Antenna Lead Routing #2762501
04/10/20 09:32 PM
04/10/20 09:32 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
69 Charger under the dash how was the antenna lead run? Over or under the glove box and what was used to hold it in place? The antenna lead was cut off when I took the car apart 15 years ago. I would like to put it in its proper place.
Re: Antenna Lead Routing [Re: NITROUSN] #2763212
04/12/20 09:37 PM
04/12/20 09:37 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
If any one cares its routed under the glove box and has several z like clips that grab the dash frame rib and cradle the wire.
