20 09:09 AM
New York
rarefish Offline
rarefish  Offline
New York
Here is my setup using the Lokar cables.
Re: Need help. need pics [Re: dvw] #2770003
04/30/20 11:22 PM
04/30/20 11:22 PM
central IL reg Nov 18, 1999
Stroker Offline
Stroker  Offline
Doug
That plating/coating on your throttle bracket sure looks nice.
What is it?
Re: Need help. need pics [Re: Stroker] #2770034
05/01/20 07:50 AM
05/01/20 07:50 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Had the linkage done at the same time as the headers. Same coating.
https://www.qccoatings.com/
Doug
Re: Need help. need pics [Re: dvw] #2771967
05/07/20 12:04 AM
05/07/20 12:04 AM
Stroker Offline
Stroker  Offline
Doug
Thanks, and they're not in California.
That's almost local!
