Re: Braille Battery - what size?
[Re: roadrunninMark]
#2765816
04/19/20 09:44 AM
04/19/20 09:44 AM
Posts: 8,038 Tulsa OK
Bad340fish
Tulsa OK
They are out there but are hard to find and hard to get. I might have one in the garage, i'll look.
68 Barracuda Formula S 340
#2766133
04/19/20 10:12 PM
04/19/20 10:12 PM
Posts: 1,853 South Bend
John Brown
South Bend
Badfish, being a GM for a manufacturer, is it possible to get just a battery “body”, just a case without any of f the guts inside? I think I would like to hide a small battery inside of a full size one and make it look like a retro battery. I would rather not mess with the acid and stuff to cut up a bad battery if I could get a clean battery shell to start with. They are out there but are hard to find and hard to get. I might have one in the garage, i'll look. They are called display batteries. They turn up on epay every once in a while. Have converted a couple of them. Much cleaner than doing it with a wet battery.
[Re: Since1822]
#2766140
04/19/20 10:31 PM
04/19/20 10:31 PM
Posts: 31,114 Oregon
AndyF
Andy are you selling the battery trays yet??? Nicely done No I decided not to sell them. They aren't a bolt in deal so they would be a hassle to sell.
#2766216
04/20/20 09:23 AM
04/20/20 09:23 AM
John Brown
South Bend
That is what I am thinking John, not having to mess with acid and lead if I don't have to. Hopefully Badfish can find one but Ill also check on ebay. If you run into any, please let me know.
Thanks 27 series? Just checked a minute ago. No 27's, and no 24's. You might check your local parts stores and ask if they have any stuck away on their back shelves. Paid $10.00 for one years ago to one of my customers I had been calling on for years. You wouldn't have wanted that one. It was a 24 Delco.
#2766260
04/20/20 11:50 AM
04/20/20 11:50 AM
Posts: 3,704 MICHIGAN
DynoDave
MICHIGAN
Thanks It's not as fun as a day at the ballpark. I'm going through that right now. A new start for my 77 Cordoba
[Re: Hemi_Joel]
#2766388
04/20/20 05:10 PM
04/20/20 05:10 PM
Posts: 625 Oakville, Wa
HOTMOPR
Oakville, Wa
I have been checking these out as well! I worry though. I have a few loads. Electric water pump, turbo oil scavenge pump, small radiator fan, EFI system coil on plug and injectors. maybe the next size up??
67 Barracuda, 470" B, Glide, FuelTech FT600, Precision, Ptc, QA1, Calvert, Smith racecraft, Afco, Dana 60. 275 radials
[Re: HOTMOPR]
#2766392
04/20/20 05:17 PM
04/20/20 05:17 PM
HOTMOPR
Oakville, Wa
I have been checking these out as well! I worry though. I have a few loads. Electric water pump, turbo oil scavenge pump, small radiator fan, EFI system coil on plug and injectors. maybe the next size up?? One other question. What are you using to charge it? I do run a tiny Denzo style alternator. But on my optima I still need to charge between rounds. I did remove a huge electric fuel pump..
[Re: HOTMOPR]
#2766400
04/20/20 05:26 PM
04/20/20 05:26 PM
Posts: 7,502 Minnesota
Hemi_Joel
Minnesota
I use a Remy 21798 alternator. It is 105 amp and weighs about 12 lbs. It is commonly available at just about any parts store. I run on Drag Week which involves street driving, plus there is no way for me to plug in a charger at the track. So I need a powerful alternator that I can buy anywhere in case it fails on the road, even tho it is heavy. Edit: THis alternator is for a 1999 - 2004 silverado 1500. It is about the most power you can run off a single V belt, and it needs to be TIGHT. It comes with a serpentine pulley, and I had to put a V pulley on it. So if it dies on the road, I will have to swap the V pully onto the replacement alternator.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: HOTMOPR]
#2766409
04/20/20 05:37 PM
04/20/20 05:37 PM
Hemi_Joel
Minnesota
I have been checking these out as well! I worry though. I have a few loads. Electric water pump, turbo oil scavenge pump, small radiator fan, EFI system coil on plug and injectors. maybe the next size up?? Might not be a bad idea to go up one size. But if you have enuff alternator, the bigger battery will only give you more reserve for running stuff when the engine is off. This one certainly has enuff oomph to start the car.
[Re: Hemi_Joel]
#2766416
04/20/20 05:44 PM
04/20/20 05:44 PM
Hemi_Joel
Minnesota
Not only did I save the weight of the battery, I saved about 20# of cable by mounting the battery a foot away from the starter on the inside of the frame rail, instead of in the trunk. The NHRA mandated battery cut off switch is right there too, with the lever of it on the floor inside the car where I can reach it if I forget to turn it on. A 3/8" x .030" wall stainless steel tube runs from the lever, back through the trunk and out the back of the car as a remote control for the switch. That is much lighter than a Morse cable, it only weight a pound.
#2766529
04/20/20 10:41 PM
04/20/20 10:41 PM
DynoDave
MICHIGAN
Those smaller batteries can tuck in some of the tighter areas. I didn't think about putting it closer to the starter.
Dyno - Can you fill that crack with some melted plastic? If you can, I would drill a hole on the ends of the crack so it won't keep cracking, then try to fill that and the crack with some hot black plastic. Looks like a ton of nastiness in that old battery of yours!
What is everyone doing with the old acid and lead plates from the batteries you cut open? I'll do something to address it for sure. Epoxy, Gorilla Glue, some sorta something. Doesn't have to be water/acid tight or structural. All for appearance, and completely covered on the sides by the Thermoguard. I'll find something that will work. Yes, fairly messy in there, though I've managed to do it fairly neatly from a work area point of view. I have a 5 gal. bucket with a heavy mil contracor garbage bag that all the contents are going into. Our county has hazardous waste collection days 3 or 4 times a year, and they take car batteries. So I'm going to give it to them. I love the lithium battery upgrade. But knowing how hot they get in computers and phones, I worry about one in a hot engine compartment. Unlike a modern hybrid or BEV, where the battery is liquid cooled and computer monitored, mine will just have a 40 year old plastic Thermogruard with airflow through the core support around the repro case. Almost wondering if I should leave the hole in the side of the case!
