Page 1 of 10 1 2 3 9 10
TH400 to RB in 69 b body info,I have a trans #2761806
04/09/20 08:47 AM
04/09/20 08:47 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am getting ready to make the move to a TH400 in my Satellite.I asked in the past for a pic of the trans tunnel adjustment but never got it so if you have 1 please post it along with the trans cross member.I am going with an Utra bell because I don't want a mid plate if I can.TIA for your help!
Re: TH400 to RB in 69 b body info [Re: Clanton] #2761816
04/09/20 09:25 AM
04/09/20 09:25 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Why? There is absolutely no reason a 727 won't live with your combo. I agree a 400 is good. But at what cost? You don't need one.
Doug
Re: TH400 to RB in 69 b body info [Re: dvw] #2761818
04/09/20 09:27 AM
04/09/20 09:27 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Come on Doug! All the cool kids are doing it!
Re: TH400 to RB in 69 b body info [Re: J_BODY] #2761819
04/09/20 09:35 AM
04/09/20 09:35 AM
bronx n.y
O
one bad fish Offline
O
bronx n.y
lol
Re: TH400 to RB in 69 b body info [Re: dvw] #2761822
04/09/20 09:41 AM
04/09/20 09:41 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
What I can say is mine don't last so I am done with it so post info if you have it .TY!
Doug
Re: TH400 to RB in 69 b body info [Re: Clanton] #2761900
04/09/20 12:56 PM
04/09/20 12:56 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
HI
what is the advantage? I have had a 727 in my super/gas lebaron for sometime now
gary
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: TH400 to RB in 69 b body info [Re: Clanton] #2761904
04/09/20 01:01 PM
04/09/20 01:01 PM
Do you want to slow your car down with the heavier parts in the 400? scope
Re: TH400 to RB in 69 b body info [Re: Clanton] #2761922
04/09/20 01:47 PM
04/09/20 01:47 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Doug
IF YOU CANT KEEP A 727 TOGETHER WITH YOUR COMBO EITHER SOMEONE IS NOT BUILDING THEM RIGHT OR YOU ARE NOT SETTING UP YOUR TV CORRECTLY.
JAKES AUTOMOTIVE
Re: TH400 to RB in 69 b body info [Re: JAKE68] #2761929
04/09/20 02:12 PM
04/09/20 02:12 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
I had a 400 in an ebody. I get it the parts availability and converter selection is much better. The ultra bell is heavy and you really need to move the floor/firewall around a good bit for it all to fit nicely. I would also recommend an SFI case. Trying to put a shield on it would be a whole other issue. A blanket works pretty good. Headers are another concern, depending on what you have you may have top reengineer them to fit. The TTI stuff probably won't fit without a lot of work. What kind of power and what does your car weigh? I have to say I thought about putting a 400 in the 65 I am building and just didnlt want to do the work required and just couldn't justify the cost. I have had a 727 in a 3700# car running 9.90s for hundreds of passes with 0 issues and just a billet drum and bolt in sprag. It can be done but I see the 400 benefits as well. Sorry I don't have any pics to contribute but hopefully this gives you an idea of the challenges.
Re: TH400 to RB in 69 b body info [Re: biff426] #2761936
04/09/20 02:31 PM
04/09/20 02:31 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you for the info.If you can say nore on adjusting the floor/tunnel I would appreciate it a lot.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2761943
04/09/20 02:50 PM
04/09/20 02:50 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
You will have to cut the tunnel and enlarge it basically a total re-do - also you will need to build a new cross member for the 400 - if you are using an SFI approved case will get you away from blankets and shields that's one plus as between the bell housing and case you are covered - its a lot of work with no gain other than parts availability - powerglide would be easier. If you are having problems at your power level - get a new transmission builder
Re: TH400 to RB in 69 b body info [Re: DoubleD] #2761959
04/09/20 03:29 PM
04/09/20 03:29 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
Basically I agree with the above you really need to cut the tunnel and make a new one at least to the mount. The mount is not too bad to make, the firewall opening needs to be bigger, the area from there back needs to be taller and wider basically back to the mount crossmember. The lines are on the right side and not the left side as well. All in all if this were a 1200HP 3400# car on a small tire where shake, and gear ratio become a problem I would spend the time. If it is a bracket deal I would do a glide much easier or build a 727 with better parts.
Re: TH400 to RB in 69 b body info [Re: biff426] #2761962
04/09/20 03:34 PM
04/09/20 03:34 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you for the information!
Re: TH400 to RB in 69 b body info [Re: Clanton] #2761963
04/09/20 03:35 PM
04/09/20 03:35 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
if you have pics of the tunnel redo TIA!
Re: TH400 to RB in 69 b body info [Re: Clanton] #2761984
04/09/20 05:17 PM
04/09/20 05:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
[quote=Clanton]What I can say is mine don't last so I am done with it so post info if you have it .TY!
What parts have you failed? Who is building your transmission? My car has well over 400 runs on the current clutches and band. Correct me if I'm wrong, but I believe you run low 10's? How any passes have you made? 100 or less?
Doug
Re: TH400 to RB in 69 b body info [Re: dvw] #2761985
04/09/20 05:28 PM
04/09/20 05:28 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I want to put that in the past how long it lasted,30 runs.just leave it at thatpls.ty
Doug
Re: TH400 to RB in 69 b body info [Re: Clanton] #2761997
04/09/20 06:25 PM
04/09/20 06:25 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Turbo400 is a good trans. Can be built to hold a lot of power pretty inexpensively. The same could be said for a properly built torqflite. The benefits of installing a 400 into a B body, are not... for most, worth the effort. I understand being soured on parts. But It seems that maybe you would be best off to step back, take a breath, and re-evaluate your choice of trans builder. I assure you you are not making enough power to need to walk away from a TF.
Re: TH400 to RB in 69 b body info [Re: TRENDZ] #2762000
04/09/20 06:32 PM
04/09/20 06:32 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
if you are counting the ponies---a powerglide loses the least HP out the back---the built 904 is second in the loss column------or maybe you are already too fast....
Re: TH400 to RB in 69 b body info [Re: savoy64] #2762006
04/09/20 06:50 PM
04/09/20 06:50 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
Did you get burnt out and frustrated with the 727 while you still had the blower on the car??
Even a slow heavy car is hard on the trans. with a roots style blower.
IF anything is deficient in it the torque. fails them quickly.
Even my 11-0 streetcar has taken out 3rd FOUR TIMES.
Finally got it sorted out.
IMO with the blower forget horsepower, worry about the torque.
Your car, your effort your money and choice.
Hope you get it how you want it...👍
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: TH400 to RB in 69 b body info [Re: 6bblFLASH] #2762017
04/09/20 07:12 PM
04/09/20 07:12 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you for your support!!
