Page 35 of 48 1 2 33 34 35 36 37 47 48
Re: Modern Bullitt build [Re: Keepat] #2755937
03/25/20 05:05 PM
03/25/20 05:05 PM
Virginia
larry4406 Offline
larry4406  Offline
Virginia
Pat - Nice job yet again!
The reflections in the paint is simply amazing.
Did you cad plate your latch hardware or farm it out? If you did it your self, details please.
-larry
Re: Modern Bullitt build [Re: larry4406] #2756178
03/26/20 12:56 PM
03/26/20 12:56 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
-larry
I wish I could do my own plating!! Stephen Fournier with S.F restoration automobile re-plate all of my door latches.
Thank you!
Pat
Re: Modern Bullitt build [Re: Keepat] #2758906
04/02/20 02:02 PM
04/02/20 02:02 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Installed the right side rear power regulator and like on the door I had to cut an opening to allow the crank handle switch.
Re: Modern Bullitt build [Re: Keepat] #2758907
04/02/20 02:05 PM
04/02/20 02:05 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
This is a continuation of the first post, pictures are in order I installed the parts for the regulator. I missed taking a picture of sliding in the long track from the top that holds the two spring rollers.
Pat
Re: Modern Bullitt build [Re: Keepat] #2758995
04/02/20 04:09 PM
04/02/20 04:09 PM
OH
Red383 Offline
Red383  Offline
OH
Very nice work.
Question about the windows switches though. Is there a way to put all windows down from the drivers seat?
Re: Modern Bullitt build [Re: Red383] #2759022
04/02/20 05:14 PM
04/02/20 05:14 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Originally Posted by Red383
Very nice work.
There’s a 4 gang switch I mounted under the dash. A little more details two pages back.
Pat
Re: Modern Bullitt build [Re: Keepat] #2759362
04/03/20 10:30 AM
04/03/20 10:30 AM
Czech Republic,Europe,
O
ornocar Offline
ornocar  Offline
O
Hello !! long-time lurker on here....like 15 years lurker haha - I just have to comment on this. I am gearhead all my life, I like everything that burns rubber and gasoline, I have seen and followed many many great builds of different cars over the years - exotics, muscle cars,all kinds of vintage iron, home made hot rods - you name it...I loved them all, but THIS thing takes the cake ... I think that many members used all the superlatives you can use...I will just say: if I ever win the lotto , I will be banging on your door - you name the price haha !!!
Growing up in eastern block full of underpowered piles, car that could squeal the tires was considered a rocket. I was around 8 years old and total car nut watching tv over easter holidays - when this bad guy in glasses buckled-up the seatbelt and put the hammer down, it changed my life (seriously - career and everything) BEST BUILD EVER ! Best regards - Roman
Re: Modern Bullitt build [Re: ornocar] #2759504
04/03/20 02:18 PM
04/03/20 02:18 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Roman, Thank you for the kind words and for following along with this extremely long build. Like you I was also change by the movie Bullitt! Stay tune I think the end is getting near ;-)
Thanks again!
Pat
Re: Modern Bullitt build [Re: Keepat] #2761531
04/08/20 03:08 PM
04/08/20 03:08 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Now with the rear wheels on I could finish up the rear brake cooling ducts. I had made the air intakes and modified the Torque boxes before painting the bottom of the car 2+ years ago. But I did not have the rear installed at that time so I could fit the wheels to make the disk brake plates until this weekend.
Re: Modern Bullitt build [Re: Keepat] #2762201
04/10/20 09:52 AM
04/10/20 09:52 AM
Columbus, Ohio
Chally426 Offline
Chally426  Offline
Columbus, Ohio
What did you spray on the inside of those quarters?
Re: Modern Bullitt build [Re: Chally426] #2762372
04/10/20 03:23 PM
04/10/20 03:23 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
Love the cooling duct design! up
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: Modern Bullitt build [Re: Chally426] #2762469
04/10/20 07:32 PM
04/10/20 07:32 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I rolled Hercuiner bed liner inside both doors in quarters.
Pat
Re: Modern Bullitt build [Re: DynoDave] #2762470
04/10/20 07:33 PM
04/10/20 07:33 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Thank you sir! I’m hoping the front ducts come out as well.
Pat
Re: Modern Bullitt build [Re: Keepat] #2763630
04/13/20 08:05 PM
04/13/20 08:05 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I fabricated the front caliper cooling vent this weekend. Had a hard time finding a piece of 2 inch OD aluminum tubing until I got into my son’s golf bag and found his golf ball picker-upper tube. Cut off about 3” and put the cap back on. He will never know that holds two less balls;-)
Pat
[img]https://i.postimg.cc/28gg93Lx/64-B4-D412-2-CF8-4477-9-BEF-A4-AD3029-B0-E0.jpg[/img]
Re: Modern Bullitt build [Re: Keepat] #2765130
04/17/20 04:21 PM
04/17/20 04:21 PM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
I received the 2nd version of my custom 3D printed fender tag from Dan at http://www.nextgendesignsnc.com/ . We made a few changes in the font size, letters in the alphabet and spacing. Hope to paint it black and install it on the inner fender soon. Dan is great to work with, and I’m very happy with the tag!
Pat
Re: Modern Bullitt build [Re: Keepat] #2765267
04/17/20 09:37 PM
04/17/20 09:37 PM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
First time I've seen those 3D printed.
DynoDave
Member # 12304
Re: Modern Bullitt build [Re: DynoDave] #2765512
04/18/20 02:26 PM
04/18/20 02:26 PM
NJ
rdrnr6970 Online content
Your #1 source for current events
rdrnr6970  Online Content
NJ
This whole modern Bullitt build is simply amazing! drive
OWNER OF EVERYTHING FROM 1956 300 B,IMPERIAL,NEW YORKER HEMIS,AND NEW HEMI TRUCKS.....5TH GENRAMS.COM... 1969/70 ROADRUNNERS ,DARTS/CORONETS, NORTHEAST HEMI OWNERS ASSOCIATION.....WWW.PHANTASMCUDAS.COM....MOPAR FAMILY FOR 50 YEARS AND STILL GOING!MOPAR OWNER COAST TO COAST!!!!
Re: Modern Bullitt build [Re: rdrnr6970] #2768357
04/26/20 10:09 AM
04/26/20 10:09 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Rear brake coolers painted and installed. Still working on a few ideas for the air intake screen.
Pat
Re: Modern Bullitt build [Re: Keepat] #2768368
04/26/20 10:47 AM
04/26/20 10:47 AM
Superfreak
Superfreak
With cooling only one side of the rotor do you have any concerns of possible warping?
Re: Modern Bullitt build [Re: ] #2768381
04/26/20 11:23 AM
04/26/20 11:23 AM
Maryland
K
Keepat Offline OP
Keepat  Offline OP
K
Maryland
Not sure that could happen as the air is not that cool. Note that the air is actually directed towards the center so that it gets drawn in and out by the veins in between the disc, cooling both sides.
Pat
