Hood Lip and C Molding 70 RR/GTX #2764097
04/15/20 07:31 AM
04/15/20 07:31 AM
Virginia
V
vadartlover Offline OP
V
Virginia
I need the molding that goes above, around and below the grill. I guess that is the hood lip & C molding plus the lower piece (not sure what it is called), which would be four pieces I think. Does anyone know where to purchase? I can find the first three but not lower piece. Will the 68-69 upper and lower pieces work? Thanks!!!
Re: Hood Lip and C Molding 70 RR/GTX [Re: vadartlover] #2764151
04/15/20 09:36 AM
04/15/20 09:36 AM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Hood lip molding and lower molding are stainless. The C moldings on the end of fenders are cast (pot metal) with chrome. These are all 70 only parts. Not sure if they are re-produced.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Hood Lip and C Molding 70 RR/GTX [Re: vadartlover] #2764155
04/15/20 09:47 AM
04/15/20 09:47 AM
Illinois
sixbbl 69 Offline
sixbbl 69  Offline
Illinois
sent you a message. Jerry
Re: Hood Lip and C Molding 70 RR/GTX [Re: vadartlover] #2764182
04/15/20 10:57 AM
04/15/20 10:57 AM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Sounds like your looking for the grill moldings? no
Ron
Re: Hood Lip and C Molding 70 RR/GTX [Re: RJS] #2764275
04/15/20 03:00 PM
04/15/20 03:00 PM
Virginia
V
V
Virginia
no, molding that fastens to the hood and fenders. There is one below the grill too I believe. So we have the grill and bezel molding, the ones I need go above and below them, sort of a circle around.
Re: Hood Lip and C Molding 70 RR/GTX [Re: vadartlover] #2764293
04/15/20 03:30 PM
04/15/20 03:30 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
You can see the ones on pic of my car . . .
Re: Hood Lip and C Molding 70 RR/GTX [Re: a12rag] #2764374
04/15/20 06:38 PM
04/15/20 06:38 PM
Virginia
V
V
Virginia
I see the bottom piece clearly. It doesn't even look like you have the C moldings or hood lip piece or that is an awesome job. I hope mine looks that good when I finish.
Re: Hood Lip and C Molding 70 RR/GTX [Re: vadartlover] #2764412
04/15/20 08:06 PM
04/15/20 08:06 PM
a12rag Offline
a12rag  Offline
right click "view" image, then use your menu bar to find the + to size up the pic and you will see the trim pieces . ..hood piece is held on by screw on bottom side of molding, and the "C" on the fender have studs with nuts . . .
Here is another view . . . the pieces on my car, are the original ones that I took the time to polish up . . .
Re: Hood Lip and C Molding 70 RR/GTX [Re: a12rag] #2764501
04/16/20 08:06 AM
04/16/20 08:06 AM
Virginia
V
V
Virginia
I see it now. Do you have any of these pieces lying around?
Re: Hood Lip and C Molding 70 RR/GTX [Re: vadartlover] #2764541
04/16/20 10:30 AM
04/16/20 10:30 AM
a12rag Offline
a12rag  Offline
sorry no I don't . . . I was lucky that my car had all it's original trim and was able to reuse a lot of it . . . good luck with your search ! Can't recall if there was someone out there re popping the trim or not . . . .
Re: Hood Lip and C Molding 70 RR/GTX [Re: a12rag] #2774619
05/14/20 06:32 PM
05/14/20 06:32 PM
Virginia
V
V
Virginia
Just an FYI, yes all four pieces are reproduced. As soon as I figure out the mounting hardware, I will be in business.
The confusion to me is the lower piece is advertised as lower grill molding.
So mystery solved.
