Holley street Dominator intakes 4 B and RB motors users
#2763886
04/14/20 03:16 PM
04/14/20 03:16 PM
Posts: 43,241 Bend,OR USA
Cab_Burge
I have not yet used one of the Holley Street Dominator intake on any of my or one of my customer motor but I've bought two, one B and one RB intake. My questions to you that have used them what size carb. or carbs. did you try and how did they drive on the street especially light part throttle driving ?
Thanks in advance: Cab
Re: Holley street Dominator intakes 4 B and RB motors users
[Re: Cab_Burge]
#2763888
04/14/20 03:22 PM
04/14/20 03:22 PM
Posts: 4,693 Wichita
GY3
Wichita
Thanks in advance: Cab I use the RB Street Dominator ported by Bobby (Streewize) with an 850 Demon carb. It is a great driving and performance combo. No issues at all. I also like it because it is shorter and still manages to fit under my stock hood with a spacer and a nitrous plate.
[Re: Cab_Burge]
#2763897
04/14/20 03:40 PM
04/14/20 03:40 PM
Posts: 17,892 S.E. Michigan
ZIPPY
S.E. Michigan
I have used both the B and RB versions and still have them.
I have used 650, 750, 850 and 1000 4150 carbs with them and always found them to be a very driveable kind of a piece that fit under most hoods.
performance wise, I remember....
The B version was down somewhere around 18hp at the wheels compared to a Victor on my 451 combo, not including everything I picked up with carb spacers which was pretty significant. Considering how much taller and newer the Victor is, and considering the Holley manifold was probably designed for 383ci, that is not bad at all. The best I ever ran with the 'B' holley st dominator was 11.24 at 117.3. As the intake manifold that helped me get kicked off the track for not having a harness or roll bar, it will always hold a place in my heart lol.
Back when I ran 12s, the RB version was within about .1 ET and same MPH as a Performer RPM with the same carb and no attempts made to optimize anything, so the test may have not been totally fair. I just threw it on and adjusted idle mixture. The RPM felt stronger down low and was a little more responsive in part throttle driving as you'd expect from a dual plane. However the RPM is quite a bit taller and won't fit as many cars as easily. They both ran 12:5's at like 106.
They're pretty good pieces. I won't sell mine until I'm convinced I won't want to use them again later.
Rich H.
Esse Quam Videri
[Re: Cab_Burge]
#2763957
04/14/20 06:37 PM
04/14/20 06:37 PM
Posts: 16,928 NC
440Jim
NC
My street/strip 1973 Cuda has the RB Street Dominator intake with an 850 Street Demon carb. It is a great driving and performance combo. The first few years I used the carb simply jetted at the track. Then later I richened the idle air bleeds (press in type), for better cold operability and off idle throttle response. The engine is 446 CID, 10.7 CR, "452" iron heads with a MP 0.557" flat tappet cam. It has Hooker Competition headers, #5903, with the 1-7/8 tubes, 3" collector, an H-pipe with dual mufflers and full tail pipes to the modified factory rear tips. Torqueflite 727 trans with a super street fighter 4000 rpm 10" converter. 11.70 at 114 mph on a cool day with 4.56 gears. I run 3.90 gear on the street.
[Re: Cab_Burge]
#2763964
04/14/20 07:04 PM
04/14/20 07:04 PM
Posts: 12,200 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I ran mine on a 440 with an 850 Holley and then a Proform 950. Did real well. Then I built a 500 stroker. In an attempt to keep everything under the Shaker, I modified the intake to accept a 1050 Dominator. I just screwed some aluminum bolts into the carb bolt holes and cut them off. Then opened the plenum up enough to clear the Dominator's throttle blades. Worked good on my street/strip Cuda. One of my favorite intakes.
Master, again and still
[Re: calrobb2000]
#2764027
04/14/20 10:59 PM
04/14/20 10:59 PM
Posts: 2,256 IL
furious70
IL
years ago I ran one on a stockish magnum 383. The car had more low end grunt by virtue of how it would spin the tires off idle with a stock intake and 3.23's than it did with the SD and 3.91's. Same car, same tires, same road for both set ups. I also have both b and rb versions on the shelf, saving them for strokers with stock hoods if the day ever comes. it is nice that the runners allow all stock accessories to mount up.
