Re: Carburetor recommendations? [Re: Sniper] #2765258
04/17/20 09:00 PM
04/17/20 09:00 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
[quote=Sniper]You will probably need the mopar throttle linkage adapter for the new carb. Edelbrock 1481, unless your carb already has that adapter, then you can most likely recycle it to the new carb.
Can't say about Holleys, I don't like them. 750 is overkill, imo. Years ago I ran some back to back testing on a mild 360. The Edelbrock 1406 vs the Edelbrock 1407. The 1406 had better mileage and a top speed of 110 in my test car. The 1407 got substantially worse mileage but would top out the 125 mph speedo, since it was my work car and I didn't need more top end but better mileage I stuck with the 1406.
I am not familiar with the "adaptor" this is what is on current carb... probably not right...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Carburetor recommendations? [Re: JMCFAN] #2765279
04/17/20 10:18 PM
04/17/20 10:18 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You don't have the adapter on that one, the adapter bolts onto that linkage and is setup to work properly with the kick down linkage and throttle cable.
Re: Carburetor recommendations? [Re: Sniper] #2765281
04/17/20 10:23 PM
04/17/20 10:23 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Installed pic
Re: Carburetor recommendations? [Re: Sniper] #2765637
04/18/20 07:56 PM
04/18/20 07:56 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Originally Posted by Sniper
Installed pic
Well hell....I have been running that carb like that for a long time....and guessing thats why my kickdown didnt work,...
Re: Carburetor recommendations? [Re: JMCFAN] #2765789
04/19/20 09:05 AM
04/19/20 09:05 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
If I were in your place Id go with an electric choke Edelbrock 600cfm. Why? Its a great carb, its close to what you currently had and with the correct kickdown adaptor should be a very simple install and go.
Keep old mopars alive.
Re: Carburetor recommendations? [Re: JMCFAN] #2765839
04/19/20 10:17 AM
04/19/20 10:17 AM
God's Country Maryland
GODSCOUNTRY340 Offline
Go with the 1407 750, your 383 will thank you. Put one on my 340 Demon and it loves it. The main reason people get worse mileage with the 750 is because they love the power increase and are standing on the throttle more. The 383 Magnum wasn't intended to be a gas miser so let it breathe like it wants to. If you want better gas mileage put a 2bbl. on it.
Re: Carburetor recommendations? [Re: 2boltmain] #2765840
04/19/20 10:17 AM
04/19/20 10:17 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I ordered the Elelbrock 600 with the kickdown adaptor I did go with manual choke...
Re: Carburetor recommendations? [Re: topside] #2765847
04/19/20 10:36 AM
04/19/20 10:36 AM
Sweden
Mopar493 Offline
Mopar493  Offline
Sweden
Originally Posted by topside
I'm very happy with the Eddy AVS2 I put on my street 383 Road Runner.
Works better than its original/rebuilt AVS, simply better manufacturing technology & annular boosters.
I changed the metering rods 2 steps leaner on primary side.
Mine is manual choke, but they also have electric if you prefer.
Hooking up the electric is easy, instructions provided.
Hi! It sounds great your happy with the avs2 carb, i have just buy one 800cfm to my 493 stroker and i hope i bee happy with it, i have not try it yet but i have heard a lot of good about the avs2 carb.
Re: Carburetor recommendations? [Re: Mopar493] #2765950
04/19/20 01:29 PM
04/19/20 01:29 PM
moparx Offline
moparx  Offline
a 4bbl will get BETTER gas mileage than a 2bbl on a 383 if conservatively driven. no whistling
beer
Re: Carburetor recommendations? [Re: moparx] #2766259
04/20/20 11:50 AM
04/20/20 11:50 AM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Will I also need the adaptor plate to mount iit or will it bolt right up... install videos are confusing...
Re: Carburetor recommendations? [Re: JMCFAN] #2766313
04/20/20 01:32 PM
04/20/20 01:32 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If your Carter bolted up then so will the Edelbrock.
Re: Carburetor recommendations? [Re: Sniper] #2766328
04/20/20 02:27 PM
04/20/20 02:27 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks!
Re: Carburetor recommendations? [Re: JMCFAN] #2766809
04/21/20 04:41 PM
04/21/20 04:41 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
One more ? Did end up going with electric choke. Good place to tie in for 12v key on power? I know coil and Alt are no no....
Never mind....search is your friend....
Re: Carburetor recommendations? [Re: JMCFAN] #2766899
04/21/20 08:33 PM
04/21/20 08:33 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Sorry, I was putting quality time in on the Cambridge's EFI build.
The switched 12V to the regulator/ballast is where the factory tapped into for it's electric choke setups. later ones also incorporated a three prong oil pressure switch that would only apply 12v to the choke if the engine was running.
Re: Carburetor recommendations? [Re: Sniper] #2766905
04/21/20 08:52 PM
04/21/20 08:52 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Exactly where I was planning now. Perfect . Thanks!!