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2764223
04/15/20 12:41 PM
04/15/20 12:41 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Back in the early 80's (81-82) I had a 440 that I had a Street dominator w 800 Holley and a "DC-509" was a great little street strip combo, As I recall it went high 12's in a 70 Cuda with 4.88's, slapper bars and a pinion snubber,...two more things that "don't work"... Similar combo but on a 76 smog motor, made my 79 PU run best of 13 oh's with a stock converter, and a lot of rear gear. Ah the days when things were simpler..
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2764557
04/16/20 10:56 AM
04/16/20 10:56 AM
ZIPPY
S.E. Michigan
Ah the days when things were simpler.. You got me feeling nostalgic enough to scrounge these up. B and RB
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2764602
04/16/20 12:53 PM
04/16/20 12:53 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Zippy...chrome box and a big old yellow super coil. I had them too and they worked!
[Re: Jeremiah]
#2764626
04/16/20 01:50 PM
04/16/20 01:50 PM
Cab_Burge
Zippy...chrome box and a big old yellow super coil. I had them too and they worked! I remember hearing Tom Hoover or one of the other Mopar drag team members saying to not use the big old Accel coil with their Chrome Mopar race ECU, only use the Mopar special race coil with it at one of their drag race seminars Ziggy, is that ECU the old Mopar race chrome ECU with the blue heat sink?
[Re: fourgearsavoy]
#2764661
04/16/20 03:35 PM
04/16/20 03:35 PM
ZIPPY
S.E. Michigan
I always wonder why the Torker II doesn't work as well as the SD Torker II is actually in pretty much the same league of awesome, there's a difference but not a ton. I wouldn't hesitate to use one. With a little work done to it I'm sure it'd be just about the same. https://www.hotrod.com/articles/mopp-0207-intake-manifold-engine-and-rpm-range-test/Only problem is there was never a B version Torker II. RB and small block only. They aren't horrible. Ziggy, is that ECU the old Mopar race chrome ECU with the blue heat sink?
USA Chrome box had a black heat sink, USA Orange box had a blue heat sink. That goofy giant yellow super coil never let me down, then I switched to an msd blaster and it ran exactly the same LOL. Also check out the drum brake master cylinder in the RB picture.
Rich H.
Esse Quam Videri
[Re: ZIPPY]
#2765031
04/17/20 12:24 PM
04/17/20 12:24 PM
W.I.N. Racing
Byron, NY
Ah the days when things were simpler.. You got me feeling nostalgic enough to scrounge these up. B and RB Not to highjack but I'm gonna Zippy I'm going to be in your neighborhood in the next couple of weeks. I am buying a trailer in Monroe, what's the chances I'm going to in and out of MI...especially w/plates NY on my truck
[Re: W.I.N. Racing]
#2765093
04/17/20 02:51 PM
04/17/20 02:51 PM
ZIPPY
S.E. Michigan
W, I am thinking you aren't gonna have a lick of trouble.
A select few folks are kinda losing their mind over the restrictions, the rest of us who recognize the restrictions are nearly unenforceable are doing what we need to do, being as prudent and careful as possible to not spread the virus, and enjoying the light traffic and low fuel prices.
Remember, it's okay to out for groceries. It doesn't say exactly where you have to go. So make sure you are getting groceries no matter what other errands you might combine to save fuel.
I've been driving my C body most of the time, it sticks out a little bit. Nobody says anything.
Rich H.
Esse Quam Videri
[Re: 440Jim]
#2765095
04/17/20 02:53 PM
04/17/20 02:53 PM
ZIPPY
S.E. Michigan
My street/strip 1973 Cuda has the RB Street Dominator intake with an 850 Street Demon carb. It is a great driving and performance combo. The first few years I used the carb simply jetted at the track. Then later I richened the idle air bleeds (press in type), for better cold operability and off idle throttle response. The engine is 446 CID, 10.7 CR, "452" iron heads with a MP 0.557" flat tappet cam. It has Hooker Competition headers, #5903, with the 1-7/8 tubes, 3" collector, an H-pipe with dual mufflers and full tail pipes to the modified factory rear tips. Torqueflite 727 trans with a super street fighter 4000 rpm 10" converter. 11.70 at 114 mph on a cool day with 4.56 gears. I run 3.90 gear on the street. Jim I also use a depth mike to check deck height. I do that + rock the piston to find the average. But ....I see many other use a bridge. Why would one be preferable over the other?
Rich H.
Esse Quam Videri
